SO, this seems to have been asked on the forum over and over again based on the search I just did. No answers though....
How can you create a (pretty basic) filter to show only pages with > x visits? I'm particularly interested in doing this in workspace, but any help or advice would be welcome.
Its pretty annoying that such a basic thing which is asked for over and over, with posts going back 5 or 6 years is still not available in what is supposed to be a premium, enterprise level analytics product.
Also.... Report builder for Mac would be nice
Solved! Go to Solution.
I'm curious what you're looking to do with this filter, once you have it applied.
Right now, your best option is to leverage Calculated Metrics and sort by them:
Which would result in:
You could also leverage a combination of the IF and GREATER THAN functions if this is your goal. For example, if Visits are greater than 10,000, show Bounce Rate:
Does that help get you where you're looking to go?
Hey Eric,
Thanks for this.
I think the If Then Else might work for what I need. Basically, I have a calculated metric which works out a % of calls generated from each page (Calls / Visits). I want to create a report which I can order by the % column, but exclude any pages with less than say 100 visits or so.
Again, this seems like such a basic thing, while creating the If Then Else might work, it feels like a more complex solution that it should need to be. I’ll give it a try though.
Thanks again!
Simon.
Views
Total Likes
Hi Eric
Is it possible to have the irrelevant "0" results in your first picture not show up at all? Reason being, I am trying to filter a metric to export the results to a CSV file. I would rather just export a small number of relevant results than a large number which I would then have to take the extra step of manually excluding 0 values.
Views
Total Likes
Have been thinking about this for a long time as well. I went ahead and created an idea for this.
Allow items with zero value to be not shown in workspace
Hope this helps. Do add if I have missed any details or impact of having the idea implemented or not.
-Hyder
I think thats pretty much the same solution, but with some formatting added to the report to remove the 0? Its a good work around, but Adobe should really provide a way to filter by metric volume. Its a pretty simple ask really.
Views
Total Likes
