Using an AJA IoXt driver 12.5.1 with a client monitor on a mac pro 2013 with 32 GB of ram. Randomly, the record side will start flickering, stuttering, and playing random frames and the external monitor will turn green. Shutting down the cpu and the aja box fixes the issue for a while. Any ideas?
Bump
BUMP
Have you contacted AJA? In my experience, their customer support is first rate.
MtD
Aja says the issue is an Adobe issue since it glitches out on the record side and then is followed on the client monitor.
I connect to the client monitor via an AJA T-Tap, currently using AJA control panel v13.0, on one system and an AJA IO Express on another and do not/have not seen this issue. One system is an iMac the other a MacBook Pro.
Have you tried the v13 software drivers?
What is your renderer set to? {File > Project Settings > General > Renderer}
What is your Mac OS?
MtD
OS is 10.11.6. I plan on updating to version the v13 driver today. The renderer is set to the default of OPENCL. If the v13 driver doesn't help, I am gonna set it to software only.
That would be a good test to see if it is a gpu issue.
Also, Aja archives earlier versions of the software drivers so if this problem arose with 12.5 you could try an earlier one.
MtD
So the V13 didn't help. Trying to change the playback Renderer to Software.
Process: Adobe Premiere Pro CC 2017 [477]
Path: /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/MacOS/Adobe Premiere Pro CC 2017
Identifier: com.adobe.PremierePro.CC11
Version: 11.1.2 (11.1.2)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe Premiere Pro CC 2017 [477]
User ID: 503
Date/Time: 2017-07-31 12:44:39.205 -0700
OS Version: Mac OS X 10.11.6 (15G31)
Report Version: 11
Anonymous UUID: 39A11AF7-BAFF-7F8C-59E0-E68C066C08AB
Time Awake Since Boot: 7400 seconds
System Integrity Protection: enabled
Crashed Thread: 11 Dispatch queue: com.apple.audio.CADispatchQueue.SerialQueue
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
Pure virtual function called!
abort() called
Thread 0:: Dispatch queue: com.apple.main-thread
0 ??? 0x0000000000000016 0 + 22
1 libsystem_platform.dylib 0x00007fff901bc52a _sigtramp + 26
2 dyld 0x00007fff61125b0f ImageLoader::markedUsedRecursive(std::__1::vector<ImageLoader::DynamicReference, std::__1::allocator<ImageLoader::DynamicReference> > const&) + 131
3 com.adobe.GPUFoundation.framework 0x000000010cebd53d (anonymous namespace)::RedInfo<(anonymous namespace)::ForCl>::ClearApi() + 445
4 com.adobe.GPUFoundation.framework 0x000000010cebae6e (anonymous namespace)::RedInfo<(anonymous namespace)::ForCl>::~RedInfo() + 30
5 com.adobe.GPUFoundation.framework 0x000000010cebb33f (anonymous namespace)::RedInfo<(anonymous namespace)::ForCl>::~RedInfo() + 15
6 com.adobe.GPUFoundation.framework 0x000000010cec3343 __cxx_global_array_dtor29 + 227
7 libsystem_c.dylib 0x00007fff8b2b2463 __cxa_finalize_ranges + 345
8 libsystem_c.dylib 0x00007fff8b2b2767 exit + 55
9 libdyld.dylib 0x00007fff9e0ed5b4 start + 8
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff96f92efa kevent_qos + 10
1 libdispatch.dylib 0x00007fff89cf0165 _dispatch_mgr_invoke + 216
2 libdispatch.dylib 0x00007fff89cefdcd _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x00007fff96f92eca kevent + 10
1 com.adobe.dvatransport.framework 0x0000000101f87095 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 261
2 com.adobe.dvatransport.framework 0x0000000101f86ccc boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 364
3 com.adobe.dvatransport.framework 0x0000000101f86928 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 184
4 com.adobe.dvatransport.framework 0x0000000101f7b862 SkyConnectionEnv::MainLoop() + 162
5 com.adobe.dvatransport.framework 0x0000000101f7b2b9 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
6 com.adobe.boost_threads.framework 0x0000000100042279 boost::(anonymous namespace)::thread_proxy(void*) + 185
7 libsystem_pthread.dylib 0x00007fff988ae99d _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff988ae91a _pthread_start + 168
9 libsystem_pthread.dylib 0x00007fff988ac351 thread_start + 13
Thread 3:
0 libsystem_kernel.dylib 0x00007fff96f91db6 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff988af728 _pthread_cond_wait + 767
2 com.adobe.dvatransport.framework 0x0000000101f86c56 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 246
4 com.adobe.dvatransport.framework 0x0000000101f92c7a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_io_service_runner>::run() + 42
5 com.adobe.dvacore.framework 0x00000001001c2bc3 boost_asio_detail_posix_thread_function + 19
6 libsystem_pthread.dylib 0x00007fff988ae99d _pthread_body + 131
7 libsystem_pthread.dylib 0x00007fff988ae91a _pthread_start + 168
8 libsystem_pthread.dylib 0x00007fff988ac351 thread_start + 13
Thread 4:
2 com.apple.CoreServices.CarbonCore 0x00007fff9b5fc8ac TSWaitOnCondition + 108
3 com.apple.CoreServices.CarbonCore 0x00007fff9b5fcaab TSWaitOnConditionTimedRelative + 171
4 com.apple.CoreServices.CarbonCore 0x00007fff9b5d5012 MPWaitOnQueue + 192
5 com.adobe.dvacore.framework 0x0000000100224f5b dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::AllocatedFunctionT<boost::function<void ()> > >&, int) + 155
6 com.adobe.dvacore.framework 0x0000000100222d48 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 168
7 com.adobe.dvacore.framework 0x000000010021f7c6 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 358
8 com.adobe.boost_threads.framework 0x0000000100042279 boost::(anonymous namespace)::thread_proxy(void*) + 185
9 libsystem_pthread.dylib 0x00007fff988ae99d _pthread_body + 131
10 libsystem_pthread.dylib 0x00007fff988ae91a _pthread_start + 168
11 libsystem_pthread.dylib 0x00007fff988ac351 thread_start + 13
Thread 5:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x00007fff96f8bf72 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff96f8b3b3 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff9a3451c4 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff9a34468c __CFRunLoopRun + 1356
4 com.apple.CoreFoundation 0x00007fff9a343ed8 CFRunLoopRunSpecific + 296
5 com.apple.CFNetwork 0x00007fff990d8a6d +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
6 com.apple.Foundation 0x00007fff994eee64 __NSThread__start__ + 1351
Thread 6:
2 com.apple.CoreServices.CarbonCore 0x00007fff9b5f98de TS_exception_listener_thread + 100
3 libsystem_pthread.dylib 0x00007fff988ae99d _pthread_body + 131
4 libsystem_pthread.dylib 0x00007fff988ae91a _pthread_start + 168
5 libsystem_pthread.dylib 0x00007fff988ac351 thread_start + 13
Thread 7:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff96f9207a __select + 10
1 com.apple.CoreFoundation 0x00007fff9a3824fa __CFSocketManager + 762
2 libsystem_pthread.dylib 0x00007fff988ae99d _pthread_body + 131
3 libsystem_pthread.dylib 0x00007fff988ae91a _pthread_start + 168
4 libsystem_pthread.dylib 0x00007fff988ac351 thread_start + 13
