Heloo,
I am using Captivate 7 and setting is progressive downloading video.
I want the learner click on the Continue button after watching the video.
Can I disable the “Continue” button until learner has watched the video. Otherwise learner can skip the video at all and obtain credit without click the link video.
Thanks.
Your help will be highly appreciated.
You inserted ab event video, which plays totally independent from Captivate. I cannot help you for several reasons: do not have CP7 anymore, it should be done with JavaScript but CP7 doesn't have the common JS API that appeared with CP8. I hope someone else will help you but would recoommend to use multisyncrhonized video. Then you'll be able to make the Continue button appear after the end of the video timeline, which will be the easiest way to accomplish your goal.
