How do you disable the Automatic Prompt to Update Flash through the network for multiple workstations?
We have referenced the following article but multiple machines are still being prompted to update:
Disable Adobe Flash Updates on 64-bit Windows with Group Policy
We've updated the Group Policy for all workstations and they are still being prompted.
How can we officially turn the updater off for all?
We manually send the update through SCCM without any action from the client.
[moved from Adobe Creative Cloud to Installing Flash Player]
Add AutoUpdateDisable=1 to the mms.cfg file saved at the following location:
It's possible the system was already configured to display the notification update prior to disabling updates. For Notification Updates, when an update is encountered Flash Player creates the following two registry entries:
The presence of the RunOnce > FlashPlayerUpdate entry triggers the Notification Update to display upon logging into the system. If these entries (especially the RunOnce > FlashPlayerUpdate) do not exist the Notification Update prompt does not display. You can write a script to periodically check if these entries exist on the system and if they do, delete them.
Note that the AutoUpdateDisable setting in the mms.cfg file is reset to the default setting of AutoUpdateDisable=0 when Flash Player is uninstalled. If your deployment strategy involves uninstalling Flash Player before installing the new version this option will be reset and you'll need to deploy the custom mms.cfg file again disabling Flash Player Update Notification (AutoUpdateDisable=1) after installing the new version of Flash Player.
More information on this can be found in the Flash Player Administrators Guide.
We have the mms.cfg file set this way through Group Policy and we’re still receiving the Prompt.
Any other suggestions?
Please provide the following information from an impacted system:
In the interim, you can perform the following troubleshooting steps:
We have configured the mms.cfg file to reflect these settings and so far no more popups.
Thanks for the update. We haven't had a release since July 11 (2nd Tuesday of the month). The next regularly scheduled release will be August 8. If the mms.cfg file is configured correctly, and in the correct location, your users should not see the update notification prompt. I will be on vacation for the next release. If you experience issues, post back here and one of the other staff members should see it and assist you.
Maria
Thank you!
Did any of your systems display the pop-up message after the August 8th release?
Maria
I am having a new issue with Adobe Acrobat Pro 2017 that when I try to do a Fill & Sign – I’m getting the attached error.
Help PLEASE??!!
I would love to just draw my signature or do a very simple signature and this is a newly purchased product.
Please post Acrobat questions to the Acrobat forum.
Note that the forums software doesn't accept email attachments. To attach an image/document to your post, please log into the forums and add it to your post.
