• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
licensing FrameMaker 13
Community Beginner ,
Jul 18, 2017 Jul 18, 2017
I have a license for FM 2017 (v14) license. I need to use FM 2015 (v13). How?
Views
400
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Jul 19, 2017 Jul 19, 2017
Common Use Case: a corporation settles on a version of a production tool older than the current version.
The FrameMaker licensing implementation does not support this use case.
I did promise an update if I learned something definitive. Which is:
1) A FrameMaker license key works for one version and one version only.
2) There is no online or automatic way to get a license for an older version.
3) Ergo, one MUST contact support at tcssup@adobe.com and request.
Because you cannot purchase a license for
Votes
Translate
Translate
Community Expert ,
Why do you need to use v13?
If it's because your customer is on v13, v14 presumably can save-as v13 directly, and of course to MIF for any prior version.
Votes
Translate
Translate
Report
Report
For consistency and smooth interoperation with the rest of the company’s tech pubs team, which is using v13.
Votes
Translate
Translate
Report
Report
Community Expert ,
Do you have a volume license for FM2015? Do you have FM2015 installation media? Have you contacted Adobe Support about using your serial number with FM2015?
Votes
Translate
Translate
Report
Report
Hi Jeff. I have no license specific to 2015. What I have is a “one-off” single seat purchase to enable me to assist our tech pubs team (I’m an engineer with a serious tech writing background). Hence my desire to remain on the same version as our pubs team. I do have the 2015 installer, as well as 2017. Both are currently installed, the 2017 works.
I have contacted Adobe support – if I get a generally useful response, I’ll post it here as well.
Thanks!
Votes
Translate
Translate
Report
Report
Because you cannot purchase a license for an older version, only the current version, there is no way to use an older version without jumping through the support hoops. I personally think this is suboptimal, to be polite.
My expectation: If I have a valid license for a newer version, I should be able to use an older version transparently. This is not rocket science. This is pretty simple to implement in a good licensing system.
So far support has been helpful, but I still don't have a license for FM2015.
Votes
Translate
Translate
Report
Report
Community Expert ,
re: Because you cannot purchase a license for an older version
Yes, you can, although not perhaps directly from Adobe.
CDW dot com has them, going back several releases.
Votes
Translate
Translate
Report
Report
LATEST
Ah sweet. That would be good to know for some folks. Me, I'm tied to corporate purchasing systems, so someone else orders it from wherever we normally get stuff. I appreciate you filling in that detail. That's MUCH better than two days with support.
In the meantime, a 2015 license has arrived.
All's well that ends that way.
Votes
Translate
Translate
Report
Report
