Expand my Community achievements bar.
Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Show/hide related implementation in dialog in AEM 6.3
Avatar
Level 8
Hi zeeshan/All,
Show hide dialog fields based on selection in AEM 6.3 Based on the inputs provided here, have been trying on this for quite some time.
My component dialog is like
/apps/sample/components/content/samplleone/cq:dialog/content/items/listing/items/column/items.
Under this directly[direct descendanats] I have the below
I have selection node of type granite/ui/components/foundation/form/select. which has values value1, value2 ....to value6.
Have two more nodes 'x' and 'y' of type granite/ui/components/foundation/container.
Basically on selection of value1 only, I have to show node 'x'. On selection of other values in dropdown, have to show node 'y'.
Tried various things, but no luck.
Custom js Code I tried so far as below :
(function(document, $) {
$(document).on("foundation-contentloaded", function(e) {
        showHide();
    function showHide(){
         var value = $("[name='./pagetitle']").val() ;
})(document,Granite.$);
Once, I do the above none of the container fields show up and so many errors  come up in browser console[which seems to be pointing to some OOTB js files].
Any thoughts/pointers/reference code will be really helpful.
1 Accepted Solution
Avatar
Correct answer by
Level 5
Try something as below:
We can do it using ootb classes as well. But I feel writing a clientlib is a bit cleaner and easier.
Write a clientlib with cq.authoring.dialog category and add the js as below:
<selection
jcr:primaryType="nt:unstructured"
sling:resourceType="granite/ui/components/foundation/form/select"
id="partnerSelection"
name="./partnerSelection">
</selection>
<multilogo
sling:resourceType="granite/ui/components/foundation/container"
class="logo-text-multifield"
id="multilogo">
<multitextfield
id="multitextfield">
JS:
  $(document).on('foundation-contentloaded', function(e) {
    showHide();
  $(document).on('selected.select', '#partnerSelection', function(e) {
    showHide();
  function showHide() {
    var selectedValue = $('#partnerSelection select').val();
    $(".logo-text-multifield").hide();
    if (selectedValue === 'name') {
      $("#multitextfield").show();
    } else {
      $("#multilogo").show();
})(document, Granite.$);
View solution in original post
Avatar
Level 5
It seems that above code will through Jquery error due to not found of $("[name='./pagetitle']") value of undefined name.
did you follow this article it might helpful Toggle fields based on selection in Granite UI dialogs | Adobe AEM Club
Avatar
Level 8
So far the progess is as below :
        showHide();
        var numberOfFields = $("[name='./Selection']").val(); // here I am getting the value selected in the dropdown field
        if (numberOfFields === 'value1') {
            alert('condition satisfied');
This code runs through fine, but the container nodes x and y do not appear in dialog.
Avatar
Level 8
Please ignore my comment "but the container nodes x and y do not appear in dialog." in the previous post.
All of the dialogs are appearing in front end. Based on whatever I have done so far, probably I need to show/hide the container fields in dialog[which is the requirement].
Avatar
Level 8
Further pointers/reference code would be helpful.
Avatar
Level 5
please take a look of this ootb js /libs/cq/gui/components/authoring/dialog/dropdownshowhide/clientlibs/dropdownshowhide/js/dropdownshowhide.js
below is the sample package and install it.analyse the dialog node properties and try to change accordingly.
http://adobeaemclub.com/wp-content/uploads/2016/05/text-style-component-1.0.zip
Avatar
Correct answer by
Level 5
<selection
</selection>
<multilogo
id="multilogo">
<multitextfield
JS:
    showHide();
    showHide();
    } else {
Avatar
Level 8
Hi Susheel,
Thanks a ton. It really really helped me.
