Hi Captivate friends...
Much frustration can you help...
When I create a responsive project using the default 1024 x 627 screen resolution the responsiveness aspect works very well and is absolutely fit for purpose.
Only problem is that this is the biggest the output screen appears, so on a screen with resolution above the default values, the output project appears centralised towards the top of the browser and only fills about 75% of the screen.
Earlier today I tried to build the project to the maximum resolution of my screen at work, 1920 x 1080, I did exactly the same with all the wrap settings etc in all fluid boxes but on project output the project completely lost all responsive behaviour...
I may have read somewhere that responsive projects only output to the maximum relative project pixel size, compared to a static project that outputs to a Pixel % value thus filling the relevant browser.
I wonder if the default setting 1024 x 627 is where I should be focusing my efforts and if the issues are with the settings on the LMS Captivate which is a Moodle based system provided by Learning Pool.
I look forward to any responses, resolutions, and I will be liaising with the LMS provider tomorrow (Wednesday).
Russell
Have something to add?
