3 Replies Latest reply on May 25, 2006 9:15 AM by TLScan
    Error in a script and i can´t find it
    TLScan Level 1
      I found a very interesting Tutorial about an Archtitcural Fly-Trough at the Adobe Sites.
      As I tried make the same i got an Error in the Lingo Script that was providet with the Tutorial. I have no experience with Lingo so I can´t find the Error. Could sombody find the Error?
      I marked the Line with <<<<<<<<
      Here is the Script (just a little bit long)
      You can see the whole Tutorial here: http://www.adobe.com/devnet/director/articles/shockwave_3d/shockwave3d_ch3.pdf
      on beginSprite (me)
      -- initialize properties
      pMember = sprite(me.spriteNum).member
      pSprite = sprite(me.spriteNum)
      pMouseDown = FALSE
      pRightMouseDown = FALSE
      pCamera = sprite(me.spriteNum).camera
      pCamAnimFlag = TRUE
      pCamAnimInfo = [#initT: pCamera.transform.duplicate(), \
      #finalT: pMember.camera ("first_person").transform.duplicate(), \
      #count: 0]
      -- create the camera’s bounding sphere
      mr = pMember.newModelResource("camera_sphere",#sphere)
      mr.radius = 7.5
      pCameraSphere = pMember.newModel("camera_sphere",mr)
      -- create a light to carry with the camera
      camLight = pMember.newLight("camera_light",#point)
      camLight.color = rgb(170,170,170)
      -- make the sphere and light children of the camera
      pCamera.addChild(pCameraSphere,#preserveParent)
      pCamera.addChild(camLight,#preserveParent)
      -- register the camera for the timeMS event in order to perform the intro animation if any
      pCamera.registerScript(#timeMS,#animateCamera,me,0,50,51)
      -- register the member for regular timeMS events in order to respond to user input and resolve camera “collisions”
      pMember.registerForEvent(#timeMS,#controlCamera,me,2500,50,0)
      end beginSprite
      on mouseDown (me)
      -- update the mouse down property
      pMouseDown = TRUE
      end mouseDown
      on mouseUp (me)
      pMouseDown = FALSE
      end mouseUp
      on rightMouseDown (me)
      -- update the right mouse down property
      pRightMouseDown = TRUE
      end rightMouseDown
      on rightMouseUp (me)
      end rightMouseUp
      -- The animateCamera handler is used to animate the camera automatically over time:
      on animateCamera (me)
      -- increment the internal counter for the animation
      pCamAnimInfo.count = pCamAnimInfo.count + 1 <<<<<<I get an Errormessage in this Line!!!!!
      -- determine the interpolation percentage
      pctg = 100.0 × (pCamAnimInfo.count / 50.0)
      -- if pctg is greater than 100 end animation sequence
      if (pctg > 100) then
      pctg = 100
      pCamAnimFlag = FALSE
      end if
      -- determine the new interpolated camera transform
      t = pCamAnimInfo.initT.interpolate (pCamAnimInfo.finalT,pctg)
      -- apply that transform to the camera
      pCamera.transform = t
      end animateCamera
      on controlCamera (me)
      -- respond only if the intro camera animation is completed
      if not(pCamAnimFlag) then
      -- CONTROL THE LEFT/RIGHT ROTATION OF THE CAMERA
      -- if the shift key is *not* down then follow the mouse
      -- to adjust left right looking
      if not(the shiftDown) then
      -- check for the mouse locH wrt the sprite loc
      deltaH = the mouseH - pSprite.locH
      -- calculate rotation value to apply
      rotn = -(deltaH/165.0) * 4.0
      -- apply that rotation
      pCamera.rotate(pCamera.worldPosition, vector(0,0,1),rotn,#world)
      end if
      -- CONTROL THE FORWARD/BACKWARD MOVEMENT OF THE CAMERA
      -- if the left mouse is down then move the character forward
      if pMouseDown then
      pCamera.translate(0,0,-2.5)
      end if
      -- if the right mouse is down then move the character backward
      if pRightMouseDown then
      pCamera.translate(0,0,2.5)
      end if
      -- cast one ray fwd/bckwrd depending upon which mouse button is down
      case (TRUE) of
      -- left mouse down, cast ray forward
      (pMouseDown):
      -- cast ray
      tList = pMember.modelsUnderRay (pCamera.worldPosition,-pCamera.transform. zAxis,#detailed)
      -- if there are models in front of the camera, check for collisions
      if (tList.count) then
      me.checkForCollision(tList[1])
      end if
      -- right (control+) mouse down, cast ray backward
      (pRightMouseDown):
      -- cast ray
      tList = pMember.modelsUnderRay (pCamera.worldPosition,pCamera.transform. zAxis,#detailed)
      end if
      end case
      -- cast a ray to the left
      tList = pMember.modelsUnderRay (pCamera.worldPosition,-pCamera.transform. xAxis,#detailed)
      end if
      -- cast a ray to the right
      tList = pMember.modelsUnderRay(pCamera.worldPosition,pCamera.transform.xAxis, #detailed)
      end if
      end if
      end controlCamera
      on checkForCollision (me, thisData)
      -- grab the distance value
      dist = thisData.distance
      -- if distance is smaller than bounding radius, resolve collision
      if (dist < pCameraSphere.resource.radius) then
      -- get distance of penetration
      diff = pCameraSphere.resource.radius - dist
      -- calculate vector perpendicular to the wall’s surface to move the camera
      tVector = thisData.isectNormal * diff
      -- move the camera in order to resolve the collision
      pCamera.translate(tVector,#world)
      end if
      end checkForCollision
