Hi there,
I've installed CS6 today, updated all the software, including the plug-ins, but I can't open up my 5D Mark IV 'CR2' RAW Files in Camera RAW. I keep getting the error message that 'Photoshop cannot open this file'. I've even tried downloading the most up-to-date version of Camera RAW separately and then rebooting, but I'm still receiving the same message. All the software is up-to-date......
In addition, I'm unable to even open JPEG or TIFFs in Camera RAW.
I kept my old version (CS3) installed just in case there was a problem with CS6 - might this be the reason Camera RAW is not responding??? CS6 seemed to have installed without any glitches - it's just Camera RAW that is unresponsive.
I'd greatly appreciate any help.
Kindest regards
Iain
Hi Jack
The Canon 5D Mk1V requires ACR version 9.7 or later
Cameras supported by Camera Raw
Unfortunately the latest version that is compatible with CS6 is ACR 9.1.1
Camera Raw plug-in and Adobe application compatibility
So you have a choice.
a. Subscribe to Photoshop CC (the Photography plan gets you Photoshop and Lightroom)
or
b.Download the free DNG convertor, convert your ACR files to DNG and open the DNGs in CS6
Digital Negative (DNG), Adobe DNG Converter | Adobe Photoshop CC
Dave
Hi Jack
or
Dave
Thanks Dave,
If I download the DNG convertor and convert my 5D Mark IV Files, I'm assuming there's no loss or reduction in file size/data?
Any idea why I can't seem to open JPEGs or TIFFs? I don't seem to be able to open Camera RAW at all?
Iain
The DNG convertor converts the RAW file to a container that can be opened in your version of ACR. It does not throw away the raw data.
There is a limitation with your particular camera and that is the "dual pixel" function. See this link for more :
Working with Canon Dual Pixel raw CR2 files in Camera Raw and Lightroom
Opening JPEGs or TIFFs would not normally involve ACR. What message do you get when you use File - Open on those files.
Dave
I should also have added - that dual pixel limitation applies even with the latest ACR versions.
Dave
Hi Dave,
I've downloaded the DNG Converter and run a conversion on a few images and that seems to have worked, so big thanks for that.
In terms of opening JPEGs and TIFFs I produce a lot of work on film and I have always wanted to bring those files into Camera RAW, but I can't seem to do this. Is there an easy way of doing this?
Cheers
Iain
Hi
Use Bridge to view the file - highlight the file then Ctrl+R to Open in Camera Raw
Dave
Thanks for your help Dave.
You're welcome
Dave
