8 Replies Latest reply on May 25, 2006 1:35 PM by flashfloozie
    add timeline action after progressive dload video plays
    flashfloozie
      I need to have something happen like goto fame (3) only after the video finishes. A listener or something? Add a script comand to the last frame of the movie?
        • 1. Re: add timeline action after progressive dload video plays
          Level 7
          on frame where your mediaDisplay resides add this code:
          stop();
          var myListener: Object = new Object();
          myListener.complete = function(eventObj: Object) {
          trace("media is Finished");
          gotoAndPlay("next1");
          myMedia.addEventListener("complete", myListener);
          //"next1" is a frame label *after* your video
          //"myMedia" is the instance name of your mediaPlayer.
          hope this helps.
          --> **Adobe Certified Expert**
          --> www.mudbubble.com
          --> www.keyframer.com
          • 2. Re: add timeline action after progressive dload video plays
            .:}x-=V!P=-x{:. Level 3
            sounds like you know your options allready
            • 3. Re: add timeline action after progressive dload video plays
              flashfloozie Level 1
              I know names only but no clue how to set up a listener, and I've tried to add AS to movie but it seems to only be for adding keypress actions. Cant get a goto frame to work
              • 4. Re: add timeline action after progressive dload video plays
                Thanks for the help. but not working for me
                Added mc named shellyvid to frame one.
                Added other content on frame 2 labeled done
                this code on frame one
                stop();
                gotoAndPlay("done");
                shellyvid.addEventListener("complete",myListener);
                tried setting mc "export for AS
                no change
                • 5. Re: add timeline action after progressive dload video   plays
                  Level 7
                  no - why are you adding a Movie Clip and giving it an instance? That code is a listener for the
                  mediaPlayer re-read my explanation - i said to add the instance to the mediaPlayer - in your
                  original post you said you wanted a gotoAndPlay after a video was done playing - so i had to assume,
                  given no specifics, that you are using a mediaPlayback component with an external FLV file. I think
                  at this point you need to explain in greater detail what your movie contains, what it is calling
                  externally (if anything) and how exactly you have it setup.
                  > stop();
                  > no change
                  • 6. Re: add timeline action after progressive dload video   plays
                    Without the mc it works fine, but I need the component in a mc because I need the timeline to continue on to fade text in and out
                    I tried to use this._parent.gotoAndPlay("done") but to no avail. Like this
                    stop();
                    this._parent.gotoAndPlay("done");
                    Really appreciate the help
                    ff
                    ps
                    Also: On the parameters for the component in flash is there a "name" and "value" I can add there to accomplish this?
                    • 7. Re: add timeline action after progressive dload video     plays
                      Level 7
                      ok - so if your media component is in a MC then you just need to target the MC then the component -
                      so give your MC an instance name also:
                      stop();
                      _level0.gotoAndPlay("done");
                      MCinstaneName.shellyvid.addEventListener("complete",myListener);
                      //_level0 is the main timeline
                      //MCinstanceName is the movie clips' instancename that contains your component.
                      > stop();
                      > ff
                      > ps
                      • 8. Re: add timeline action after progressive dload video     plays
                        Fantastic! It works perfectl. I really appreciate you taking the time to help me with this.
                        ff
                        any place I can read up on adding parameters to cue points?
