Hello! I performed screen recording using video demo mode of adobe captivate. I selected the area (in the red box) which I wanted to record but unfortunately when I saw the video after recording , it was not the complete area of video and only I could see merely 1/2 or 1/4th of the total red area only.
Did you change display setting before recording?
Are you on Win10 perhaps? For Video Demo or for software simulation recording you have to check the Display %. It needs to be at 100% and on most screens Win10 will have increased that percentage, resulting in what you see after recording: only part of the screen is captured. Example: on Surface Pro 4 which I use at this moment, the default display % by Win10 is 200%, because it is a small retina screen.
I am using windows 10 and display is set at 100%.
Sorry to insist, but are you sure that Display setting is at 100%? Which screen resolution do you have, because up till now I never did see any screen where Win10 keeps Display at 100%. For normal screens it will be 125% or 150%, for retina screens even higher to make text and icons readable. My OS on this system is in Dutch, maybe you could check this
see this is happening . only limited part of video , merely 1/4th.. red box is incomplete and as told by you I have set display settings to 100%, earlier it was 125%. what to do?
I tried to record again after changing display settings and now I can see the complete recording area. Thanks a lot
