2 Replies Latest reply on May 22, 2006 5:08 AM by Dan Bracuk
    update add to column
    JohnGree
      hi i have a number column called "man" i also have a update query which i need to add to this column
      set Man = '100'
      this changes the value to 100
      what i need is to add 100 to the number already in the column
      not sure how to do this ?
        • 1. Re: update add to column
          DJ_Jamba
          <CFSET Man = 100>
          get the value of 'man' first:
          <CFQUERY NAME="getValueofMan" DATASOURCE="#theDSN#">
          SELECT man FROM theTable WHERE id = #theUniqueID#
          </CFQUERY>
          <CFIF getValueofMan.recordcount NEQ 0>
          <CFSET Man = Man + getValueofMan.man>
          </CFIF>
          <CFQUERY NAME="updateValueofMan" DATASOURCE="#theDSN#">
          UPDATE theTable set man = #Man# WHERE id = #theUniqueID#
          </CFQUERY>
          Jam
          • 2. Re: update add to column
            Dan Bracuk Level 5
            This is the easiest way and will work as long as man is not null to start with.
            update thetable
            set man = man + 100
            where whatever
            If you want to treat nulls as zero, and your db supports this syntax, this should work
            update thetable
            set man = coalesce(man, 0) + 100
            where whatever