Thread 8:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff91482d95 _NSEventThread + 149
Thread 9:: MF::DirectoryChangeMonitor
1 com.adobe.MediaFoundation.framework 0x00000001026211b7 MF::DirectoryChangeMonitor::(anonymous namespace)::EventQueueThreadProc(void*) + 519
Thread 10:
Thread 11 Crashed:: Dispatch queue: com.apple.audio.CADispatchQueue.SerialQueue
0 libsystem_kernel.dylib 0x00007fff96f91f06 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff988b14ec pthread_kill + 90
2 libsystem_c.dylib 0x00007fff8b2b16df abort + 129
3 libc++abi.dylib 0x00007fff9defac11 abort_message + 257
4 libc++abi.dylib 0x00007fff9df1f370 __cxa_pure_virtual + 18
5 com.adobe.dvaaudiodevice.framework 0x0000000112bfad7e (anonymous namespace)::DeviceListChanged(unsigned int, unsigned int, AudioObjectPropertyAddress const*, void*) + 206
6 com.apple.audio.CoreAudio 0x00007fff957f3fbd HALPropertyListener::Call(unsigned int, unsigned int, AudioObjectPropertyAddress const*) + 347
7 com.apple.audio.CoreAudio 0x00007fff957e72e1 HALObject::PropertiesChanged(unsigned int, AudioObjectPropertyAddress const*) + 769
8 com.apple.audio.CoreAudio 0x00007fff957e697d HALSystem::ObjectsPublishedAndDied(unsigned int, unsigned int const*, unsigned int, unsigned int const*) + 1275
9 com.apple.audio.CoreAudio 0x00007fff957e6356 HALSystem::AudioObjectsPublishedAndDied(AudioHardwarePlugInInterface**, unsigned int, unsigned int, unsigned int const*, unsigned int, unsigned int const*) + 196
10 com.apple.audio.CoreAudio 0x00007fff9580ca8f HALC_ShellPlugIn::ProxyObject_PropertiesChanged(unsigned int, unsigned int, AudioObjectPropertyAddress const*) + 765
11 com.apple.audio.CoreAudio 0x00007fff957f4c5e HALC_ProxyNotifications::CallListener(unsigned int, unsigned int, unsigned int, AudioObjectPropertyAddress const*) + 54
12 com.apple.audio.CoreAudio 0x00007fff957f4b18 HALC_ProxyNotifications::CallListener_f(void*) + 26
13 libdispatch.dylib 0x00007fff89cea40b _dispatch_client_callout + 8
14 libdispatch.dylib 0x00007fff89cef03b _dispatch_queue_drain + 754
15 libdispatch.dylib 0x00007fff89cf5707 _dispatch_queue_invoke + 549
16 libdispatch.dylib 0x00007fff89cedd53 _dispatch_root_queue_drain + 538
17 libdispatch.dylib 0x00007fff89cedb00 _dispatch_worker_thread3 + 91
18 libsystem_pthread.dylib 0x00007fff988ae4de _pthread_wqthread + 1129
19 libsystem_pthread.dylib 0x00007fff988ac341 start_wqthread + 13
Thread 12:
2 com.mainconcept.mc.dec.mp2v 0x000000011b70430b 0x11b6e3000 + 135947
3 com.mainconcept.mc.dec.mp2v 0x000000011b6fd43b 0x11b6e3000 + 107579
4 libsystem_pthread.dylib 0x00007fff988ae99d _pthread_body + 131
5 libsystem_pthread.dylib 0x00007fff988ae91a _pthread_start + 168
6 libsystem_pthread.dylib 0x00007fff988ac351 thread_start + 13
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
0 libsystem_kernel.dylib 0x00007fff96f925e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff988ae578 _pthread_wqthread + 1283
2 libsystem_pthread.dylib 0x00007fff988ac341 start_wqthread + 13
Thread 49:
0 libsystem_kernel.dylib 0x00007fff96f8bfc6 semaphore_timedwait_trap + 10
1 libdispatch.dylib 0x00007fff89cf5c67 _dispatch_semaphore_wait_slow + 149
2 libdispatch.dylib 0x00007fff89cefd1b _dispatch_worker_thread + 148
Thread 11 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x0000700001bb2518 rdx: 0x0000000000000000
rdi: 0x00000000000300c7 rsi: 0x0000000000000006 rbp: 0x0000700001bb2540 rsp: 0x0000700001bb2518
r8: 0x0000000000000001 r9: 0x00007fff9df21c22 r10: 0x000000000c000000 r11: 0x0000000000000206
r12: 0x0000700001bb26a0 r13: 0x0000000000000000 r14: 0x0000700001bb3000 r15: 0x0000700001bb2580
rip: 0x00007fff96f91f06 rfl: 0x0000000000000206 cr2: 0x00007fff7822c008
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x100000000 - 0x100001fff +com.adobe.PremierePro.CC11 (11.1.2 - 11.1.2) <1A639C64-B1E5-3A83-8A2B-F435C157F6BB> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/MacOS/Adobe Premiere Pro CC 2017
0x100008000 - 0x10000bfff +com.adobe.AdobeCrashReporter (7.3 - 7.4.0) <AC1EBE59-1242-3933-A0C8-EC1D73CD2C26> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x100013000 - 0x100015fff +com.adobe.PRM.framework (11.1.0 - 11.1.0.0) <BC841141-ECE9-34E0-9293-E38457BEB35F> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
0x100021000 - 0x100022fff +com.adobe.boost_system.framework (11.1.2 - 11.1.2.22) <CD43FFF9-8413-3F89-86C4-73DF87B05C39> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
0x10002a000 - 0x10002efff +com.adobe.boost_date_time.framework (11.1.2 - 11.1.2.22) <4EF2F1E8-A5B3-37EC-84F8-22EE7EDA38EA> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
0x100040000 - 0x10004effb +com.adobe.boost_threads.framework (11.1.2 - 11.1.2.22) <547D50CB-40B7-3C57-AE37-0DBD45F47CAC> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0x10006b000 - 0x100077ffb +com.adobe.boost_filesystem.framework (11.1.2 - 11.1.2.22) <4DC7BBA3-D94E-36F4-84B4-34310370A555> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
0x10008b000 - 0x1000a5ff3 +com.adobe.dvaunittesting.framework (11.1.2 - 11.1.2.22) <A4C63245-2E1C-3565-818A-C4EB28C56F52> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
0x1000d8000 - 0x10044aff7 +com.adobe.dvacore.framework (11.1.2 - 11.1.2.22) <D15146E5-14FE-3C12-B4DB-59C3825C4D4A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x100724000 - 0x10079dff3 +com.adobe.dvamediatypes.framework (11.1.2 - 11.1.2.22) <268ED683-BAEE-30EE-811C-5DC8F31D3E8B> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
0x100840000 - 0x1008b9ff7 +com.adobe.ASLFoundation.framework (11.1.0 - 11.1.0.0) <805F80A3-B734-3893-9A72-260ADEFA043B> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
0x100954000 - 0x100b45ff7 +com.adobe.Frontend.framework (11.1.2 - 11.1.2.22) <AFEDDE3D-8C48-3CBC-9C86-BCC21C6F9E64> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
0x100dd6000 - 0x100ed9fff +com.adobe.amtlib (10.0.0.47 - 10.0.0.47) <AD7B1E56-04A5-355A-AD70-DA2464879FC3> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x100eed000 - 0x100f98ff7 +com.adobe.dvascripting.framework (11.1.2 - 11.1.2.22) <F8B04455-CA29-368B-BF75-52FDE1E4BD2A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvascripting.framework/Versions/A/dvascripting
0x1010b3000 - 0x1010d6ff7 +com.adobe.ASLMessaging.framework (11.1.0 - 11.1.0.0) <8B35AEF1-EAA1-3F68-B7BB-18E8EAAF1FFB> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
0x101122000 - 0x101979ff7 +com.adobe.dvaaccelerate.framework (11.1.2 - 11.1.2.22) <BA740B62-3726-3DFC-A042-C6098C9222B8> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaaccelerate.framework/Versions/A/dvaaccelerate
0x101a2e000 - 0x101c84ff7 +com.adobe.dvaaudiodsp.framework (11.1.2 - 11.1.2.22) <70B9492A-9E74-301B-A503-8DD66221C358> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaaudiodsp.framework/Versions/A/dvaaudiodsp
0x101f55000 - 0x101f57ff7 +com.adobe.Memory.framework (11.1.0 - 11.1.0.0) <7709D499-1F35-3AA5-9B30-C0569201C4A8> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
