1 Reply Latest reply on Jan 20, 2009 5:28 AM by Dan Bracuk
    Value from CFC using cfscript
    Combine Level 1
      I've got a function in a CFC that inserts a parent value into an Oracle table (see below). I want to extend the function to return the new parent ID so that I can use it to insert the child values. I'm using <cfscript> to execute the function which works fine with the data insert, but I can't quite work out how to output the new parent ID value in <cfscript>. Any help appreciated.
      Thanks in advance
      Roy.
      <cffunction name="insertApp" hint="Insert Applications" returntype="query">
      <cftry>
      <!--- Insert Values --->
      <cfquery name="qryAppInsert" username='#this.uid#' password='#this.pwd#' datasource='#this.source#'>
      INSERT INTO
      impsapp.tblAPPLICATIONS
      VALUES
      (#this.ID#, '#this.dType#', TO_DATE('#this.cDate#','dd-mon-yyyy'))
      </cfquery>
      <!--- Select current Value form DUAL --->
      <cfquery name="qryNewSeq" username='#this.uid#' password='#this.pwd#' datasource='#this.source#'>
      SELECT impsapp.Test_SEQ.currval x FROM dual
      </cfquery>
      <cfcatch type="any">
      <cfreturn "Error in Function insertApp">
      </cfcatch>
      </cftry>
      <!--- Return Query --->
      <cfreturn qryNewSeq>
      </cffunction>
      <cfscript>
      // create componet object
      comTest = createObject("component", "cfc.Test");
      // Set the properties from Form
      comTest.uid = '#myUser#';
      comTest.pwd = '#myPasswd#';
      comTest.source = '#myDS#';
      comTest.holder= #Form.eID#;
      comTest.appType = '#Form.pType#';
      comTest.recDate = '#DateFormat("#Form.dateReq#", "dd/mmm/yyyy")#';
      //Call insert finction
      apply_Card.insertApplications();
      //I need to be able to output and use the value x from the qryNewSeq above
      </cfscript>
