1 Reply Latest reply on Jul 26, 2017 11:42 AM by davescm
    Diffuse Texture Issue
    ActiveGamerz
      Hey! I'm sorta new to the 3D scene (only previously using Maxon), and I need to apply a logo to one of Felix's pre-made models. I am using the square bottle model.
      I need to place my logo onto the diffuse map, but where? I understand that the two rectangular maps are for the sides, and I put the logo into the diffuse map, and it does not apply.
      Here is my current setup.
      I tried putting the logo where the two blue boxes are, and they didn't work. (btw the blue drawings are just for show)
        • 1. Re: Diffuse Texture Issue
          davescm Adobe Community Professional
          Hi
          I can't see your 3D panel - but it looks like you have added a glass texture which will have a very low opacity. If you place a label on top of the diffuse texture you will also need to create an opacity map so that the label area is not also transparent.
          Diffuse and opacity map :
          If you do that  - then it should work correctly
          Hope that helps
          Dave
