4 Replies Latest reply on Jul 24, 2017 10:18 PM by milmat72
    How to import 32k+/large amount of pictures in Photoshop Elements 15?
    milmat72 Level 1
      I'm trying to import whole my photo gallery which consist from over 32k photos organized in the hundreds sub-directories. If I clicked onto the main directory and start to import, the import after hours is stopped and the application doesn't respond. I'm trying a workaround where I start to import all, but manually interrupt the import after 10k+ photos. It seems to be working, but I'd expect the application should be able to do it at once and not to frozen. Thanks for the help! Milos !
        • 1. Re: How to import 32k+/large amount of pictures in Photoshop Elements 15?
          MichelBParis Adobe Community Professional & MVP
          milmat72  wrote
          You should not have that issue even with much bigger catalogs. It looks like you are facing a hardware capacity problem: RAM or disk space, or non optimized scratch disks settings.
          It would be helpful to know more about your system specs (menu Help >> System info, you can paste a copy here).
          You can import sequentially by different batches. You select a high level directory and import all its contents, including all its subfolders, then another etc.
          • 2. Re: How to import 32k+/large amount of pictures in Photoshop Elements 15?
            milmat72 Level 1
            Hi Michael,
            there is my system's information:
            Elements Organizer 15.0.0.0
            Verze jádra: 15.0 (20160905.m.97630)
            Jazyková verze: 15.0 (20160905.m.97630)
            Aktuální katalog:
            Název katalogu: Můj katalog
            Umístění katalogu: C:\ProgramData\Adobe\Elements Organizer\Catalogs\Můj katalog\
            Velikost katalogu: 68MB
            Velikost vyrovnávací paměti katalogu: 595MB
            Systém:
            Název operačního systému: Windows 10
            Verze operačního systému: 10.0
            Systémová architektura: AMD Procesor Řada:15 Model:1 Krokování:2 s MMX, SSE Integer, SSE FP, SSE2
            Vestavěná paměť: 8GB
            Volná paměť: 1,2GB
            • 3. Re: How to import 32k+/large amount of pictures in Photoshop Elements 15?
              milmat72 Level 1
              Hi Michael,
              it seems to be another issue than the large amount of the photos. The application has frozen when analyzing a video file in .mts format. Is it possible to automatically skip *.mts files? This could be video from Sony camera.
              • 4. Re: How to import 32k+/large amount of pictures in Photoshop Elements 15?
                milmat72 Level 1
                I did more investigation and I found out: Photoshop Elements 15 Can't Show .mts video files , where is recommended to install Haali Media Splitter. The media add performed without the issue after installation of it. IMHO there is a bug, which caused the application frozen when media in mts format were found. I assume that it is may be connected with the missing codec. Can Adobe to check it and repair?
