All,
I'm new to illustrator. I'm trying to create a negative space note in between two letters. I've gotten the negative space part down, but keep hitting a road block when trying to remove the stroke in the letters where the negative space should also be.
I've succeeded once, but the line across the letters was not correct. Does anyone have suggestions?
To make an opacity mask
Open the panel Window > Transparency
Make sure the 'negative space' object at least covers the area you want to hide and give it a black fill -
as in an opacity mask: black reveals, white conceals.
Select both your letter and the negative space
Click Make Mask
with those settings
You need to expand the stroke: Object > Path > Outline stroke
Expand the text
Then use the pathfinder panel to actually subtract the expanded stroke from the letter shape
In case you want this to be editable: use an opacity mask.
You might want to check the documentation for the functions you don't know how to use.
Click Make Mask
with those settings
