5 Replies Latest reply on Jul 21, 2017 11:07 AM by Gutterfish
    Adding a 'wave/ripple' effect to a moving sheet of paper ..?
    dmiraie Level 1
      Does anybody know what would be the best effect to add to this paper sheet (see video) to make it look a bit more lively/realistic?  (I did play around with the "Ripple" and "Wave Warp" effects, but couldn't get very convincing results.. Thnx!
        • 1. Re: Adding a 'wave/ripple' effect to a moving sheet of paper ..?
          Andrew Yoole MVP & Adobe Community Professional
          Try applying the Page Turn or CC Twister effects.  The key is subtlety with these, just a little bit of flutter on the corners can be convincing, go overboard and it just looks silly.
          If you want to get more elaborate, you can look at third party 3D deformation plugins, or Cinema 4D, but I'd stick with the basics for now if you're new to After Effects.
          • 2. Re: Adding a 'wave/ripple' effect to a moving sheet of paper ..?
            Gutterfish Adobe Community Professional
            Well I don't know if realism or "life" are the things it lacking.  Paper isn't alive & for intents and purposes it already looks like a piece of paper.  The problem is that the animation is boring.  This can be fixed using other elements and basic animation principles.
            I don't think there's much you do to the paper itself.  maybe use page turn effect to give one of the corners a little curl?
            Have it rotated a bit off absolutely straight
            I think it could slide in a little faster.  I feel like between 15 and 20 frames is the sweet spot.
            Secondary motion:  like bounce or overshoot.  Or Attach the paper to a null and scale the null up slowly starting at the papers first position keframe and finishing way past where the slide in stops so the paper contiues to scale up slowly after it slides into place.  You could add a little rotation in the same way, to the same null.
            Secondary elements:  give a background.  Maybe it's being held by a hand or sitting on music stand.  Maybe put a blurred out image of somehting musical or something abstract like floaty music notes or staffs.  You could have the background slide in few frames before the paper to create some anticipation and or offset.  The background can also have secondary movement slightly offset from the papers
            Basically....add interest.  Don't let the screen just go static keep some very subtle motion or movement going all the time.
            • 3. Re: Adding a 'wave/ripple' effect to a moving sheet of paper ..?
              Here's an example for you.  I started with a 20 frame slide on a static BG just like you have. Then added a few secondary animations
              and elements to make it more interesting.
              2 people found this helpful
              • 4. Re: Adding a 'wave/ripple' effect to a moving sheet of paper ..?
                Mike_Abbott Adobe Community Professional
                Awesome reply Mr. GF
                You are the man I am going to come to for all my future sliding-a-piece-of-a-paper-onto-screen animations!
                • 5. Re: Adding a 'wave/ripple' effect to a moving sheet of paper ..?
