4 Replies Latest reply on May 24, 2006 6:24 AM by Newsgroup_User
    Sorting Variables & adding a number to the name
    JstMrd
      Hello,
      The Issue:
      Have input boxes on stage. Would like to compare the results to an array through a loop. I am not fully understanding how.
      Taking the existing Input Text Box Variable enter_1 (1- 14) and assigning the number to a standard variable when testing:
      enter_[x]
      enter_(x)
      [enter_+x]
      I have attached the loop code, but may not be on the right track.
      Thank You,
      D
        • 1. Sorting Variables & adding a number to the name
          .:}x-=V!P=-x{:. Level 3
          if (["enter_"+countResponse] == namesArray[countNum]) {
          nameCorrect = (nameCorrect+1);
          ["output_"+nameCorrect] = ["enter_"+countResponse];
          trace(["output_"+countResponse]);
          • 2. Re: Sorting Variables & adding a number to the name
            Level 7
            The example shown here uses the array access operator, []. It seems
            like a neat trick, but once you understand it, it's just another tool in
            your arsenal. When accessing elements in an array, use the array access
            operator as follows:
            myArray[0] // accesses the first element
            myArray[1] // access the second, etc.
            When accessing variables or properties -- in fact, any object at all --
            you may use the array access operator as follows:
            myObj["propertyName"]
            ... which is just a way of specifying this ...
            myObj.propertyName
            ... except you use a string for the property name. In dot syntax, the
            property name (aka variable, or object) is preceeded by a dot; with the
            array access operator, the property name is not preceeded by a dot, but
            encased in square brackets. Content inside the square brackets must resolve
            to a string.
            So in the original post ...
            trace(enter_[countResponse]);
            ... should be ...
            trace(this["enter" + countResponse]);
            ... because countResponse resolves to a number, which, when concatenated
            with a string, ultimately becomes a string. This won't work without the
            "this" (or some other parent object reference), because the array access
            operator accesses the property *of* an object. Without something in front
            of the brackets, ActionScript will think you're trying to create a new
            array.
            David
            stiller (at) quip (dot) net
            Dev essays: http://www.quip.net/blog/
            "Luck is the residue of good design."
            • 3. Re: Sorting Variables & adding a number to the name
              JstMrd Level 1
              Well thanks to both .:}x-=V!P=-x{:. (pronounce??) and David Stiller. You both had some insight and a great explanation from David. I now understand this better. Do you think all these books that I have barricaded myself with could actually get to the point, like this does this.
              Anyways, thanks and here is a summary of what I have gathered from both of you and one other source:
              Answer 1)
              Answer 2)
              Answer 3)
              eg.
              var reference = eval("enter_" + countResponse);
              trace(reference);
              OR
              var reference = this["enter_"+countResponse];
              trace(reference);
              • 4. Re: Sorting Variables & adding a number to the name
                Level 7
                JstMrd,
                Okay.
                > Answer 1)
                In your if() statement, the first part of your condition,
                ["enter_"+countResponse], is shorthand for an array. In affect, those
                brackets, [], are the same as using the constructor new Array(). This isn't
                what you want.
                > Answer 2)
                In this useage, those brackets, [], are performing the service of the
                array access operator. That's different. Because of the object immediately
                in front of the brackets (in this case, "this"), the brackets are resolving
                a string into an object property. The word "this" could be _root, _parent,
                or any other term that points to an object (such as an object's instance
                name).
                > Answer 3)
                > eg.
                > trace(reference);
                Sure. That would do it, too. eval() is very similar to the use of the
                array access operators in this context.
                > OR
                > trace(reference);
                Right. Those say the same thing. But you don't even have to use the
                variable.
                trace(eval("enter_" + countResponse));
                trace(["enter_" + countResponse]);
                Those are practically identical.
                David
