I'm not sure how to word what i'm trying to ask properly but here goes..
Some of my answer choices are longer than others. There for, I'm manually having to guess how far apart I'm needing to space them out from each other.
My answers shuffle. Seems If i don't space them out just right they clash unto each other after being shuffled.
so I'm manually adding each question and answer per slide. Is there a way around this?
I find myself manually doing a lot of things when I feel there may be a workaround..
Formatting question slides is very manual. Reason is that you cannot resize the individual answer containers in the Quizzing Master slides. Only the Answer area can be resized. Please, please, log a feature request to have this changed in a future release!
My work flow for long answers that are used with shuffling answers:
It is even worse for responsive projects, at least if you design with Breakpoint views, because you have to repeat that manually resizing for each breakpoint view. It is a little bit easier in CP2017 with Fluid Boxes work flow, but nevertheless... look at this article;
thank you for the feedback!
It is so tedious to do everything manually!
I was hoping i was missing something.
It's a very long process when you get to developing a test that is 100 questions log and 5 sections.
You could also duplicate a well formatted quiz slide. Please log a feature
request, this formatting issue got worse since CP6.
On Jul 20, 2017 2:17 PM, "melissar67446280" <forums_noreply@adobe.com>
