2 Replies Latest reply on Jul 24, 2017 6:00 PM by grufh
    Command H not working to Minimize.
      I use the command H quite often to minimize Lightroom. It stopped working and I can't figure out what I have done to cause this. I uninstalled Lightroom completely and the problem went away but now it is happening again.
      Thanks in advance
        • 1. Re: Command H not working to Minimize.
          Conrad C Adobe Community Professional & MVP
          Command-H usually works, but it look like there are still times when it might not work. I tried Command-H in Lightroom a minute ago and it didn't work. I switched the Screen Mode (Window > Screen Mode) using the Shift-F shortcut, and then Command-H started working again. So changing the Screen Mode is something to try.
          By the way, Command-H doesn't minimize, it hides. If you look at the menus in Lightroom, Command-H is the shortcut for Lightroom > Hide Lightroom (H = Hide). The shortcut for Window > Minimize is Command-M (M = Minimize), which shrinks the window to a minimized Dock icon. Command-H doesn't do that, it just hide the application entirely. Both of those shortcuts are Mac standard and are consistent with most Mac programs.
          • 2. Re: Command H not working to Minimize.
            grufh Level 1
            Thanks for the feedback. I should of saw hide. My mistake. I tried what you suggested with no luck.