0x101f60000 - 0x101fc0ffb +com.adobe.dvatransport.framework (11.1.2 - 11.1.2.22) <1E9F0CB3-0E0D-3ADE-891E-420ABE9611FE> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
0x10204e000 - 0x102073ffb +com.adobe.dvamarshal.framework (11.1.2 - 11.1.2.22) <206F0025-26B7-3194-9C9E-091679D71A63> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
0x1020b3000 - 0x102317ffb +com.adobe.dynamiclink.framework (11.1.2 - 11.1.2.22) <1EB6626C-58B4-32AB-88BA-DE9D3520F373> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
0x1025b9000 - 0x102668ff7 +com.adobe.MediaFoundation.framework (11.1.0 - 11.1.0.0) <3015230E-D7AD-33B8-8968-C199197FD192> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
0x102754000 - 0x1027e0fff +com.adobe.AudioRenderer.framework (11.1.0 - 11.1.0.0) <843F3E1D-E8AD-37DE-8A48-F5505E7747BA> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
0x1028b3000 - 0x1029baff7 +com.adobe.dvacaptioning.framework (11.1.2 - 11.1.2.22) <A621AE90-4EEB-3729-81EB-93436653085A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
0x102aa3000 - 0x102b02ff3 +com.adobe.dvatemporalxmp.framework (11.1.2 - 11.1.2.22) <184E14F5-D796-3595-999C-A15DFBAB9F65> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
0x102b44000 - 0x102b4fff7 +com.adobe.boost_signals.framework (11.1.2 - 11.1.2.22) <0A709484-41E2-33EE-A93C-62909D7B144A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
0x102b67000 - 0x102c4fff7 +com.adobe.dvametadata.framework (11.1.2 - 11.1.2.22) <60DDFCE9-318F-3DD0-A04C-5DE18B8AB502> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
0x102d3c000 - 0x103c1cff7 +com.adobe.Backend.framework (11.1.0 - 11.1.0.0) <1789462A-44C6-3F1C-B1FE-7E7E625CB552> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
0x104bd1000 - 0x104c04fff +com.adobe.MLFoundation.framework (11.1.0 - 11.1.0.0) <87185D99-893A-3EB5-93D1-24055E58D9A2> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
0x104c63000 - 0x104dcefdf +com.adobe.ImageRenderer.framework (11.1.0 - 11.1.0.0) <66127F91-AE1C-305E-9B14-A9188DB64762> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
0x104eeb000 - 0x104f96ff7 +com.adobe.VideoFrame.framework (11.1.0 - 11.1.0.0) <CA357601-F915-306F-AFEE-CF90BC76D408> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
0x10501e000 - 0x105066ff7 +com.adobe.PluginSupport.framework (11.1.0 - 11.1.0.0) <071C55A4-6469-3C23-8514-00FDC172BE14> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
0x1050cb000 - 0x1050f4ff7 +com.adobe.SweetPeaSupport.framework (11.1.0 - 11.1.0.0) <FE9D4F70-516C-359B-AE64-FB8CBBF3B995> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
0x105142000 - 0x105191ff7 +com.adobe.TransmitHost.framework (11.1.0 - 11.1.0.0) <0F45FFBA-3CB6-3A97-AA8C-95020AB1C317> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
0x1051f5000 - 0x105347ff7 +com.adobe.VideoRenderer.framework (11.1.0 - 11.1.0.0) <D90CBC3B-A8B3-36FC-B7D7-46CE1FAC919D> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
0x1054d3000 - 0x10550fff7 +com.adobe.AudioSupport.framework (11.1.0 - 11.1.0.0) <5994D91A-72C2-37DA-B103-5B4D0D15CF28> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
0x105585000 - 0x10559aff7 +com.adobe.MediaUtils.framework (11.1.0 - 11.1.0.0) <A564C931-0244-391B-BECF-A9F940C633E7> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
0x1055b9000 - 0x10577cfff +com.adobe.ImporterHost.framework (11.1.0 - 11.1.0.0) <A94FC19A-EF14-3FE5-AEBC-A7B78F41C7DB> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
0x1059c5000 - 0x105abcfff +com.adobe.ExporterHost.framework (11.1.0 - 11.1.0.0) <C2BB839F-D954-3966-AC4A-D19F55D922BC> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
0x105bd3000 - 0x105c48fff +com.adobe.PlayerHost.framework (11.1.0 - 11.1.0.0) <BD4E0E38-F936-37B4-BB60-D7071DD35951> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
0x105d20000 - 0x105d77fff +com.adobe.AudioFilterHost.framework (11.1.0 - 11.1.0.0) <34CA2DA7-ADA5-3D90-BD11-FB53FC099165> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
0x105dff000 - 0x105f1dfff +com.adobe.VideoFilterHost.framework (11.1.0 - 11.1.0.0) <F97C2A38-629B-31DF-BD71-BE1D47D6FC0E> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
0x10606a000 - 0x106084ff7 +com.adobe.ProjectSupport.framework (11.1.0 - 11.1.0.0) <1DA68581-69A8-35A6-84A4-66863695FF11> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
0x1060b7000 - 0x106264ff7 +com.adobe.EncoderHost.framework (11.1.0 - 11.1.0.0) <2C665D70-777B-3FEA-959B-F0D3DFE6FEAC> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
0x106436000 - 0x106447fff +com.adobe.ProjectConverterHost.framework (11.1.0 - 11.1.0.0) <54D21039-DAFC-32C6-ADCD-549027CD290B> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHost
0x10646c000 - 0x1064e1fff +com.adobe.RecorderHost.framework (11.1.0 - 11.1.0.0) <9FBEADF2-4037-38F8-B713-C44457CBB4D0> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
0x1065bb000 - 0x106755fd7 +com.adobe.atlaudio.framework (11.1.2 - 11.1.2.22) <0A28825D-F417-3633-AEF1-AD726C42D9FF> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/atl_audio.framework/Versions/A/atl_audio
0x10677e000 - 0x106e51ff7 +com.adobe.dvaui.framework (11.1.2 - 11.1.2.22) <D586FD41-C022-3D2A-B7DA-8DCA4C2F6090> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x107968000 - 0x107d48ff7 +com.adobe.UIFramework.framework (11.1.2 - 11.1.2.22) <B7E0188B-1590-3796-B9F5-9A57A222F43C> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
0x1084b4000 - 0x1084f0ff7 +com.adobe.AudioFilters.framework (11.1.0 - 11.1.0.0) <3D184050-9983-338D-A43E-BA68284987A4> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
0x10856c000 - 0x1090a4fff +com.adobe.Mezzanine.framework (11.1.2 - 11.1.2.22) <520B49B2-8265-3F3D-ADDC-2E2BA853E3A4> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
0x109adc000 - 0x109c6fff7 +com.adobe.dvaworkspace.framework (11.1.2 - 11.1.2.22) <C191DC92-6329-3BB3-A644-1D96A149A9F9> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
0x109f53000 - 0x10a026fff +com.adobe.ScriptLayerPPro.framework (11.1.2 - 11.1.2.22) <91DEBCFA-1706-30FE-9515-D6CF30CFD105> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
0x10a162000 - 0x10a610ff7 +com.adobe.ScriptLayerPProQE.framework (11.1.2 - 11.1.2.22) <7319D4F0-52F2-3E0D-B832-E3CF9A3B2767> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ScriptLayerPProQE.framework/Versions/A/ScriptLayerPProQE
0x10ae4c000 - 0x10af0efff +com.adobe.PProDynamicLinkServer.framework (11.1.2 - 11.1.2.22) <B7BC3B96-AE1F-35DD-98FC-8EFD409448FD> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkServer
0x10b084000 - 0x10b0b3ff7 +com.adobe.Registration.framework (11.1.2 - 11.1.2.22) <B1D7B30B-5F3A-3D83-8FF4-27B4E42CE816> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/Registration.framework/Versions/A/Registration
