• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Publish Search Settings
Explorer ,
Jul 20, 2017 Jul 20, 2017
Hello, I've gotten my responsive HTML output just about how how need it, but when I go to search, the results display the file name (no extension), not the topic name. Is there somewhere in the settings that I can tell it to display <$paratext>?
Using nonstructured FM 2017
Views
222
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
That sounds vaguely familiar - have you applied all the patches for FM2017?
Votes
Translate
Translate
Report
Report
Explorer ,
Jul 25, 2017 Jul 25, 2017
I have now, after fighting an error in the updater. Still the same filename instead of topic name.
Votes
Translate
Translate
Report
Report
Community Expert ,
Are you processing a book with a standalone TOC? If not, try that first
Votes
Translate
Translate
Report
Report
Explorer ,
I am indeed.
Votes
Translate
Translate
Report
Report
Community Expert ,
Jul 26, 2017 Jul 26, 2017
Not likely to help, but you should try renaming your prefs folder and restarting Fm to see if it clears the issue. My folder is at
C:\Users\Matt\AppData\Roaming\Adobe\FrameMaker\14
I've had incorrect menus and other oddities solved with this solution, and it's pretty painless to do.
Votes
Translate
Translate
Report
Report
Explorer ,
Jul 27, 2017 Jul 27, 2017
LATEST
Thanks but no dice. I thought I might be on to something when I noticed this dialog in General Settings was set to Default. Tried using <$paratext> but again no dice.
Votes
Translate
Translate
Report
Report
