6 Replies Latest reply on Jul 26, 2017 2:34 AM by Antony Mooe
    Find and place images from subfolders
    Antony Mooe
      Hello,
      I have an Indesign file with the name of the images I want to place:
      Each images has it's folder and they're in a top folder named "fotos".
      The structure:
      fotos / 10 - description / image1
      fotos / 20 - description / image2
      fotos / 30 - description / image2
      fotos / etc………
      Here is the code I'm using:
      It finds the subfolders and the images files, but don't place them into Indesign.
      if(app.documents.length != 0)
      var subf = Folder ("/Users/iMac/Desktop/fotos/");
      var sf = subf.getFiles(onlyFolders);
      var s = "";
      for (var n = 0; n < sf.length; n++) {
        s += sf[n].name + "\r";
      alert(s);
      function onlyFolders(subf) {
        if (subf.name == "File") {
          return false;
        } else {
          return true;
          if(subf != null){
              // reset the Find/Change dialog
              app.findGrepPreferences = app.changeGrepPreferences = null;
              // formulate a grep search string
              app.findGrepPreferences.findWhat = '@.+?@';
              // find all occurrence, last one first
              f = app.activeDocument.findGrep (true);
              for (i = 0; i < f.length; i++){
                  // construct file name
                  name = f[i].contents.replace (/@/g, '');
                  // place the image
                  var placedObjects = f[i].insertionPoints[0].place (File (sf +  '/'+ name+'/'));
          // delete all @??@ codes
          app.activeDocument.changeGrep();
      else{
         alert('Please open a document and try again.');
      Here is the error from ExtendScript Toolkit:
      Can I get help from you guys?!
      Thank you.
        • 1. Re: Find and place images from subfolders
          Loic.Aigon Adobe Community Professional
          Your biggest mistake is that you are using your reference to the array of files your retrieve from the folder user selection instead of the folder itself.
          //This is an array of files objects
          //sf isn't the folder object !
          //subf is
          • 2. Re: Find and place images from subfolders
            Antony Mooe Level 1
            Hello,
            Thank you for your reply.
            I changed the code to:
            var s = "";
            alert(s);
                return false;
              } else {
                return true;
                if(subf != null){
                        // place the image
                        var placedObjects = f[i].insertionPoints[0].place (File (subf +  '/'+ name+'/'));
            else{
            But it returns to the top folder and don't search in the subfolders.
            Do you know how can fix the code?
            Thank you.
            • 3. Re: Find and place images from subfolders
              The problem is that getFiles won't look at subfolders (unless I am wrong). You need a recursive function.
              A possible approach:
              var lib = {
              getFiles : function ( fo, aExtensions, bRecursive, aFiles, includeFolder )
              var exts = aExtensions? aExtensions.join("|") : ".+" ;
              var pattern = new RegExp ( "\\."+exts+"$", "g" );
              var files = aFiles? aFiles : [];
              var filterFunction = function(file)
              return pattern.test ( file.name );
              if ( bRecursive )
              var foFiles = fo.getFiles();
              while (  f = foFiles.shift() )
              if ( f instanceof Folder )
              if (includeFolder===true) files[ files.length ] = f;
              this.getFiles ( f, aExtensions, true, files );
              if ( f  instanceof File && pattern.test ( f.name ) && f.name!=".DS_Store" )
              return files;
              else
              return fo.getFiles ( filterFunction );
              getFilesDB:function(arrFiles){
              var db = {}, n = arrFiles.length, aFile;
              while ( n-- ) {
              aFile = arrFiles[n];
              db[decodeURI(aFile.name)] = aFile;
              return db;
              replaceFiles:function ( doc, db ){
              var fgp = app.findGrepPreferences.properties,
              found = [],
              text,
              n = 0,
              fileName = "",
              file;
              app.findGrepPreferences.properties = {
              findWhat:"@.+@",
              found = doc.findGrep();
              n = found.length;
              while ( n-- ) {
              text = found[n];
              tf = text.parentTextFrames.length ? text.parentTextFrames[0] : text.parentStory.textContainers[0];
              fileName = text.contents.replace(/@/g, "" );
              file = db[fileName];
              if ( file ) {
              tf .contents = "";
              tf.contentType = ContentType.GRAPHIC_TYPE;
              tf.place ( file );
              tf.fit ( FitOptions.FILL_PROPORTIONALLY );
              tf.fit ( FitOptions.CENTER_CONTENT );
              var main = function(paragraph) {
              var doc = app.properties.activeDocument,
              fo, files, db;
              if ( !doc ) return;
              fo = Folder.selectDialog("Please choose the parent folder" );
              if ( !fo ) return;
              files = lib.getFiles ( fo, ["jpe?g"], true);
              if  (!files.length) {
              alert("no files returned!");
              return;
              db = lib.getFilesDB ( files );
              lib.replaceFiles ( doc, db );
              var u;
              app.doScript ( "main(app.activeDocument.stories[0].paragraphs[-1])",u,u,UndoModes.ENTIRE_SCRIPT, "The Script" );
              • 4. Re: Find and place images from subfolders
                Antony Mooe Level 1
                Man,
                you made my day!!!!
                Thank you so much!!
                Cheers!
                • 5. Re: Find and place images from subfolders
                  Be aware it might not be bulletproof. What if several images are equally named ? Actually script "overrides" file references so the latest found file will prior when placed (I only one "1.jpg" file will be placed even if several found).
                  • 6. Re: Find and place images from subfolders
                    Antony Mooe Level 1
                    I will keep that in mind.
                    It works perfectly for what I need.
                    Thank you again!
