• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
PS CC issues....
Community Beginner ,
Jul 24, 2017 Jul 24, 2017
Hello. I recently switched from CS6 to CC, and I am having an issue grabbing and moving objects in PS. Allow me to explain.
I take volunteer to take photos for our local shelter. I have a specific watermark that I use on these photos, made up of 7-8 different layers. Even with all the layers selected, I can't move the watermark around the image. When I transform it to resize, it only seems grab two of the layers, even though all are selected.
I am running an up-top-date Windows 10 PC. Hopefully one day I'll be on Mac...lol.
Any advice on how to fix this or direction towards what may be causing it would be greatly appreciated.
Thanks.
Views
291
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jul 24, 2017 Jul 24, 2017
One note: there was a default change between CS6 and CC: when you have the Move tool selected, Photoshop CC defaults to Auto-Select Layer on. It's been there for years but defaulted to off. Try unchecking it and PS will move things like it used to.
Votes
Translate
Translate
Adobe
Community Expert ,
I would suggest a different approach.  Create your watermark as a large document. A Canvas size that is many pixel wide and high. Use as many layers as you want and save it as a PSD file you can make modification in the future.  However also save is as a large png file with a transparent background.  Use this png file to watermark your images.  The PNG will not be a very large files and it can be placed into your image documents and be sized and position via the place transform for the image.   A single smart object layer the can repositioned and resized.  All your watermark's pixels are in the object it will always resize well.   I have posted a script that you can use to automate that process.  You can even record using the script in an action and add a layer style to the layer.  The action can be batch. The Watermark will be sized for the document for which it is place into.
Here is the script change line 3 through 6 to customize it for your use.
#target photoshop;
app.bringToFront();
var logoFile = "~/Desktop/JJMack.png"; // Watermark file should be large for resize down works better than up
var LogoSize = 10; // percent of document height to resize Watermark to
var LogoMargin = 1;   // percent of Document height the Watermark should have as a margin
var BottomLetf = false; // false = Bottom Right true Bottom Left
placeWatermark(logoFile, LogoSize, LogoMargin);    // Place Watermark  into the bottom of the document
function placeWatermark(Image,Size,Margin){
   if(!documents.length) return;   // if no document return
   try{
      var doc = app.activeDocument; // set Doc object to active document
      app.displayDialogs = DialogModes.NO; // Dialog off
      var strtRulerUnits = app.preferences.rulerUnits; // Save Users ruler units
      var strtTypeUnits = app.preferences.typeUnits; // Save Users Type units
      app.preferences.rulerUnits = Units.PIXELS; // work with pixels
      app.preferences.typeUnits = TypeUnits.PIXELS; // work with pixels
      var fileObj = new File(Image);                 // the passed file
      if(!fileObj.exists){   // If file does not exits tell user
         alert(fileObj.name  + " does not exist!");
         return;
      placeFile(fileObj); // Place in file the Watermark png file
      activeDocument.activeLayer.resize(100 ,100,AnchorPosition.MIDDLECENTER); // Insure Place did not scale layer
      var SB = activeDocument.activeLayer.bounds; // get layers bounds
      var layerHeight = SB[3] - SB[1]; // get layers height
      var resizePercent = (100/layerHeight)*(Size/100*doc.height.value); // Percent to resize by
      activeDocument.activeLayer.resize(resizePercent ,resizePercent,AnchorPosition.MIDDLECENTER);  // Resize width and height by percentage
      SB = activeDocument.activeLayer.bounds; // get resized layers bounds
      activeDocument.activeLayer.translate(-SB[0].value,-SB[1].value); // Move resized layer to top left canvas corner
      var LayerWidth = (SB[2].value - SB[0].value);
      var LayerHeight = (SB[3].value - SB[1].value);
      marginSize = Margin/100*doc.height.value; // Margin size
      // move resized watermark into the document lower right corner with some margin or lower left
      if  ( BottomLetf) {activeDocument.activeLayer.translate(marginSize,( doc.height.value -marginSize - LayerHeight));}
      else {activeDocument.activeLayer.translate((doc.width.value -marginSize - LayerWidth),( doc.height.value -marginSize - LayerHeight));}
catch(e) { alert(e + ': on line ' + e.line); } // inform user of error
finally{
   app.preferences.rulerUnits = strtRulerUnits; // Restore user ruler units
   app.preferences.typeUnits = strtTypeUnits; // Restore user type units
function placeFile(placeFile) {
    var desc21 = new ActionDescriptor();
    desc21.putPath( charIDToTypeID('null'), new File(placeFile) );
    desc21.putEnumerated( charIDToTypeID('FTcs'), charIDToTypeID('QCSt'), charIDToTypeID('Qcsa') );
    var desc22 = new ActionDescriptor();
    desc22.putUnitDouble( charIDToTypeID('Hrzn'), charIDToTypeID('#Pxl'), 0.000000 );
    desc22.putUnitDouble( charIDToTypeID('Vrtc'), charIDToTypeID('#Pxl'), 0.000000 );
    desc21.putObject( charIDToTypeID('Ofst'), charIDToTypeID('Ofst'), desc22 );
    executeAction( charIDToTypeID('Plc '), desc21, DialogModes.NO );
JJMack
Votes
Translate
Translate
Report
Report
Jul 25, 2017 Jul 25, 2017
I would love to use the watermark like that, except I have to change the name in it to match the animal's name every time. 😕
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
OMG that worked! I feel so stupid now! LOL! Thank you so much BarbBinder!
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Don't! That little change caught a lot of people off guard. Glad things are working for you again.
Votes
Translate
Translate
Report
Report
Community Expert ,
Also look to see if any of the layers are locked or linked to layers outside the layers you want to select.  Try selecting the layers and making it a Smart Object.  Then drag the Smart Object to the Library panel.  The watermark will then be available from the Library for all projects going forward.  I love CC Libraries for that reason.
Votes
Translate
Translate
Report
Report
I will try making it a smart object. Thank you.
Votes
Translate
Translate
Report
Report
