I am currently working on an interactive PDF catalog in InDesign CC and I was wondering if it was possible to add a "page stop" to certain pages so that the reader cannot scroll/swipe past said page. There is a table of contents consisting of various categories and each category is a hyperlink button. After the reader clicks a button and is directed to a certain category, I want them to be able to scroll/swipe within that category but I want the last page of each category to stop scrolling/swiping. I want the reader to use the hyperlink buttons (Home button) to navigate if possible to create the feel of an app interface. If somebody has the answer to this or can lead me in the right direction it would be much appreciated!
That is not possible when exporting a single InDesign file to pdf.
Maybe creating hyperlinks to multiple pdf help.. where in your toc has buttons with hyperlinks to each separate pdf. At the end of the pdf there is again a button that takes them back to the original pdf. This would then require total pdfs to be number of categories plus one pdf for the toc. But again this is a little complicated and messy
Within a single pdf i think it is impossible unless you try to employ some hacks like sett
...Copy link to clipboard
If it's possible it wouldn't be done through InDesign. Check in the Acrobat forum but be advised that even if there is a method to do this, many third party PDF readers will not honor it.
Within a single pdf i think it is impossible unless you try to employ some hacks like setting up buttons or changing view properties. ( lots of auch ideas are easily seen when you google )
-Aman
Thank you for replying. Yes, I had considered the option of hyperlinking to multiple PDFs but I didn't want to over-complicate things. It seems like as of right now, this seems to be the only option.
