I will be utilizing Captivate 9 to redo an e-learning that because of its size took too long to load. For the new e-learning, I'd like to break the workflows into separate Captivate files & make them accessible via a Table of Contents.
Please advise the best way to accomplish this e.g. Do I publish the files separately & place them in one folder? Can I use a Captivate generated TOC or do I need to create my own TOC?
Any advice you can give as to how to simplify creation of this project would be most appreciated!
Do you use a LMS? Are those SCO's?
This particular project will be not use our LMS.
No SCO's in that case. Did you look at the Aggregator?
Hey,
You can either use Multi-SCORM packager, see here: How to package multiple SCOs using the Adobe Multi-SCORM Packager OR Aggregator (for SWF projects only), see here: How to combine multiple SWF files with aggregator
You can also link the projects as explained here: How to link Adobe Captivate projects
Let me know if this helps. Also, if there are any followup questions you have.
A Captivate Enthusiast
Multi-Scorm packager has no sense, since the OP replied that no LMS will be used.
Aggregator is only fine for SWF output.
I would personally create a 'main project' that acts as a dashboard and links to the subprojects, or choose for daisy-chaining if the sequence has to be imposed.
We had a recent requirement for a similar circumstance. The approach we took was straightforward. A "toc" module with buttons & links to other the other modules, and each module had links back to the toc module. In our case, every slide had a "return to main" menu button. if all of the modules were in the same master directory, the URL links were purely relative, meaning that the toc button links looked something like "../module_1/index.html" and the link back looked like "../main_toc/index.html"
The only part that couldn't be accomplished without some clever behind-the-scenes javascript was the ability to show a "visited" mark by modules that had been viewed in the TOC.
