Hello, everyone.
I've been using Premiere for a while now, and never had any problems beside it eating all my CPU. However, today, I encountered a bizarre situation:
This is a screenshot of a video that I am trying to edit because its color is badly washed (everything should be rich deep gold):
And after I applied these effects:
The Program playback looks like this:
But when I actually exported the video, it still looks pale:
What is wrong, please?
Thanks to You all. But I figured that using uncompressed quicktime gives me the desirable result.
Results depend on export settings and the player you are using.
Post a screenshot of your export settings with left tab to output and with an image.
Which player?
I have viewed it in Windows Media Player and VLC, and my android phone;
The export something looks like this:
Thanks for helping.
Premiere actually does grade you-get-what-you-see in sRGB if your monitor is also calibrated sRGB. premiere will ignore any other color profiles. quicktime is not sRGB(0-255 gamma 2.2). quicktime(depending on the version), RGB values are 16-235 with various gamma styles like 1.8 or 2.4.
Furthermore, if you colorgrade in Premiere and your monitor is not sRGB, you will get incorrect grades because you are grading in the wrong native color profile. VLC can match premiere perfectly if you set its video output to OpenGL. Also, nvidia control panel needs to be set to 0-255 so that your gfx card doesn't change your RGB values in media playback.
Also,
external displays are still limited by adobe's mercury transmit protocol that is hard coded to rec. 709 so you'll need to match that too.
If you want a WYSIWYG scenario, you have to set things up properly.
That means an I/O device like the T-Tap from AJA or the Intensity from Blackmagic, and connected to that a properly calibrated TV.
