Is there a way to access the index of a shape in a shape layer? Just like how I can use layer index to talk to specific layers in a comp, I want to talk to specific shapes in a shape layer. Like Rectangle 1. Rectangle Path [3] or something like that?
There is no absolute index to address. You address this stuff using the .content() method referencing the groups and property streams. The real crux of course is that you may end up writing endless strings of content(Top Group).content(Sub Group).content(Path) and so on just to gain access to a simple value, depending on how deeply you nested your stuff. The actual groups can of course be referenced using their indices just as well, but this gets quite confusing and messy since in fact most of t
...Copy link to clipboard
There is no absolute index to address. You address this stuff using the .content() method referencing the groups and property streams. The real crux of course is that you may end up writing endless strings of content(Top Group).content(Sub Group).content(Path) and so on just to gain access to a simple value, depending on how deeply you nested your stuff. The actual groups can of course be referenced using their indices just as well, but this gets quite confusing and messy since in fact most of them will simply only have 1 as their number and clearly content(1).content(1).content(1) isn't particulalrly telling. Therefore using the names is much more advisable.
Mylenium
I found a few resources that dig into it a bit. using propertyIndex of the propertyGroup(), but they only explain so much. I am still trying to figure out you to use it for linking individual shapes but it seems so complicated.
Tapering A Stroke with Expressions Part 1 on Vimeo
Property Group and Index - AE ENHANCERS
Property Group Index Expression + Free Preset - YouTube
Yep, this is the right approach. I used this when trying to change transform properties of a specific group, matching the index of the group to the index of the layer (I would then duplicate the same layer multiple times in the same comp)
You can find the name of the group like this:
var groupIndex = thisProperty.propertyGroup(2).propertyIndex;
var groupName = thisLayer("Contents")(groupIndex).name;
Combining the group index and name, you should be able to set up the rig I hope. Lemme know, thanks!
You can use the propertyIndex and group name property, something like this:
You can change the 2 above to whatever heirarchy the group is in.
Hopefully all your shape layers are in groups with the same heirarchical level
