• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
SpreadsheetCreateSheet - check if sheet already exists?
LEGEND ,
Jul 19, 2017 Jul 19, 2017
Hello, all,
I'm working with SpreadsheetNew and SpreadsheetCreateSheet, populating from a query object.
I've experienced something that I've never seen, before.  If you have a Spreadsheet object and try to add a sheet to it using a name that already exists, CF will abort.  I finally got it to email the reason to me.  "The workbook already contains a sheet of this name."
I am sorting the data on the column (FQDN) that I am using to name the sheets with.  I'm removing "http://" and "https://" from the FQDN and using "www.example.com" as the sheet names.
However, I did not expect for there to be "http://www.example.com" AND "https://www.example.com", so when CF creates "www.example.com", populates the sheet, then tries to create "www.example.com", again, it just stops.
I am not seeing any CF Spreadsheet(blahblahblah) commands that will check to see if a sheet already exists.
I will try to modify the query so that both standard and encrypted FQDNs fall into the same group, but just in case.. can anyone think of a way to check if a particular sheet name already exists within a Spreadsheet object??
V/r,
^ _ ^
Views
619
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jul 19, 2017 Jul 19, 2017
Well, I did kind of find an answer to my question.  You can use SpreadsheetInfo(obj) to get information about the spreadsheet object, including a column called "SHEETNAMES".  It's a comma-delimited list of the names of currently existing spreadsheets.  I will iterate through that and just make that the active sheet instead of creating it if the name already exists.
V/r,
^ _ ^
Votes
Translate
Translate
LEGEND ,
LATEST
V/r,
^ _ ^
Votes
Translate
Translate
Report
Report
Resources
Documentation
