8 Replies Latest reply on Jun 28, 2008 9:35 PM by kglad
    button functions don't work
    meishak Level 1
      I've had this problem occur intermittently in AS2, and I always work around it my putting the code right in the button, but it seems that sometimes, out of the blue, one (or some) buttons will ignore button functions that are called from a frame script, while other buttons are quite happy with their frame scripts and work as they should. Yes, the instance name is correct and the function is defined within the timeline range of the button, and the syntax is correct. It's just a strange phenomenon, and I wonder if anyone knows if there is a rhyme or reason (or if there isn't)? Thank you for your help!
