Hello all,
I'm having a problem with some kind of masking, filtering, or maybe screening over my fonts/pages. It's been fairly random but it shows up in print as well as on the monitor. Interestingly enough, images set in frames (using the frame tool) also look masked/filtered/screened.
I inherited some templates but they worked perfect for the last newsletter and I haven't been able to figure out what's changed.
Here are some of the things I've checked:
- Preferences > Appearance of Black and both On Screen and Printing/Exporting are set to Display All Blacks as Rich Black and Output All Blacks as Rich Black. Overprinting of [Black] is checked.
- Display performance is on High Quality
- Created Swatches for C=0 M=0 Y=0 K=100 and C=60 M=50 Y=40 K=100
- Color Settings are set to Adobe RGB and also tried North America Web/Internet (though this is a printed newsletter)
- Kerning is set to (0), which has nothing to do with anything.
- I've tried changing the paragraph style: Normal (Web)+, No Paragraph Style, Normal
I've pretty much gone through every menu and still no joy.
Has anyone else seen anything like this happening?
Any info would be greatly appreciated!
Thanks in advance!
My Effects don't look anything like that but I'll search for that Opacity and Fill.
You can use the Flattener preview panel to quickly find out if transparency is the problem:
Set Highlight to Transparent Objects
Also double check that the text color's tint is set to 100% via the Color panel:
Try resetting your preferences.
To do so:
For Macintosh Users: With InDesign closed launch a Finder Window in column view and click on your home folder. With the Option Key pressed choose Library from the Finder Go Menu. Within the Library folder find the following two files and delete them: āAdobe InDesignā and ācom.adobe.InDesign.plistā. When InDesign is next launched it will create new preference files and the program will be restored to its defaults.
After youāve reset up the program (make sure that no document window is open) to your liking, it is a really good idea to create copies of your personalized āmintā preference files (make sure that you quit the program before copying themāthat finalizes your customization) and use them in the future to replace any corrupt versions you may need to delete.
For Windows Users: Hold down Ctrl + Alt + Shift when launching InDesign and respond affirmatively when asked if you want to reset.
Thank you! I will definitely give that a try and set up the preferences, but it will need to wait until I after I get this newsletter out.
Thanks again for the quick reply!
Another thing you could check -- in the Effects panel, is the fill set to Normal 100% and is the Text set to Normal 100% and the overall Opacity in the upper right corner set to 100%.
Hi Barbara,
Thank you,
-naomi
You can find Effects under Window > Effects, or Object > Effects, and you'll see a list of effects. If your effects panel doesn't look like mine, your selected object probably has different settings than mind.
Got it! I was looking in the wrong place. It appears to be correct.
I'll try messing with the numbers and see what I can get out of it.
Thank you
Hey Rob,
Flattener! That's a really handy feature!
I didn't know it was there. Guess I really should RTFM.
Also, thank you for step-by-step. I'm still new to this so it take me a while to get around.
Thanks again,
