3 Replies Latest reply on Jul 21, 2017 1:34 PM by williamadowling
    Is there a way to select pathItems base on stroke size and spotcolor?
    lan.mine Level 1
      Hi Everyone,
      I am a entry level scriptor and I am currently stuck on this one specific step. I am trying to have a script loop through pathItems and select a path that matches these criterias:
      • Stroke is using spotcolor name "BLACK" with No Fill
      • Stroke is size at 2pt
      I have found a script that loops through pathItems and selects paths with a specific point size, but I am having trouble add the part where it selects a path with the assign color "BLACK" on the stroke. Can anyone help me with this script?
      // script.name = selectPathsThisSize.jsx;
      // script.description = selects pathItems that have the same supplied stroke width; limited to 3 decimals;
      // script.required = a document with at least one path item;
      // script.parent = CarlosCanto // 6/5/11;
      // script.elegant = false;
      var idoc = app.activeDocument;
      var strokewidth = 2
      //prompt ("Enter Stroke Width in points of paths to be selected", 0.361, "Select Paths this size:___");
      for (i=0 ; i< idoc.pathItems.length; i++) {
                var ipath = idoc.pathItems[i];
                     if ((ipath.strokeWidth).toFixed(3) == Number(strokewidth).toFixed(3)) {
                               ipath.selected = true;
      app.redraw();
        • 1. Re: Is there a way to select pathItems base on stroke size and spotcolor?
          williamadowling Level 4
          The property you're looking for is strokeColor.spot.name. like this:
          if(ipath.strokeColor.spot.name == "BLACK")
               //do something
          and to check whether there's no fill, you need to check the filled property, like so
          if(!ipath.filled)
               //do something
          then just combine both of those in the same conditional:
          if(!ipath.filled && ipath.strokeColor.spot.name === "BLACK")
               //do something
          here's a quick snippet that's tested and working. I'm not sure why your snippet was using the toFixed() method. Since you were declaring a desired stroke width of 2pt, there should be no need to convert that to 2.00. if the strokeWidth of ipath is 2.25, then it's not equal to 2 or 2.00. Save yourself some calculations and leave out those extra methods.
          function test()
              var docRef = app.activeDocument;
              var paths = docRef.pathItems;
              var len = paths.length;
              var strokeWidth = 2;
              for(var x=0; x < len; x++)
                  var iPath = paths[x];
                  if(iPath.strokeWidth == strokeWidth && iPath.strokeColor.spot.name == "BLACK" && !iPath.filled)
                      iPath.selected = true;
          test();
          • 2. Re: Is there a way to select pathItems base on stroke size and spotcolor?
            lan.mine Level 1
            Oh wow, this is definately what I needed. Your script is very easy to understand. Thank you so much for explaining how which parts I need and how to put it together into a function. This is very helpful!