0x10b0e8000 - 0x10b1d9ff3 +com.adobe.dvaeve.framework (11.1.2 - 11.1.2.22) <A375538D-87F4-3D4C-806D-41E5CAD16722> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x10b352000 - 0x10b81afff +com.adobe.Dialogs.framework (11.1.2 - 11.1.2.22) <4334A253-8CF3-3958-8BA6-DFCD9B2B2E20> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
0x10bd61000 - 0x10bda7fff +com.adobe.BravoInitializer.framework (11.1.0 - 11.1.0.0) <AFB2C88C-071C-312B-A658-283461CF2004> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
0x10be1f000 - 0x10be58fff +com.adobe.MediaCoreUI.framework (11.1.0 - 11.1.0.0) <6E8D71FE-EE02-3C86-9938-B21C410DAFC7> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
0x10beb1000 - 0x10c0e6ff7 +com.adobe.SettingsUI.framework (11.1.2 - 11.1.2.35) <14B6F01E-C3FC-3864-8DEF-7BC8F168AD72> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
0x10c4af000 - 0x10c8dfff7 +com.adobe.HSL.framework (11.1.2 - 11.1.2.22) <B04C15C0-460A-39CD-8777-3639C23F2EDE> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
0x10ce23000 - 0x10d01bff7 +com.adobe.GPUFoundation.framework (11.1.0 - 11.1.0.0) <BD54C9E4-BFC5-3E35-8536-9A6AAA9B0731> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
0x10d14b000 - 0x10d226ff3 +com.adobe.exo.framework (11.1.2 - 11.1.2.22) <064B5536-B110-31E4-B020-A15158A2AC1A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x10d3da000 - 0x10d439ff7 +com.adobe.CSXSManager.framework (11.1.2 - 11.1.2.22) <C7B8CA97-6E47-3064-8AB7-AF883423E8B4> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
0x10d4ba000 - 0x10d4eeff7 +com.adobe.HandlerAudioMiniMixer.framework (11.1.2 - 11.1.2.22) <B8B97CD8-2E46-38D3-BF7B-F12B63B614D8> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMiniMixer
0x10d54f000 - 0x10d603ff7 +com.adobe.HandlerAudioMixer.framework (11.1.2 - 11.1.2.22) <AD1AF82F-B859-3605-8C60-2D6896F991EB> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
0x10d708000 - 0x10d766ff7 +com.adobe.HandlerAudioClipMixer.framework (11.1.2 - 11.1.2.22) <56FB57E9-4EE4-38BF-A27F-E6EC695E7F5E> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerAudioClipMixer.framework/Versions/A/HandlerAudioClipMixer
0x10d81b000 - 0x10d870ff7 +com.adobe.HandlerCaptions.framework (11.1.2 - 11.1.2.22) <0C937DBC-F128-34BD-A976-7BFB662503D6> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerCaptions.framework/Versions/A/HandlerCaptions
0x10d90e000 - 0x10d99fff7 +com.adobe.HandlerCapture.framework (11.1.2 - 11.1.2.22) <7588CA63-35AD-33FC-8B77-6634B2F6608B> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
0x10da9e000 - 0x10db64fff +com.adobe.HandlerColor.framework (11.1.2 - 11.1.2.22) <84A9F70D-28FB-3996-AA3A-F852F1FBBE40> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerColor.framework/Versions/A/HandlerColor
0x10dc79000 - 0x10dc93ff7 +com.adobe.HandlerEssentialSound.framework (11.1.2 - 11.1.2.22) <184E6603-717F-3F4B-88A7-481F4378BC91> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerEssentialSound.framework/Versions/A/HandlerEssentialSound
0x10dcdf000 - 0x10dd32ff7 +com.adobe.HandlerEditToTape.framework (11.1.2 - 11.1.2.22) <F2F14EE5-35AE-3E14-B25D-360D700F37D6> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerEditToTape.framework/Versions/A/HandlerEditToTape
0x10ddd6000 - 0x10de06fff +com.adobe.HandlerCSXS.framework (11.1.2 - 11.1.2.22) <D24BEA0A-602B-301D-A1D8-57C2F5FA5012> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerCSXS
0x10de82000 - 0x10e0deff7 +com.adobe.HandlerEffectControls.framework (11.1.2 - 11.1.2.22) <95A6DDFD-D304-3B1A-B524-296BE8EB5823> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffectControls
0x10e37a000 - 0x10e3f5fff +com.adobe.HandlerEffects.framework (11.1.2 - 11.1.2.22) <8F876FC6-6848-3521-805D-B6169CBBBE85> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/HandlerEffects
0x10e4af000 - 0x10e4cfff7 +com.adobe.HandlerEvents.framework (11.1.2 - 11.1.2.22) <B9F7F3F6-9EB8-3B41-899F-99AF3837B10C> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
0x10e51f000 - 0x10e532fff +com.adobe.HandlerGetProperties.framework (11.1.2 - 11.1.2.22) <CD1705B4-DEED-33F6-BB2C-FFE8D234E643> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetProperties
0x10e564000 - 0x10e5e2ff7 +com.adobe.HandlerGraphics.framework (11.1.2 - 11.1.2.22) <B65DEEA7-ACED-31D2-B0FA-5C9B1C4132D3> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerGraphics.framework/Versions/A/HandlerGraphics
0x10e6ab000 - 0x10e6c5ff7 +com.adobe.HandlerHistory.framework (11.1.2 - 11.1.2.22) <1B8F0C3D-0ED2-397B-B582-D96D45E8A63D> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
0x10e700000 - 0x10e709fff +com.adobe.HandlerStoryPanel.framework (11.1.2 - 11.1.2.22) <CBEFBA18-9605-3D97-901B-42B121369DD0> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerStoryPanel.framework/Versions/A/HandlerStoryPanel
0x10e729000 - 0x10e753ff7 +com.adobe.HandlerInfo.framework (11.1.2 - 11.1.2.22) <19921242-7A54-32DA-A347-D3EAA13F3175> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
0x10e7b3000 - 0x10e883fff +com.adobe.HandlerInspector.framework (11.1.2 - 11.1.2.22) <73767CE6-7967-3905-98B0-0A80D44575BB> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerInspector.framework/Versions/A/HandlerInspector
0x10e9e2000 - 0x10ea2cff7 +com.adobe.HandlerMarkerList.framework (11.1.2 - 11.1.2.22) <CA6FCC81-292E-348D-8A20-97CC77006AFE> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerMarkerList.framework/Versions/A/HandlerMarkerList
0x10eaca000 - 0x10eb22fff +com.adobe.HandlerMetadataEditor.framework (11.1.2 - 11.1.2.22) <24079885-C2AE-33F1-AAD4-67289AC9176A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/A/HandlerMetadataEditor
0x10ebd5000 - 0x10ec10fff +com.adobe.HandlerMediaBrowser.framework (11.1.2 - 11.1.2.22) <6D30E50F-F937-3AC1-BC95-68E5F48F73DA> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/HandlerMediaBrowser
0x10eca7000 - 0x10ee08ff7 +com.adobe.HandlerProgramMonitor.framework (11.1.2 - 11.1.2.22) <7AB621F7-1D2F-3489-BA8C-1907E208FAA5> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/A/HandlerProgramMonitor
0x10efcc000 - 0x10f286ff7 +com.adobe.HandlerProject.framework (11.1.2 - 11.1.2.22) <1A32052A-38E8-39BD-95CD-F8F3B950A8C5> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
0x10f656000 - 0x10f668fff +com.adobe.HandlerScopes.framework (11.1.2 - 11.1.2.22) <CBB33025-F6D6-3AB7-AA29-266A836B6CE1> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerScopes.framework/Versions/A/HandlerScopes
0x10f691000 - 0x10f849fff +com.adobe.HandlerSourceMonitor.framework (11.1.2 - 11.1.2.22) <3F6CFB53-DC70-36B7-A103-36108134F2B1> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A/HandlerSourceMonitor
0x10f9f5000 - 0x10fa09ff7 +com.adobe.HandlerTimecode.framework (11.1.2 - 11.1.2.22) <582D0689-B3CB-36CB-9DB4-AC79FCE0E2D6> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerTimecode.framework/Versions/A/HandlerTimecode
0x10fa3f000 - 0x10fd9dff7 +com.adobe.HandlerTimeline.framework (11.1.2 - 11.1.2.22) <BF957FD7-108A-3303-9252-ACAD8D37B656> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
