4 Replies Latest reply on Jul 26, 2017 2:35 AM by DBLjan
    Resize by value with Applescript?
    DBLjan Level 2
      Hello Scripters,
      i need a tiny bit of help to finish the last bit of a quick-and-dirty.
      tell application "Adobe InDesign CC 2017"
      set mySel to selection
      set myitem to item 1 of mySel
      resize myitem …
      • I need my selected item (a picture frame) be exactly 9 mm (milimeters) in heigth, width scaling proportional, using the anchor upper left.
      Thanks in advance!
        • 1. Re: Resize by value with Applescript?
          Loic.Aigon Adobe Community Professional
          You can use resize or transform with a simple math. However that will not work nicely if item is rotated or skewed or both.
          Dealing with geometry inside indesign is actually a science topic by itself…
            set sel to selection
            if (count of items in sel) = 0 then
            display dialog "You need one item to be selected"
            else
            set doc to active document
            set sel to item 1 of sel
            set vb to visible bounds of sel
            set uncertainHeight to ((item 3 of vb) - (item 1 of vb))
            set ratio to 9 / uncertainHeight
            --Using matrix
            set myTransformationMatrix to make transformation matrix with properties {horizontal scale factor:ratio, vertical scale factor:ratio}
            tell sel to transform in pasteboard coordinates from center anchor with matrix myTransformationMatrix
            --OR using resize
            --tell sel to resize in pasteboard coordinates from center anchor by multiplying current dimensions by values {ratio, ratio}
            end if
          end tell
          • 2. Re: Resize by value with Applescript?
            DBLjan Level 2
            Good job Loic.Aigon !
            And I never was close to that code you delivered . Also I didnt know about uncertainHeight, would come in handy in future.
            Have a nice day!
            • 3. Re: Resize by value with Applescript?
              Once again, uncertainHeight stands for what it means i.e. a possible value for the height. If the item is rotated or skewed or both that will throw a wrong value. Normally it would imply dealing with internal object geometry for stronger results.
              • 4. Re: Resize by value with Applescript?
                DBLjan Level 2
                Thanks for the warning, I'll be careful with my script. But since its for a logo exchange routine, nothing will be skewed or rotated *phew*.
