1 Reply Latest reply on May 23, 2006 2:52 AM by 2m
    Difference between viewing dynamic text and static text with same format
    sotoodeh Level 1
      I create a static text which contains a text, and then I create a dynamic text and assign a value to it.
      I set the same format to both of them but when I publish it; their views are different in the swf file.
      Why?
      Is it usual?
        • 1. Re: Difference between viewing dynamic text and static text with same format
          2m Level 2
          It is not unusual, as while in the ide more advanced typographical features can be applied to static text (which is mor or less converted to a graphic before publishing), in the player text rendered at runtime cannot use al of those featurers (with Player Version 8 the textrendering has greatly improved, but uses other methods than the IDE).
          You can also set different anti-alias methods for dynamic textfields (Flash 8), so even two dynamic texfields with the same text and textformat can look different.