0x110110000 - 0x110167fff +com.adobe.FontEngine.framework (11.1.0 - 11.1.0.0) <DDC89E57-A5DA-339F-B3F6-CE0F48E37A3E> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
0x1101f7000 - 0x110212ff7 +com.adobe.TitleLayer.framework (11.1.0 - 11.1.0.0) <CAE32AFF-2DE7-36F8-B84B-958EAB3FC193> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
0x1103ac000 - 0x1103b8ff7 +com.adobe.TitleImageManager.framework (11.1.0 - 11.1.0.0) <200DA0A6-4012-3184-8623-E6572DCA8447> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
0x1103d4000 - 0x110457ff7 +com.adobe.TitleCharacterFactory.framework (11.1.0 - 11.1.0.0) <572D4BBF-F0DD-36BE-8AB2-28AA54FECE60> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFactory
0x1104b0000 - 0x1105bdfff +com.adobe.TitleCG.framework (11.1.0 - 11.1.0.0) <EEC4B1C0-D91B-3979-B925-D606B2237469> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
0x110651000 - 0x1108a4fff +com.adobe.TitleLayout.framework (11.1.0 - 11.1.0.0) <B38E94DF-16A5-3456-BA19-71798E6D01CE> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
0x110d8b000 - 0x110de0ff7 +com.adobe.TitleRenderer.framework (11.1.0 - 11.1.0.0) <3693307A-DEF5-357C-B576-F1264ED7E7E7> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
0x110e77000 - 0x1110fcff7 +com.adobe.HandlerTitler.framework (11.1.2 - 11.1.2.22) <0178E730-F024-3F0E-A50C-6A99C588A131> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/HandlerTitler
0x111476000 - 0x1114c2fff +com.adobe.HandlerTools.framework (11.1.2 - 11.1.2.22) <6B9B41D4-2A22-3253-A1CC-BBC9F5C6A62A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerTools.framework/Versions/A/HandlerTools
0x1115ce000 - 0x1115d3ff7 +com.adobe.HandlerProgress.framework (11.1.2 - 11.1.2.22) <7F2E6322-F5C5-3B5F-877D-618B2EB80C07> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/HandlerProgress.framework/Versions/A/HandlerProgress
0x1115e7000 - 0x1116d8ff7 +com.adobe.dvaaudiofilterhost.framework (11.1.2 - 11.1.2.22) <C7070229-7024-31C1-9111-7372537EA8CF> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
0x111830000 - 0x11188dff3 +com.adobe.dvaaudiofilterhostui.framework (11.1.2 - 11.1.2.22) <CB7C9C6D-0514-3CB0-8B33-245C32F11F13> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A/dvaaudiofilterhostui
0x111956000 - 0x111ad5ffb +com.adobe.dvaaudiofilters.framework (11.1.2 - 11.1.2.22) <89898FC5-19EA-37E7-9B78-818ACD030447> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaaudiofilters.framework/Versions/A/dvaaudiofilters
0x111cf1000 - 0x112060ffb +com.adobe.dvaadameve.framework (11.1.2 - 11.1.2.22) <A192EEC4-D07E-38B8-8A5E-67BF8EF4051F> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
0x11273f000 - 0x1128b6ff7 +com.adobe.dvaaudiofiltersui.framework (11.1.2 - 11.1.2.22) <B3801CF0-E67D-33CC-9C55-6C336775DA88> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaaudiofiltersui.framework/Versions/A/dvaaudiofiltersui
0x112b4d000 - 0x112c41fe7 +com.adobe.dvaaudiodevice.framework (11.1.2 - 11.1.2.22) <E555870F-7A01-32F1-91CE-C6900752FA5C> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
0x112dda000 - 0x112e12ff3 +com.adobe.dvaaudiodeviceui.framework (11.1.2 - 11.1.2.22) <0CAD827E-0D8A-30CC-A906-659983B11F50> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaaudiodeviceui.framework/Versions/A/dvaaudiodeviceui
0x112e70000 - 0x112f52ffb +com.adobe.dvanet.framework (11.1.2 - 11.1.2.22) <D554FA55-2E73-3A4D-A6D5-A756F924FDB2> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
0x11306e000 - 0x11317fff7 +com.adobe.dvanetsync.framework (11.1.2 - 11.1.2.22) <9B15873E-CEAA-3B1E-92C2-A0D285EB2134> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvanetsync.framework/Versions/A/dvanetsync
0x1132db000 - 0x113a33ff7 +com.adobe.EAClient.framework (11.1.0 - 11.1.0.0) <FCC25EAE-A69E-3C9B-9957-F50D25EABE8D> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/EAClient.framework/Versions/A/EAClient
0x1142b7000 - 0x1144bbfe7 +com.adobe.EACodec.framework (11.1.0 - 11.1.0.0) <499569FC-0B3D-3CD2-AEFC-EA070A7CD2C2> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/EACodec.framework/Versions/A/EACodec
0x114579000 - 0x114882ff7 +com.adobe.EAMedia.framework (11.1.0 - 11.1.0.0) <F87C3DDE-02BD-3E48-B443-EBFA597B8B4A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/EAMedia.framework/Versions/A/EAMedia
0x114b9a000 - 0x11509fff7 +com.adobe.EAProjectBridge.framework (11.1.0 - 11.1.0.0) <06889E17-286B-339D-AC2B-341554C8A679> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/EAProjectBridge.framework/Versions/A/EAProjectBridge
0x1155eb000 - 0x115766fff +com.adobe.EAPrBridge.framework (11.1.2 - 11.1.2.22) <5E612942-F6A3-3F16-9707-5F387A456B80> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/EAPrBridge.framework/Versions/A/EAPrBridge
0x11594e000 - 0x115998ff7 +com.adobe.MediaFinder.framework (11.1.2 - 11.1.2.22) <AE543ED3-B8BE-3880-86BF-35FA761B5DCD> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/MediaFinder.framework/Versions/A/MediaFinder
0x115a10000 - 0x115a45ff7 +com.adobe.dvacontrolsurfacehost.framework (11.1.2 - 11.1.2.22) <D33E45F1-EE35-3CF0-A4C9-8098488E9408> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvacontrolsurfacehost.framework/Versions/A/dvacontrolsurfacehost
0x115aca000 - 0x115b57ff7 +com.adobe.ControlSurface.framework (11.1.2 - 11.1.2.22) <49FF712E-0EBC-3315-9585-E2ACC57352E9> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ControlSurface.framework/Versions/A/ControlSurface
0x115bf1000 - 0x115c07ff7 +com.adobe.postprocess.framework (11.1.2 - 11.1.2.35) <0DA764DD-C236-3496-80DE-31EEE21B75C1> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/postprocess.framework/Versions/A/postprocess
0x115c37000 - 0x115c64fff +com.adobe.OnBoarding.framework (11.1.2 - 11.1.2.22) <C1A5EB7E-4ADD-36BE-9B92-1875875AAAFF> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/OnBoarding.framework/Versions/A/OnBoarding
0x115ccd000 - 0x115d76fff +com.adobe.boost_regex.framework (11.1.2 - 11.1.2.22) <7A65F876-5527-32EC-A898-EB512FE91E48> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
0x115dfd000 - 0x115f97fff +com.adobe.headlights.LogSessionFramework (7.4.1.63.45453) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x11606b000 - 0x1161e5ff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 140 - 79.160451) <BA9FA2D4-A630-31C2-991E-463A1637F95A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x116338000 - 0x11649dff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 26 - 79.160451) <D9D1C497-7EFF-3AF2-A42D-E51721FE1483> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
0x1165c6000 - 0x116710ff7 +com.adobe.ACE (AdobeACE 2.20.02.37848 - 2.20.02.37848) <3236E6F5-C286-3C46-AD03-9838AFE1D751> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x116726000 - 0x1169efffb +com.adobe.AGM (AdobeAGM 4.30.87.37848 - 4.30.87.37848) <7DAE22B9-2F91-385B-B4EA-9EC75CBEE0EF> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x116a5e000 - 0x116a7affb +com.adobe.BIB (AdobeBIB 1.2.03.37848 - 1.2.03.37848) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x116a83000 - 0x116aa6ff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x116aaf000 - 0x116dacffb +com.adobe.CoolType (AdobeCoolType 5.15.00.37848 - 5.15.00.37848) <46381E3C-77F9-3842-8A13-33BDEFA6E1D7> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x116df9000 - 0x116e95ff7 +com.adobe.sccore.framework (4.5.6 - 4.5.6.1) <1D21F907-A29E-3C96-A29F-02F7EB97173C> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/sccore.framework/Versions/A/sccore
