10 Replies Latest reply on Jul 23, 2017 9:14 AM by Test Screen Name
    No-break space size varies
    KenWK Level 1
      I have 2 computers, both CS6 (version 8.1.0.420), both Windows 7. Both have been editing the same InDesign files for a long time, we've not noticed any differences.
      However, in one particular font one computer is "reading" the no-break space considerably larger than the other computer.
      I know between CS3 and CS6 it seemed that InDesign began using the no-break character (U00A0) directly from the font. That it, if the 00A0 glyph was in the font is started using the width of that glyph. Prior to CS6 it didn't seem to do that.
      However, both these computers are running the same version of CS6 but acting differently regarding the no-break space.
      Any ideas why?!
      Thank you,
      Ken
        • 1. Re: No-break space size varies
          amaarora Adobe Employee
          Maybe because the fonts are different....
          The Nonbreaking Space varies in width depending on point size, the justification setting, and word space settings, whereas the Nonbreaking Space (Fixed Width) character maintains the same width regardless of context.
          -Aman
          • 2. Re: No-break space size varies
            Jeff Witchel, ACI Adobe Community Professional
            Just my opinion: I would suggest not using the No Break Space at all. Why? The words on either side of the No Break Space can still hyphenate, which kind of defeats the purpose of that space.
            Instead, select the two words on either side of the space and choose No Break under the options menu of the Character panel. This No Break formatting can be saved as a Character Style making it easier to apply again and again.
            • 3. Re: No-break space size varies
              jane-e Adobe Community Professional
              Which Nonbreaking Space are you using?
              • 4. Re: No-break space size varies
                Does both documents have the same paragraph styles?
                • 5. Re: No-break space size varies
                  A necessary correction:
                  • 6. Re: No-break space size varies
                    KenWK Level 1
                    Thanks for all the input guys, MUCH appreciated! It turns out that it's even MORE complicated than any of the above, and involves both an OpenType and Type1 versions of the same font. :/
                    So, Windows has 2 registry areas that hold font info for PostScript fonts (OTF and Type1), more specifically, entries that "point" to font filenames. Various font management software only update the "Wow6432Node" registry entry, which seems to be a "legacy" entry that the Adobe apps (InDesign and Photoshop at least) do not "see," they only look at the newest registry entries. Which pretty much makes sense.
                    As a point of note: If the InDesign file being opened already has a Type1 font that is only in the legacy registry entry (the one InD doesn't "see") it will still use the font correctly. I THINK because the path of the font file is actually stored in the InD file (someone please correct me if I'm wrong).
                    At some point, on the computer that was displaying the no-break space the same size as the regular space, the Type1 font had been loaded into the registry key that InD can "see." When the OTF font was loaded on that computer InD was getting to confused because it had the OTF and some font cache stuff from the Type1 font. It was using the Type1 font metrics, apparently.
                    Which brings me to another point: InD does something different with the no-break space in OTF fonts than it does Type1 fonts. We discovered this by UNloading the OTF and putting the Type1 font files in the "C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Fonts" folder. When using an OTF font and setting a no-break space, InD appears to use the width of the no-break space glyph (00A0), but when using the Type1 font it uses the width of the regular space for no-break spaces.
                    By unloading the font everywhere and deleting the InD font cache files all machines were setting the no-break space the same size using the OTF font. WHICH was actually the WRONG size, it was larger than a regular space! We ended up changing the width of the 00A0 glyph to match the regular space and regenerating the OTF.
                    Hope this helps someone, sometime.
                    All best and thanks again,
                    Ken
                    3 people found this helpful
                    • 7. Re: No-break space size varies
                      Ken, that's some great sleuthing you did here!
                      For clarity: so both fonts contain a valid glyph for the non-breaking space? Intriguing! I'm going to check if I can replicate the different behavior you found between Type-1 and OTF, and see if I can find out more on this. As I understand it, I don't need two 'similar' fonts, just two where the widths of Space and NBSP are different - if I can't find one, I'll create some
                      • 8. Re: No-break space size varies
                        Hi [Jongware],
                        According to me, it does change with point size.  From the below illustration i have tried to show how the width of the space changes when point size is varied keeping justification constant. And how the space width changes keeping point size constant and varying justification.
                        Please correct me again if I am missing something.
                        -Aman
                        • 9. Re: No-break space size varies
                          The mentioning of "point size" is irrelevant.
                          You state one kind of space changes its width due to [...] point size and the other one does not. That is incorrect. The width of a space primarily scales along with the point size, whether it is fixed width or not (just like any visible character). Your statement can be read as "a non breaking fixed width space keeps its size no matter what the point size it is", which is wrong.
                          Your image shows something else: the width of a space (no matter what point size it is in!) is influenced by justification; i.e., changing just the point size of the (justified) space in that line will not make that space smaller or larger.
                          The only relevancy to the OP's question would be if OP applied a different font size to just the spaces in question.
                          • 10. Re: No-break space size varies
                            Maybe this detail is relevant. In the registry an app mighrt to use HKLM\Software\Something. But this is invisible to 32 bit apps. These apps try to use HKLM\Software\Something but they actually get HKLM\Software\WOW6432Node\Something. Two views of the world. So it's nothing to do with Adobe or legacy, just 32 versus 64 bit apps.
