0 Replies Latest reply on Jul 20, 2017 6:54 AM by juanp8875863
    Testing the real (and confusing) GPU acceleration impact on Premiere Pro
    juanp8875863 Level 1
      I found my gpu performance monitoring software was showing a very little usage (or none) when using Premiere Pro 2017 in tasks where supposedly are accelerated by the graphics card such as warp stabilizer, exporting, etc.
      I only was able to see certain peaks of activity but inmediatelly go down to 0% and searching the web and this forum I found other people are worried about this.
      Is the GPU helping?
      So I made some test.
      Here is my build:
      i7 3820 oc at 4,6ghz 4 cores 8 threads (this old boy keeps giving nice performance)
      32gb ram
      gtx 1050 ti
      os and apps in SSD
      project files, cache, renders and exports in a Samsung 960 evo m.2 disk via pcie adapter
      I did some test with and without gpu acceleration in project settings with two 17 sec clips 1080 50p and 4k 25p
      (gigabyte gpu monitoring software and GPU-z is what I use to see activity)
      *minutes
        cpu only                         mercury playback engine gpu acceleration cuda
      apply warp stabilizer
      4k        5:21,63                                                  5:19,53
      1080        2:45,00                                                  2:43,00
      render preview warp stab. applied
      4k        00:40,50                                                 0
      1080        00:48,10                                                 0
      render preview 40% slower with optical flow
      4k        03:06,61                                                  00:53,89
      1080        04:59,00                                                  01:32,55
      export to h265
      4k to 4k        02:25,10                                                   00:29,10
      1080 to 1080        01:18,53                                                   00:19,53
      Now that I see the results it is obvious that Gpu is helping (a lot) but it is not showing the expcted intense activity like the CPU does. So the GPU works in a different way or the monitoring software is not doing well.
      I´m waiting for a 1080 ti. When it arrives I´ll do some comparisons with the 1050 ti. Although I´ll be expecting some differences I´m sure the 5x times more expensive card won´t give me 5x more performance.