0x116f26000 - 0x116fccfff +com.adobe.extendscript.framework (4.5.6 - 4.5.6.1) <D70C249B-B6A8-373E-9BC6-FEB4D3F747AE> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/extendscript.framework/Versions/A/extendscript
0x117068000 - 0x1172defe7 +com.adobe.PlugPlug (7.0.0.30 - 7.0.0.30) <9CD4BFD1-2997-3606-93F6-F81A0CC2773B> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x1175a8000 - 0x1176d2ff7 +com.winsoft.wrservices (WRServices 12.0.0 - 12.0.0) <DC848A40-2FD7-3C18-8653-242100970FF6> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/wrservices.framework/Versions/A/WRServices
0x117725000 - 0x117823ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
0x117851000 - 0x11794bfff +com.adobe.adobe_caps (adobe_caps 10.0.0.5 - 10.0.0.5) <E029224F-4AD9-3054-87A7-AB5FAAD7CD1F> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
0x11795c000 - 0x1179a3ff7 com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <725265D0-1869-30A1-B27A-55CFA8FBF5A4> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x1179dd000 - 0x117b36fe7 com.apple.mobiledevice (823.40.7 - 823.40.7) <39118395-1892-3CFC-9E9B-420BE768B648> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
0x117bc0000 - 0x117bf7fff com.apple.audio.midi.CoreMIDI (1.10 - 88) <51E79766-51D8-3A95-A7FD-18E7E11528F3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x117c20000 - 0x117d2ffff com.apple.AudioVideoBridging (403.4 - 403.4) <647EC44F-BC92-367C-AA25-E52085CC3EC6> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
0x117de0000 - 0x117df9fff libexpat.1.dylib (12.60.1) <6BF318AC-F90F-3F16-99C2-6ADDE404E280> /usr/lib/libexpat.1.dylib
0x117e03000 - 0x117e09fff com.apple.TimeSync (1.0 - 403.4) <4E3FCB52-7F47-39A2-9C29-11CFE4823CC4> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
0x117e14000 - 0x1180c5ff7 +libxerces-c-3.1.dylib (0) <226354C7-81DD-3502-9CCB-500EC181627A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/libxerces-c-3.1.dylib
0x11826c000 - 0x11828ffff +com.adobe.dvavulcansupport.framework (11.1.2 - 11.1.2.22) <31DAE2B2-C95E-34FD-ACF3-161362720575> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvavulcansupport.framework/Versions/A/dvavulcansupport
0x1182c0000 - 0x1182e4fff +VulcanControl.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <28EE3D33-EA55-38D6-91AA-63225B82B0A5> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/VulcanControl.dylib
0x118310000 - 0x11834bff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
0x1183c6000 - 0x1183e0fff +com.adobe.TeamProjectsLocalClient.framework (11.1.0 - 11.1.0.0) <E0546B42-33E1-365C-99CA-8A9A3B8B1638> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/TeamProjectsLocalClient.framework/Versions/A/TeamProjectsLocalClient
0x118416000 - 0x118553ff7 +com.adobe.AdobeXMPCompareAndMerge (Adobe XMP Compare And Merge 2.0 -c 5 - 79.160451) <6C5D0E77-D2B8-3033-84D8-73A97B4D4A6A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeXMPCompareAndMerge.framework/Versions/A/AdobeXMPCompareAndMerge
0x1186b1000 - 0x1186d7fe7 +com.mainconcept.mc.enc.dv (10.3 - 10.3.16.2760) <5F1DC757-B5BC-34FD-AA83-11FFA3F18BF4> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_enc_dv.framework/Versions/10/mc_enc_dv
0x1186ec000 - 0x118704ff7 +com.adobe.RuntimeInstaller.framework (11.1.0 - 11.1.0.0) <EFF7EF69-96C6-33C1-A963-C0776AB4E6E7> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/RuntimeInstaller.framework/Versions/A/RuntimeInstaller
0x118729000 - 0x11880bfff +com.mainconcept.mc.mfimport (10.3 - 10.3.16.2760) <F1EF4CC4-660B-3D5E-9F9C-08E6EF857B53> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_mfimport.framework/Versions/10/mc_mfimport
0x118819000 - 0x11885eff7 +com.adobe.ATESupport.framework (11.1.0 - 11.1.0.0) <B62DACF4-8422-3CE2-B9E6-96370F11A1AD> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ATESupport.framework/Versions/A/ATESupport
0x1188e7000 - 0x118e4efff +com.adobe.ATE.framework (11.1.0 - 11.1.0.0) <6341BD1D-C01B-347C-8B80-46309720D810> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ATE.framework/Versions/A/ATE
0x119415000 - 0x119507ff7 +com.adobe.OpticalFlow.framework (11.1.0 - 11.1.0.0) <CF6C7B44-C3FF-37F8-947F-5116707E131D> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/OpticalFlow.framework/Versions/A/OpticalFlow
0x1195d6000 - 0x119631fff +com.adobe.QT32Client.framework (11.1.0 - 11.1.0.0) <6A6912C2-BC0B-34C2-BCA6-966CC6E108A1> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
0x1196b5000 - 0x119720ff7 +com.adobe.DynamicLinkMedia.framework (11.1.0 - 11.1.0.0) <FAA6A8BA-8C76-3BEB-A7CD-B42A270B7A40> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
0x1197f2000 - 0x11980fff7 +com.adobe.TimeCarving.framework (11.1.0 - 11.1.0.0) <A06F3EB4-750C-33E4-9F87-A1D2C4AAE28B> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/TimeCarving.framework/Versions/A/TimeCarving
0x119841000 - 0x119895ff3 +com.adobe.dynamiclinkUI.framework (11.1.2 - 11.1.2.22) <4E3E0999-2A24-3DD4-8D91-E3230F6E161A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dynamiclinkUI.framework/Versions/A/dynamiclinkUI
0x119920000 - 0x119924ff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0x11992b000 - 0x119951ff7 +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <40A59819-7A57-0E9F-658D-1803B2A461AE> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/adbeapecore.framework/Versions/A/adbeapecore
0x119964000 - 0x1199a1fff +com.adobe.boost_program_options.framework (11.1.2 - 11.1.2.22) <0FA27EE8-A108-3A93-A4FA-E65602E6632F> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/boost_program_options.framework/Versions/A/boost_program_options
0x1199f7000 - 0x119a13ffb +com.adobe.libzip.framework (11.1.2 - 11.1.2.22) <86E01DD7-AFC0-322F-976A-9B3DA9AC188D> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/libzip.framework/Versions/A/libzip
0x119a29000 - 0x119bd2fff +com.adobe.SynKitLib (1.0.0.91 - 1.0.0.91) <FB3028A1-2329-311E-AB97-90CECA1870A9> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/SynKitLib.framework/Versions/A/SynKitLib
0x119cf8000 - 0x119d16fff +com.adobe.ahclientframework (2.2.0.1 - 2.2.0.1) <78C9396E-DBAE-3C68-9B67-95B28F2BEC76> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x119d29000 - 0x119e7dffb +com.adobe.dvametadataDB.framework (11.1.2 - 11.1.2.22) <07402AA1-98FB-31CC-A5F1-7D8703048300> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
0x119ec8000 - 0x119f2ffff +com.adobe.TimeWarpFilter.framework (11.1.0 - 11.1.0.0) <C7D1E155-106B-3571-8D44-C86B18855E90> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/TimeWarpFilter.framework/Versions/A/TimeWarpFilter
