7 Replies Latest reply on Oct 28, 2017 8:31 AM by Rick Gerard
    3D Camera Tracker Not Working
    thracker11 Level 1
      I'm having a devil of a time getting the 3D Camera Tracker to work consistently in After Effects CC 2017.  Most of the time, it doesn't work.  I have been using it on only one clip. The only way it'll work at all is to put the clip in a new comp. But, again, most of the time it doesn't work.  The camera tracker will create the tracking points and I use the target to choose at least 3 tracking points (though I've toyed with different numbers of tracking points chosen). However, when I right click to create text, most of the time the text simply stays in place instead of moving as if "stuck" to the video. Other times, it works and the text moves as if "stuck" to the video. These mixed results happen with no other settings being changed. That being said, I've also tried changing the 3D Renderer in Composition settings.  I've tried all the options.  It didn't seem to help.  Can anyone shed some light on this subject, please? Why the inconsistent results?
      Thanks in advance,
      Jorge
      AE 2017 cc 2017
      Intel i5
      6 gigs RAM
      video clip is drone footage looking down on a piece of land
        • 1. Re: 3D Camera Tracker Not Working
          To successfully use AE's camera tracker you must have very little lens distortion in the shot. This is a common problem with wide angle lenses even on professional cameras. The other common problem is that there are too many things that are moving in different directions in the shot. A hand held shot of a bunch of people walking down the sidewalk is extremely difficult to track because there is not enough fixed geometry in the shot to establish and calculate changes in parallax. A shot of a wheat field with the wheat blowing in the wind or a shot if the ocean is impossible to Camera Track because there is nothing but a horizon that is not moving.
          Another really common problem is trying to camera track a shot that is too long or makes some unexpected changes in direction. You should trim your shot to just the frames you need to actually track. For example I recently had a shot of a couple of actors walking down the street talking that ran for about 20 seconds. I had to replace a sign in a window they walked past with a new graphic. The window was inly in the shot for 4 seconds but the sign I needed to replace was only in the shot for about 3 seconds so I trimmed the shot to the just over 3 seconds, ran camera tracker, replaced the sign in my just over 3 second comp, rendered the composite, then cut the composite into the original shot. In the past I have cut one shot up into seven or eight segments and camera tracked each segment separately, then put the shot back together. This is by far the most efficient way to work.
          I hope this helps. It wold really help us point you in the right direction if we could see the shot you are having problems with.
          2 people found this helpful
          • 2. Re: 3D Camera Tracker Not Working
            thracker11 Level 1
            Thanks for the speedy answer, Rick!
            *  The video is of a parcel of land near a highway.
            *  I'm trying to use 3D Camera Tracker to insert 3D text of the name of a street on the street, itself
            * The shot is 14 seconds long.  In your experience, is this too long?
            * Really, the only movement in the shot is part of the drone on the left side of the frame and then, toward the end of the clip, some cars on a highway in the distance (to the right of the frame).
            * There are no unexpected changes of direction.
            * The shot is trimmed to exactly what I need tracked.
            It's not my shot, so I can't load it to YouTube, etc.  I wish uploading a video file from my computer was a possibility on this forum, as it is for pictures.
            In the meantime, I'll try breaking it into smaller segments to see if it will apply the tracking info to the text.
            Jorge
            • 3. Re: 3D Camera Tracker Not Working
              For something like this might be better off just using motion tracking. Track position scale and rotation by selecting a couple of relatively large detail areas on the shot that stay in the shot then apply the tracking data to a null and parent your text layer to the null.   You can then make the text layer 3-D so that it looks like it's laying down on the map.
              The camera tractor relies on parallax and a half shot from a drone has very little of that. A lot of drone cameras also have a lot of lens distortion.  I have successfully track a lot of drone footage shot from the right angle and corrected for distortion. I have also had a lot of other drone footage that just didn't work well.
              • 4. Re: 3D Camera Tracker Not Working
                Kevin-Monahan Adobe Employee
                Jorge,
                Did you try Rick's suggestion? If so, how did that work out? Let us know, or if you need more help.
                Kevin
                • 5. Re: 3D Camera Tracker Not Working
                  hr535 Level 1
                  I got something similar, my tracking is not working too.
                  I tracked my shot with camera tracker, at this point I selected "Render track points" and all the colorized points appeared .
                  But then there were no way to select 3 of them to get the target and create null + camera ...
                  Hope there is a way to solve the problem ...
                  Best,
                  Henri
                  • 6. Re: 3D Camera Tracker Not Working
                    Roei Tzoref Adobe Community Professional
                    you shouldn't do that. render track points is for the use of seeing them during preview or rendering them.
                    you should read here on how to use the tool: Tracking 3D Camera Movement in After Effects
                    • 7. Re: 3D Camera Tracker Not Working
                      hr535  wrote
                      I tracked my shot with camera tracker, at this point I selected "Render track points" and all the colorized points appeared.
                      This is user error and not a bug. When you select Render Track Points they are rendered visible when the Camera Tracker is not selected in the Effects Control Panel. You usually do not what that option turned on. You will see the track points and be able to select them only when Camera Tracker is selected and highlighted in the ECP.
                      When you select Render Track Points they are rendered visible when the Camera Tracker is not selected in the Effects Control Panel. You usually do not what that option turned on. You will see the track points and be able to select them only when Camera Tracker is selected and highlighted in the ECP. Please take some time to study up on Camera Tracker. It is not 100% accurate automatically all the time and some shots will not be accurately analyzed. Different types of shots require different settings and different analysis. Came capture footage can be difficult if not impossible to accurately track,
