Premiere Pro CS6 won't start - After the opening splash screen, it just keeps showing that start up splash page for as long as you leave it. My laptop is the following specs: MacBook Pro 17-inch, Late 2011, Processor 2.5 GHz Intel Core i7, Memory 6 GB 1333 MHz DDR3, Graphics AMD Radeon HD 6770M 1024 MB, Serial Number C02HP01EDW48, Software Mac OS X Lion 10.7.5 (11G63)
I would be grateful if i get refined feedback. Thank you
Thank you.
I had it fixed already.
All i did was to move the importerQuicktimebundle and ExporterQuicktimeBundle to the desktop.
So i tried opening Premiere pro and it opened but i observed when i was about importing any file it wouldn't import or even export a movie.
So i returned it to the original folder and it worked....my premiere pro has been fine.
Thank you for your help.
Have you tried running the app as Admin, or doing a clean reinstall?
Hi ReaganO,
I am sorry that you are not able to use Premiere Pro on your MacBook.
I would suggest you to try these steps:
Location 1: In the box type ~/Library/Application Support.
Location 2: In the box type ~/Library/Preferences.
Location 3: Documents folder.
In all the locations, rename the 'Adobe' folders to 'OldAdobe'
Launch Premiere, accept the License Agreement and see if it works.
Note: You will lose your customized workspaces and keyboard shortcuts.
Kulpreet Singh
You can also follow the troubleshooting steps from this link: After Effects or Premiere Pro crashes after starting
-Kulpreet Singh
Thank you.
Thanks for confirming, ReaganO.
I am glad that you are back on track.
-Kulpreet Singh