0x119f90000 - 0x119fb3ff3 +com.adobe.AMEAppFoundation.framework (11.1.2 - 11.1.2.35) <6F84EDE0-4C1C-39DC-8586-6900E5182E2F> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
0x11a003000 - 0x11a023fff +com.adobe.ImmersiveVideo.framework (11.1.0 - 11.1.0.0) <FD0DBCCB-9679-362D-BA93-A9E164EBA354> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ImmersiveVideo.framework/Versions/A/ImmersiveVideo
0x11a048000 - 0x11a09ffff +com.adobe.DisplaySurface.framework (11.1.0 - 11.1.0.0) <10F88B7B-01BA-36DA-8D1F-50F029AD8171> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
0x11a109000 - 0x11a213ff3 +com.adobe.dvametadataUI.framework (11.1.2 - 11.1.2.22) <B73369CE-E969-3F95-804B-270539C63F3A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
0x11a367000 - 0x11a373fff +com.adobe.dvamarkerUI.framework (11.1.2 - 11.1.2.22) <21B06707-A52F-395E-B814-1DC6FAAC5A48> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvamarkerUI.framework/Versions/A/dvamarkerUI
0x11a398000 - 0x11a581fff +com.adobe.MBCProvider.framework (11.1.0 - 11.1.0.0) <4BD31821-66E9-3893-BCD2-6E311D610EA6> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
0x11a6c9000 - 0x11a6cfff7 +com.adobe.dvaundo.framework (11.1.2 - 11.1.2.22) <1439FE94-8E47-3FE6-A3EC-361242EA3F9D> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
0x11a6de000 - 0x11a788fff +com.adobe.essentialsound.framework (11.1.2 - 11.1.2.22) <8F4BF48A-AA8F-3F18-AD7A-DF78AB58745E> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/essentialsound.framework/Versions/A/essentialsound
0x11a864000 - 0x11a88bfff +com.adobe.dvastoryparser.framework (11.1.2 - 11.1.2.22) <9763FB16-4AEB-3DA4-BA55-38560A6C814F> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dvastoryparser
0x11a8bc000 - 0x11a8e7ff7 +com.adobe.dvatypekit.framework (11.1.2 - 11.1.2.22) <D5012D54-7B38-3BB3-9AE5-B14AB121A8C1> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvatypekit.framework/Versions/A/dvatypekit
0x11a91e000 - 0x11a9c9fff +com.diaquest.pro4.omf (1.0.0.1022 - 1.0.0.1022) <CC5C6568-78E8-3E2C-B900-2F4392A0309D> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
0x11a9f3000 - 0x11aa09fff +com.adobe.CCLibrariesSupport.framework (11.1.0 - 11.1.0.0) <D6936B7F-C69D-3725-A830-7FBDBF139BAE> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/CCLibrariesSupport.framework/Versions/A/CCLibrariesSupport
0x11aa3b000 - 0x11aa3ffff com.apple.agl (3.3.1 - AGL-3.3.1) <4E401980-0F4F-33E2-A0CF-8C7CCF375F24> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x11aa47000 - 0x11adb3fff +com.mainconcept.mc.enc.avc (10.3 - 10.3.16.2760) <8445B8D0-77C9-3EEA-BF35-B3F2ADB6E600> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_enc_avc.framework/Versions/10/mc_enc_avc
0x11aee4000 - 0x11b0f0fcf +com.mainconcept.mc.dec.avc (10.3 - 10.3.16.2760) <D938E448-C686-3C4B-BE41-6610215B2F84> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_dec_avc.framework/Versions/10/mc_dec_avc
0x11b0fc000 - 0x11b38bff7 +com.mainconcept.mc.mux.mp4 (10.3 - 10.3.16.2760) <2CCFD12C-0988-33EC-9834-D8BFB38C6188> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/10/mc_mux_mp4
0x11b3b2000 - 0x11b599fef +com.adobe.CodecSupport.framework (11.1.0 - 11.1.0.0) <FF04B2A1-FB3C-3CD2-8C72-21F448477C37> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/CodecSupport.framework/Versions/A/CodecSupport
0x11b6e3000 - 0x11b877fef +com.mainconcept.mc.dec.mp2v (10.3 - 10.3.16.2760) <6C472A28-C477-3609-A218-B2FF004C541A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/10/mc_dec_mp2v
0x11b882000 - 0x11bb0ffc7 +com.mainconcept.mc.bc.dec.avc (10.3 - 10.3.16.2760) <D4C36424-71FC-3D70-896E-1D64CB8E6FAD> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_bc_dec_avc.framework/Versions/10/mc_bc_dec_avc
0x11bb21000 - 0x11bcf5fe7 +com.mainconcept.mc.dec.mp4v (10.3 - 10.3.16.2760) <29D7E132-9F2B-37DD-B20F-4D75407F52E9> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_dec_mp4v.framework/Versions/10/mc_dec_mp4v
0x11bd04000 - 0x11bdf2ff7 +com.adobe.QT64Utils.framework (11.1.0 - 11.1.0.0) <F5456D5B-5708-3F30-9810-5663CE05B12F> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/QT64Utils.framework/Versions/A/QT64Utils
0x11be43000 - 0x11be8bfef +com.adobe.ProResOpt.framework (11.1.0 - 11.1.0.0) <A387C5ED-6015-3DE2-88B9-A3D119063071> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ProResOpt.framework/Versions/A/ProResOpt
0x11bec6000 - 0x11c3a7fc7 +libDNxHR.dylib (0) <16E89552-7DB0-3ABA-87A1-C9111E71CE84> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/libDNxHR.dylib
0x11c48b000 - 0x11c567fe7 +libmp4decMT.dylib (1.1.3) <A663DA9C-874F-742A-58B2-B5665D99CA03> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/libmp4decMT.dylib
0x11c5c3000 - 0x11c6cdfff +libCFHDDecoder.dylib (1) <0C9B6356-F555-39E0-9054-81E3FAC4DE55> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/libCFHDDecoder.dylib
0x11c76c000 - 0x11c86efff +libCFHDEncoder.dylib (1) <A3B4AE2B-D61C-339A-8DD1-B2E523640425> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/libCFHDEncoder.dylib
0x11c91a000 - 0x11c949fe7 +libcilkrts.5.dylib (0) <4DC2BE09-A46F-356D-859B-FAEFD118A833> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/libcilkrts.5.dylib
0x11c967000 - 0x11c9a2ffb +com.adobe.boost_serialization.framework (11.1.2 - 11.1.2.22) <316F93EC-8D79-3608-BDEE-591631165758> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/boost_serialization.framework/Versions/A/boost_serialization
0x11ca74000 - 0x11cb26ffb +com.adobe.dvascriptingES.framework (11.1.2 - 11.1.2.22) <7383A3E8-541B-3F26-AEB2-F98B2BE6B831> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvascriptingES.framework/Versions/A/dvascriptingES
0x11cc15000 - 0x11ce27fff +com.adobe.IngestCore.framework (11.1.2 - 11.1.2.22) <7EC53BB4-D772-398D-8891-61CAF39A672B> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/IngestCore.framework/Versions/A/IngestCore
0x11d136000 - 0x11d14dfff +com.adobe.dvacaptioningui.framework (11.1.2 - 11.1.2.22) <FB63DC49-E96C-3D21-A37B-0328DE892764> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvacaptioningui.framework/Versions/A/dvacaptioningui
0x11d172000 - 0x11d361fff +com.adobe.RendererGPU.framework (11.1.0 - 11.1.0.0) <BF0E03E1-2BD4-327E-BF34-C354EC49CEC7> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/RendererGPU.framework/Versions/A/RendererGPU
0x11d481000 - 0x11d49dffb +com.adobe.dvamediaui.framework (11.1.2 - 11.1.2.22) <2FC4264A-4C7A-3319-89F1-DDD3049280A1> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvamediaui.framework/Versions/A/dvamediaui
0x11d4e9000 - 0x11d657ff7 +com.adobe.dvamediabrowser.framework (11.1.0 - 11.1.0.0) <558BAE5E-55D3-3396-A5F9-63B9AAC8FFF2> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvamediabrowser.framework/Versions/A/dvamediabrowser
0x11d8c6000 - 0x11d954ff7 +com.adobe.essentialsoundui.framework (11.1.2 - 11.1.2.22) <397E6285-352C-372A-B38E-8616A9C70BA8> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/essentialsoundui.framework/Versions/A/essentialsoundui
