Since the latest update I have to swith the page turning option every timebI open a new document. Is there a way to set single page turning for all document?
The "Continuous" page mode has always been the default view option for Acrobat Reader for iPhone and iPad. This has not changed in recent releases. Once you change the view option to "Single Page", Acrobat Reader should remember the last view option.
However, it is possible that the saved view option is lost/reset due to a defect in Acrobat Reader.
Would you please try the following steps?
Is the view option "Single Page" or reset to "Continuous"?
Is your PDF document stored locally on your iPad/iPhone or in cloud storage (e.g. Adobe Document Cloud, Dropbox, iCloud Drive, Google Drive, Microsoft OneDrive, etc.)?
Thank you for the fast reply.
In the past I only needed to change the page turning to single page one
time and all new documents would would also be set to single page. This is
no longer the case. I am also getting the "Get Started" page every day
when I first open the app. I suspect all of the defaults are resetting. I
will try deleting the app and reinstalling.
Hi winegar​,
Thank you for getting back to us.
Based on your problem description, it sounds like you have encountered the same problem.
Re: Constantly asked to sign in to Document Cloud and reg Dropbox - iOS
By the "Get Started" page, do you mean the "Welcome to Acrobat Reader" screen? The last screen shows the blue button with "Get Started" label as you mentioned.
Please let us know if uninstalling and reinstalling Acrobat Reader would solve the "reset preferences/defaults" problem for you.
Before uninstalling Acrobat Reader, we'd highly recommend making backup copies of the documents that are locally stored on your iPad/iPhone.
How to back up and restore PDF documents on iPad/iPhone using iTunes
Thank you again for your help!
Hi winegar​,
Another user with a similar problem mentioned that the problem went away after backing up PDF documents and uninstalling & reinstalling Acrobat Reader.
Re: Being signed out at random.
Would you please let us know if uninstalling & reinstalling Acrobat Reader worked for you?
Thank you.
I deleted and reinstalled the app. So far it has been working as it
should. Thank you for following up.
Thank you very much for confirming!
Hello,
Once again I am having the issue of Adobe for Ipad resetting defaults everyday upon opening. The "Getting Started" screen comes up every day and all settings are reset. Has there been any progress on this issue? Thank you.
Hi winegar​,
We just released Acrobat Reader 17.07.27 (that contains the fix for the most frequently encountered crash at startup) on August 27th.
However, because the "reset" problem occurs sporadically, we are unable to determine if the fix for the crash will resolve the "reset" problem as well.
Would you please try updating to 17.07.27 and let us know if you still experience the "reset" problem?
Sorry for the inconvenience.
Hello,
I deleted the app and downloaded it last night. I had the same issue this
morning. I am using an Ipad Pro 10.5 inch running iOS 10.3.3. Maybe this
will help you. Thank you.
On Mon, Aug 28, 2017 at 9:42 AM, MobileDeveloperCK <forums_noreply@adobe.com
