• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Save Button Color After Reopen the Script
Community Beginner ,
Jul 21, 2017 Jul 21, 2017
I'm using app.settings for saving edit text, check boxes and drop down lists and it's working fine.
But I can't figure it out how to use it on colorPicker to save my color button to be the same when I reopen the script.
This is my code:
function myScript(thisObj){
     function myScript_buildUI(thisObj){
         var myPanel = (thisObj instanceof Panel) ? thisObj : new Window("palette", undefined);
function setBG(graphics, rgba){
    graphics.backgroundColor = graphics.newBrush(graphics.BrushType.SOLID_COLOR, rgba);
function hexToRgb(hex) {
    if (typeof hex === 'string') hex = parseInt(hex, 16);
    var r = (hex >> 16) & 0xFF;
    var g = (hex >> 8 ) & 0xFF;
    var b = (hex >> 0 ) & 0xFF;
    return [r/255, g/255, b/255];
function rgbToHex(rgb){
    var r = Math.round(rgb[0]*255);
    var g = Math.round(rgb[1]*255);
    var b = Math.round(rgb[2]*255);
    return b + 256 * (g + 256 * r);
    var dfltColor1 = [0.98,0.98,0.98];
    if (isNaN(newcolor1)){
      newcolor1 = dfltColor1;
var myButtonGr = myPanel.add("group{margins: 0}");
setBG(myButtonGr.graphics, newcolor1)
var myButton = myButtonGr.add("button{size: [20,20]}");
var newcolor1;
myButton.onDraw = function(){};
myButton.onClick = function(){
    var rgba = this.parent.graphics.backgroundColor.color;
    var hex = rgbToHex(rgba);
    var newHex = $.colorPicker(hex);
    if (isNaN(newHex) || newHex<0) return;
    var newRgb =  hexToRgb(newHex);
    newcolor1 = newRgb.slice(0);
    setBG(this.parent.graphics, newcolor1);
if (app.settings.haveSetting("Color1", "Check")) {
      newcolor1 = app.settings.getSetting("Color1", "Check");
myButton.onClick = function () {
    app.settings.saveSetting("Color1", "Check", newcolor1.toString());
        myPanel.layout.layout(true);
        myPanel.minimumSize = myPanel.size;
        myPanel.layout.resize();
        myPanel.onResizing = myPanel.onResize = function(){this.layout.resize()};
         return myPanel;
        var myScriptPal = myScript_buildUI (thisObj);
        if((myScriptPal != null) && (myScriptPal instanceof Window)){
            myScriptPal.center();
            myScriptPal.show();
myScript(this);
TOPICS
Scripting
Views
770
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate , Aug 10, 2017 Aug 10, 2017
When the script is launched, you need to read the init value for the variable "newcolor1" from the setting object, or assign a default value if not found, and use that color for the initial background in the ui. Then, while the script is being used, after every change by the user (that is, inside the onClick function), save changes to the prefs file.
The following should work, but it might be better to use more specific names for settings sections than "Color1", "Check", maybe something like "MyO
Votes
Translate
Translate
Advocate ,
The following should work, but it might be better to use more specific names for settings sections than "Color1", "Check", maybe something like "MyOwnScriptName", "Color1" (those settings files are shared by all scripts and also After Effects itself).
Xavier
        var newcolor1 = (function(){
            var result = [];
            var temp, i;
            // check the settings
                temp = app.settings.getSetting("Color1", "Check").split(",");
                for (i = 0; i<temp.length; i++) result = +temp;
            else{
                result = dfltColor1;
            return result;
        setBG(myButtonGr.graphics, newcolor1);
            // show the color picker
            var hex = rgbToHex(newcolor1);
            // give new value to newcolor1:
            newcolor1 = hexToRgb(newHex);
            // apply changes
            // save settings
        return myPanel;
    if ((myScriptPal != null) && (myScriptPal instanceof Window)){
        myScriptPal.show();
myScript(this);
Hope it helps
Votes
Translate
Translate
Report
Report
Thank you so much Xavier.
It works like a charm.
You're the best.
Votes
Translate
Translate
Report
Report
Advocate ,
Jun 06, 2023 Jun 06, 2023
is this app.settings.haveSettings functionality from old versions? I get an error trying the code. Im interested in the brush part. I see people using RGB colors for the brush, but that doesnt seem to work. I can only feed it color ranging from 0-1.
Votes
Translate
Translate
Report
Report
Community Expert ,
What error message are you getting? It works for me, but it's haveSetting(), not haveSettings().
Votes
Translate
Translate
Report
Report
Advocate ,
Well i tried app.settings and that already returns undefined for me.
Ps im looking on mobile at this site. So perhaos this is photisop or aftereffects only?
Votes
Translate
Translate
Report
Report
Community Expert ,
As far as I know, it's After Effects only.
Votes
Translate
Translate
Report
Report
Advocate ,
Yes, did tesy Photoshop and it shows same result; undefined
Votes
Translate
Translate
Report
Report
Advocate ,
Jun 07, 2023 Jun 07, 2023
ne question i have about the newBrush settings and using SOLID_COLOR. With photoshop and illustrator, this color needs to be build of a number 0-1 and not a RGBA color. Is this different in After Effects?
Im curious for this because ive seen custom palettes for illustrator which build a custom swatches palette. However the color swatches preview in the palette look different vs those in the app itself. Especially when the document in CMYK.
I think i need to add better CMYKtoRGB convertor so the brush color matches better in the CMYK document.
I was wondering if other users have noticed this behaviour?
CMYK document Palette - colors are mismatchingCMYK document Palette - colors are mismatchingRGB document Palette - colors are matchingRGB document Palette - colors are matchingPreview of the swatches panelPreview of the swatches panel
Votes
Translate
Translate
Report
Report
Advocate ,
LATEST
Well prehaps i should have tested before i asked. With a script from RARBG i made CMYK2RGB conversion. With that i can properly show this palette with the brush buttons having a better preview vs how it was. This script is not mine, but im trying to improve it a bit. The big mismatch between the color swatches when a document was in CMYK was bugging my OCD 😉
PS this script even recreates gradients, it does so by adding tons of small brush background in a single brush. Thats GENIUS thinking! Hats off for the original creator. Im going to contact him that i made some fixes. Now the other issue is, this is a palette and thus its stored per illustrator session. When the real swatch count changes, this script doesnt know because it lasts in memory all the time illustrator runs. Its a bit silly and outdated i think. Thats the issue palettes still have.
Here's a before and after. The custom palette with the swatches look much better. I just posted it here for other to find. I have never seen anyone post about this issue. Its pretty specific and very niche i guess
Before
before the fix - swatches in palette dont look like the real colorsbefore the fix - swatches in palette dont look like the real colors
After
After the addded CMYK2RGB - Swatches in the palette look much more alikeAfter the addded CMYK2RGB - Swatches in the palette look much more alike
Votes
Translate
Translate
Report
Report
