• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Insufficient disk space?
New Here ,
Jul 21, 2017 Jul 21, 2017
I have a new computer  a laptop HP which came with low disc space? So, I a purchase a external hard drive with lots of space!  Yet when I want to download adobe premiere Pro Installer exe. software it keeps stopping and above error window come up 3 minutes into the download? Install location will not let me change default C:/ to D:/
Views
4.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
No you should not do that:
Programs belong on the C drive.
MIght have worked if the drive was an internal one.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks, someone said I could reconfigure my c:/ Drive as my d:/ Drive?
Votes
Translate
Translate
Report
Report
Engaged ,
Just FYI--You can reconfigure an install for a hard drive other than C: drive--but there are some issues with regard to some systems files. You can expect increased instability, errors and other issues. There are also issues with some plugins and application updates as well. To avoid the headaches...I would stick with C: drive as your primary install. If there isn't enough room--I would clear out enough room. Any drive connected to your computer that is full or near full can cause a lot of issues across a lot of programs and OS functionality. If you are having issues with an existing install and still getting consistent install errors..try using the Adobe Creative Cloud Cleaner Tool here: Use the Creative Cloud Cleaner Tool to solve installation problems Anyways, either way--good luck!
Votes
Translate
Translate
Report
Report
New Here ,
Ok!, thanks, I can install smaller video editing software, but none are to
my liking? I have a bigger server but it os is xp?
On Jul 21, 2017 2:44 PM, "Kristian Gabriel" <forums_noreply@adobe.com>
Votes
Translate
Translate
Report
Report
Community Expert ,
Why not just replace the internal hard drive with a larger one?
Votes
Translate
Translate
Report
Report
New Here ,
How hard would that be?, it's, a new laptop HP?
Votes
Translate
Translate
Report
Report
Community Expert ,
Jul 22, 2017 Jul 22, 2017
Or do some housecleaning on the laptop.
How large is the c drive?
Votes
Translate
Translate
Report
Report
New Here ,
Hi! Ann, This PC(C:) 27.6 GB used out of 29.1GB
My Passport (D;) 50.7 GB used out of 931GB?
Votes
Translate
Translate
Report
Report
Community Expert ,
What model?
Votes
Translate
Translate
Report
Report
New Here ,
Sorry for this info being so late, I had to work no computer?
Hp Desktop-A75E87A
Intel(R) Celeron(R)CPU N3050@1.60GHZ
2.00GM (1.86 GB usable)
Votes
Translate
Translate
Report
Report
Community Expert ,
Jul 23, 2017 Jul 23, 2017
I hate to burst your bubble but you cannot use your laptop for Premiere, even if you had the diskspace.
Way too underpowered.
Votes
Translate
Translate
Report
Report
New Here ,
Hi! I want to thank-you for that Information, I did not know that my New HP
computer could not be adequate for the $59 software? I am not that good on
computers thought that cloud based you would need such a big fast
computer? I just wanted to edit my video? other software like Filmora and
FXHit both fit on my computer but was not happy with their features one was
too dark background for editing the other you could not adjust the sound
track?
Votes
Translate
Translate
Report
Report
Community Expert ,
That is a mis conception. Software is downloaded from the cloud but installed local on your machine.
I doubt if Premiere Elements will even run on you laptop.
Votes
Translate
Translate
Report
Report
New Here ,
Sorry, your are 100% correct!, I am a senior, most computer savey younger
crowd already know this and I am sure more, when I purchased the computer I
had no need for video editing software! , have others do that will be
expensive?
No matter how old you get you are learning something new! Thanks again.
Votes
Translate
Translate
Report
Report
Community Expert ,
expensive?
It depends on:
What is expensive?
Who will do it?
What needs to be done?
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thanks, for the info!
Votes
Translate
Translate
Report
Report
Community Expert ,
Has nothing to do with being a senior (as I am too) or not.
It depends on where your interest lies.
We have a computer expert in the Hardware Forum who is well in his senior years and very knowledgeable.
Edit typo.
Votes
Translate
Translate
Report
Report
LEGEND ,
As Ann Bens stated, the latest version of Premiere Elements (the cheaper, consumer version of Premiere), Premiere Elements 15, will not run at all on your laptop because it requires 4GB or more RAM just to even work at all.
What's more, you will not be able to install even the last version of Premiere Elements that works with only 2GB of system RAM, Premiere Elements 14, because that program requires 5GB or more free disk space (don't confuse this with total disk space) on your C: drive.
Votes
Translate
Translate
Report
Report
LEGEND ,
You failed to read the minimum system requirements for Premiere Pro on a section of the product's Web site. That laptop's Celeron N3050 is barely the equivalent in performance to a low-end, 10-year-old Core 2 Duo CPU to begin with. And the latest versions of Premiere Pro require 8GB or more system RAM just to even run at all, even if your system's C: drive had sufficient space. 2GB total system RAM is woefully insufficient to run any recent version of Premiere Pro from CS5 onwards. And what's worse is that your system has absolutely no provision at all whatsoever to add more RAM: It has absolutely no SODIMM slots at all, and its 2GB of RAM is permanently soldered onto its motherboard.
And even after all that I stated, that laptop's display is only 1366 x 768 -- and the 768-pixel vertical resolution does not meet the 800-pixel minimum vertical resolution requirement to run Premiere Pro properly. And what happens there would have been that critical portions of the Premiere Pro interface, such as the "Export" and "Add to queue" buttons, become "permanently" hidden and unrecoverable on such a low-rez display because the windows cannot be resized to any smaller than the default size. Thus, even if you could run Premiere, you might be unable to perform any tasks whatsoever within Premiere due to this low-rez display.
Votes
Translate
Translate
Report
Report
Contributor ,
Well, a few reservations:
- Premiere Pro CS5 formal minimum RAM is 2GB. It may be sufficient for a few minutes dual video/audio tracks projects or similar.
- I have a laptop with a 1366X768 display and there is no problem to run all versions including 2017.1.2. The program knows to adapt.
- I have used Premiere Pro CS5 for short and simple projects on an old Core 2 Duo E7500 CPU (similar in performance to the Celeron N3050) with no problems (although it had 4GB RAM).
Votes
Translate
Translate
Report
Report
