0 Replies Latest reply on Jul 21, 2017 10:31 AM by D.Hadjiev
    Inconsistent CPU usage on export
    D.Hadjiev
      Hello,
      I'm trying different export scenarios for an HD XDCAM EX 1080i (HQ) 25fps sequence.
      If I use the default PAL DV AVI or OP1a XDCAM EX 35mbps preset with CUDA accelerated MPE(Mercury playback engine) the CPU usage on export is 80%+ and the export is very fast.
      If I use the default OP1a SD presets with CUDA accelerated MPE the export speed is very slow and CPU usage is below 10%.
      If I use any other "custom" SD or HD AVI codec setting CPU usage on exports falls below 10% with CUDA accelerated MPE.
      CPU usage stays at below 75% with software only rendering. Export with software only MPE is a bit slower than with hardware accelerated MPE with default presets.
      Is there a particular reason for CPU usage to fall with custom settings?
      Premiere is 2017.1.2
      Media Encoder is 2017.1.2
      The system is Lenovo Thinkpad W520
      CPU: Intel Core i7 2760QM
      GPU: Quadro 2000M
      RAM: 8GB
      [Moderator note: moved to appropriate forum]
