11 Replies Latest reply on May 22, 2009 5:04 PM by tzeng
    All kinds of problems on a Mac
    dssolveinthelove
      It wasn't so long ago that AIR was working fine on my Mac with Leopard 10.5.3. Now whenever I try and run an app, I get "This application requires a version of Adobe AIR which is no longer supported." I thought it was isolated to the app I was trying to run, but it was for every AIR app I tried. So I thought maybe my AIR runtime wasn't up to date. I go to the download page to get the most recent version and try running it, but then I get "An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator." But, I am the administrator. So I tried running the uninstaller, and I get the same error about not being allowed by the admin. Here's what I get in Console:
      6/29/08 2:30:57 PM com.apple.launchd[110] ([0x0-0x3e03e].com.adobe.air.Installer[382]) Exited with exit code: 5
      So, you can see the kinda mess I'm in. I can't even uninstall. I tried repairing permissions, but no change. Any ideas?
        • 1. Re: All kinds of problems on a Mac
          Oliver Goldman Adobe Employee
          Please enable installer logging and capture a log file, either of the failing install or uninstall. It should provide additional detail as to what is going wrong.
          • 2. Re: All kinds of problems on a Mac
            dssolveinthelove Level 1
            I didn't know how to do that originally, otherwise I would have. But I did a search and found out how. Here's the log.
            quote:
            Performing runtime install
            UI SWF load is complete
            UI initialized
            starting user confirmation
            runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception ArgumentError: Error #2007" errorID=2007]
            begin quitting
            error in stateQuitting: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception ArgumentError: Error #2007" errorID=2007]
            • 3. Re: All kinds of problems on a Mac
              Please try forcing an uninstall using the AIR 1.1 installer that you downloaded. This can be done by running it via the Terminal and passing the "-uninstall" flag, like so:
              /Volumes/Adobe\ AIR/Adobe\ AIR\ Installer/Contents/MacOS/Adobe\ AIR\ Installer -uninstall
              • 4. Re: All kinds of problems on a Mac
                Sorry, I was out of the country for a while and didn't have access to my computer to try this out. I just did now and got this in Terminal:
                quote:
                Uninstalling Adobe AIR (all versions)
                failed (consult log)
                And here's the log:
                UI initialized
                begin quitting
                rivate/var/folders/Gb/GbJqrMJ7EqG+8+bZzM2dcE+++TM/TemporaryItems/FlashTmp0/file1
                Rollback due to error complete
                error during install: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2038" errorID=2038]
                runtime install entering error state: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2038" errorID=2038]
                begin quitting
                • 5. Re: All kinds of problems on a Mac
                  Sorry to seem impatient, but any more possible fixes? It's pretty annoying that I can't even uninstall it, let alone get it to work. Thanks for all your help so far.
                  • 6. Re: All kinds of problems on a Mac
                    Apologies for the delay.
                    If the forced uninstall failed then your machine is definitely in a bad state. Please try a manual uninstall by deleting /Library/Frameworks/Adobe AIR.framework. Then try installing AIR 1.1 one more time.
                    • 7. Re: All kinds of problems on a Mac
                      That was easy enough. Problem solved. Thanks!
                      • 8. Re: All kinds of problems on a Mac
                        junglerolf Level 1
                        hello, can anyone help?! as i did follow tips on this forum entry but it still does not work!
                        i have Mac OS X 10.57
                        i downloaded latest Air 1.51
                        i uninstalled Air
                        cleared the trash
                        i do not use Virus app
                        i trashed Air prefs + App Support
                        i restarted with Safe Boot
                        i reinstalled Air
                        your tips did not work, until i trashed the prefs/app support
                        this solved the Air install error: installation may not be allowed by your admin (though i am the admin & the password was accepted!)
                        this also solved error: the app requires an update to Adobe Air but downloading that update was not successful
                        i still get error msg:
                        This app requires an update to Adobe Air that is not available for your system!
                        is Air now not compatible with OS X 10.57 that came out last week?
                        thanks for any tips,
                        rolf
                        • 9. Re: All kinds of problems on a Mac
                          tzeng Adobe Employee
                          Could you generate and post the application installation log?
                          To generate the log file, create a .airappinstall.log file on your home dir.
                          It looks like it has to do with the name space of your AIR app.
                          • 10. Re: All kinds of problems on a Mac
                            junglerolf Level 1
                            1st, thx so much for your time! ; )
                            i don't know how to do that log thing.
                            meanwhile, it worked.
                            secret: uninstalling Air & air apps, restarting etc. does not work. one has to reinstall Air in Safe Mode.
                            then reinstall Air + download latest versions of air apps, as OSX 10.57 just came out. latest air app versions finally worked.
                            but what do you mean by "name space of air app"? i never renamed apps...
                            thanks so much again
                            • 11. Re: All kinds of problems on a Mac
                              Thanks for letting us know it is working now.
                              Name space is a string inside the application descriptro file. It indicates the minimun version of AIR the application requires.
