5 Replies Latest reply on Jul 24, 2017 1:53 AM by Stephen_A_Marsh
    Find and replace text in Photoshop files
    jitenderbhatia
      Hi
      I have 100 similar PSD files with same word written inside it. but name of the files is diffrent
      All 100 PSD files has one word written in it. for example. word is "TestWord"
      Name if the PSD files is like
      apple.psd
      banana.psd
      orange.psd
      peas.psd
      pears.psd
      now I want to replace "TestWord" with name of the files. like
      in apple.psd file, "TestWord" will be replaced with word "Apple"
      in banana.psd file, "TestWord" will be replaced with word "banana"
      please suggest some script to achieve this
      regards
        • 1. Re: Find and replace text in Photoshop files
          c.pfaffenbichler Level 9
          // 2017, use it at your own risk;
          #target photoshop
          if (app.documents.length > 0) {
          var myDocument = activeDocument;
          var theString = "TestWord";
          var theReplacementString = myDocument.name.match(/(.*)\.[^\.]+$/)[1];
          var textLayers = collectAndChangeTextLayers(app.activeDocument, [], theString, theReplacementString);
          ////// function collect all layers //////
          function collectAndChangeTextLayers (theParent, allLayers, theString, theReplacementString) {
            if (!allLayers) {var allLayers = new Array}
            else {};
            var theNumber = theParent.layers.length - 1;
            for (var m = theNumber; m >= 0;m--) {
            var theLayer = theParent.layers[m];
          // apply the function to layersets;
            if (theLayer.typename == "ArtLayer") {
          // edit typelayers;
            if (theLayer.kind == LayerKind.TEXT) {
            while (theLayer.textItem.contents.indexOf(theString) != -1) {theLayer.textItem.contents = theLayer.textItem.contents.replace(theString, theReplacementString)};
            allLayers.push(theLayer)
            else {
            allLayers = collectAndChangeTextLayers(theLayer, allLayers, theString, theReplacementString)
          // this line includes the layer groups;
          // allLayers.push(theLayer);
            return allLayers
          (edited)
          • 2. Re: Find and replace text in Photoshop files
            jitenderbhatia Level 1
            hi c.pfaffenbichler
            one more question, assume, there is text file containing one word in each line . for example:
            apple
            banana
            orange
            pears
            peas
            I have a PSD file having multiple text layers, and only one word written in all layers, for example sample,
            so , looking for a script which take a word from txt file and replace this sample word and save the file
            I can create action for saving the file. but i need a script which can take word from the txt file one by one
            please help.
            • 3. Re: Find and replace text in Photoshop files
              hi
              can anyone help me with below query
              apple
              banana
              orange
              pears
              peas
              please help.
              • 4. Re: Find and replace text in Photoshop files
                This is an example on how to use text-files via JavaScript.
                alert (readPref ("~/Desktop/aaa.txt"));
                ////// read prefs file //////
                function readPref (thePath) {
                  if (File(thePath).exists == true) {
                    var file = File(thePath);
                    file.open("r");
                    file.encoding= 'BINARY';
                    var theText = new String;
                    for (var m = 0; m < file.length; m ++) {
                      theText = theText.concat(file.readch());
                    file.close();
                    return String(theText)
                You could use the resulting Array in a for-clause.
                • 5. Re: Find and replace text in Photoshop files
                  Stephen_A_Marsh Adobe Community Professional
                  jitenderbhatia – If you can’t write the script yourself or rely on others generosity, then you may need to find an alternative method.
                  One possibility is using Variables, otherwise known as “Data Driven Graphics”.
                  There are many forum topics, webpages, videos etc out there:
                  Creating data-driven graphics in Photoshop
                  Good luck!