0x11da51000 - 0x11da9bffb +com.adobe.dvastorypanel.framework (11.1.2 - 11.1.2.22) <91A33BFE-B9A0-3927-9DF6-3466B1930A17> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvastorypanel.framework/Versions/A/dvastorypanel
0x12a000000 - 0x12a0b4ff7 com.apple.AMDRadeonX4000GLDriver (1.42.15 - 1.4.2) <FD1F9EB4-0E1B-3B3D-A081-3B9EF8377E3F> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x12a0cc000 - 0x12a5a7fff ATIRadeonX4000SCLib.dylib (1.42.15) <FA3E48B8-DB4C-3335-A0EF-08882E3068BE> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x12a6f5000 - 0x12a6f7ff7 com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x12ac83000 - 0x12ac88ff7 +com.adobe.ImporterAiff.framework (11.1.0 - 11.1.0.0) <6D2F8C75-4844-307E-ABDE-09C74B53DEB9> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/ImporterAiff.bundle/Contents/MacOS/ImporterAiff
0x12cd1c000 - 0x12cd5fff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
0x12cdde000 - 0x12cde8fff +com.mainconcept.mc.enc.avcsr (10.3 - 10.3.16.2760) <12B6B1FB-3BEA-31BE-ADEC-56F1DD44B24E> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_enc_avcsr.framework/Versions/10/mc_enc_avcsr
0x12cdee000 - 0x12cdf4ff7 +com.mainconcept.mc.enc.mp2sr (10.3 - 10.3.16.2760) <4075B0DA-51D1-3D8B-A169-DBEAE6C5D875> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_enc_mp2sr.framework/Versions/10/mc_enc_mp2sr
0x12cdfa000 - 0x12ce04fff +libMXF_SDK_GenericContainer_AES3.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_AES3.dylib.4.5.16
0x12ce0d000 - 0x12ce18ff7 +libMXF_SDK_GenericContainer_AES3_S302M.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_AES3_S302M.dylib.4.5.16
0x12cff2000 - 0x12cff6fff libFontRegistryUI.dylib (155.2) <8346E80E-5832-3944-A750-FBB9D328C2FE> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
0x12fac2000 - 0x12fac2ff7 +com.adobe.Mosaic.framework (11.1.0 - 11.1.0.0) <54FB1E3F-9B22-3CE7-97E9-4D24397C24EA> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/Mosaic.bundle/Contents/MacOS/Mosaic
0x12facb000 - 0x12fad1fff +libMXF_SDK_GenericContainer_AVI.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_AVI.dylib.4.5.16
0x12fad6000 - 0x12fadcfff +libMXF_SDK_Modules_DataIO.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_Modules_DataIO.dylib.1.4.22
0x12fb46000 - 0x12fb53fff +libMXF_SDK_GenericContainer_D10.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_D10.dylib.4.5.16
0x12fb5b000 - 0x12fb76fe7 +libMXF_SDK_GenericContainer_DV.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_DV.dylib.4.5.16
0x12fb88000 - 0x12fb92fff +libMXF_SDK_GenericContainer_MPEG_MPEGPS.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MPEGPS.dylib.4.5.16
0x1302d9000 - 0x1302dafff +com.adobe.Bevel_Edges.framework (11.1.0 - 11.1.0.0) <4F3AC3C1-5983-33BE-B241-BD62B6640CE1> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/Bevel_Edges.bundle/Contents/MacOS/Bevel_Edges
0x1302e7000 - 0x1302e9fff +com.adobe.Opacity.framework (11.1.0 - 11.1.0.0) <2A4963DA-8698-3FBB-826D-0AE02AB3B9A3> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/Opacity.bundle/Contents/MacOS/Opacity
0x130304000 - 0x13030bfff +libMXF_SDK_GenericContainer_MPEG_AVCProxy.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_AVCProxy.dylib.1.4.22
0x130320000 - 0x130324fff com.apple.audio.AppleHDAHALPlugIn (274.12 - 274.12) <F5E4849C-6A2D-3D2C-AB3F-F608C0E49FD5> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1305ac000 - 0x1305d5fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
0x130607000 - 0x130607fe7 +cl_kernels (???) <ABF26AAA-B782-4F81-B2F1-2A0A6A4AF7EF> cl_kernels
0x1306d3000 - 0x13070bff7 +libMOG_Framework.dylib.2.2.17 (2.2.17) <43BC0118-237D-83F3-CC87-D303000E6DEF> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMOG_Framework.dylib.2.2.17
0x13072a000 - 0x130739ff7 +libMXF_SDK_GenericContainer_JPEG2000.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_JPEG2000.dylib.4.5.16
0x130746000 - 0x130751fef +libMXF_SDK_GenericContainer_MPEG_ESAudio.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_ESAudio.dylib.4.5.16
0x130845000 - 0x130856fef +libMXF_SDK_GenericContainer_MPEG_MPEG2Video.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MPEG2Video.dylib.4.5.16
0x130863000 - 0x130877fef +libMXF_SDK_GenericContainer_MPEG_MPEG4.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MPEG4.dylib.4.5.16
0x130882000 - 0x13088efff +libMXF_SDK_GenericContainer_MPEG_MPEGTS.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MPEGTS.dylib.4.5.16
0x130896000 - 0x1308a0fff +libMXF_SDK_GenericContainer_SystemScheme1.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_SystemScheme1.dylib.4.5.16
0x1308a9000 - 0x1308bbfff +libMXF_SDK_GenericContainer_Wave.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_Wave.dylib.4.5.16
0x1308cb000 - 0x1308d6fff +libMXF_SDK_Metadata_RP224.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_Metadata_RP224.dylib.4.5.16
0x1308dd000 - 0x1308eeff7 +libMXF_SDK_MetaMetadata_BinaryLoader.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_MetaMetadata_BinaryLoader.dylib.4.5.16
0x1308fe000 - 0x130916ffb +libMXF_SDK_MetaMetadata_XSDLoader.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_MetaMetadata_XSDLoader.dylib.4.5.16
0x130927000 - 0x13092eff7 +libMXF_SDK_GenericContainer_Binary.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_Binary.dylib.1.4.22
0x13095f000 - 0x130961fff +com.adobe.Motion.framework (11.1.0 - 11.1.0.0) <0E07C98C-A2E8-3208-9391-CF5388B2047A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/Motion.bundle/Contents/MacOS/Motion
0x130a4c000 - 0x130a6effa +libMXF_SDK_MetaMetadata_XSDLoader2.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_MetaMetadata_XSDLoader2.dylib.4.5.16
0x130a86000 - 0x130a96fff +libMXF_SDK_GenericContainer_AIFF.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_AIFF.dylib.1.4.22
0x130aa2000 - 0x130aaffff +libMXF_SDK_GenericContainer_Blind.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_Blind.dylib.1.4.22
0x130ab8000 - 0x130ac4fff +libMXF_SDK_GenericContainer_MPEG_AAC.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_AAC.dylib.1.4.22
0x130acd000 - 0x130adcff8 +libMXF_SDK_GenericContainer_MPEG_AVCUltra.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_AVCUltra.dylib.1.4.22
0x130aec000 - 0x130af2fff +libMXF_SDK_Metadata_AS11.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_Metadata_AS11.dylib.1.4.22
0x130d00000 - 0x130e02ff7 com.apple.AMDMTLBronzeDriver (1.42.15 - 1.4.2) <203DB752-C67A-3BD2-87DC-700B14CA24F2> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x154a5c000 - 0x154a9eff7 +com.adobe.ImporterMPEG.framework (11.1.0 - 11.1.0.0) <182A4E09-C48D-35A7-A38E-9B3151C4531E> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/ImporterMPEG.bundle/Contents/MacOS/ImporterMPEG
0x155400000 - 0x155407ff7 +com.adobe.AEFilterSDRConform.framework (11.1.0 - 11.1.0.0) <CC86D1ED-9699-3CDC-BD4C-88A63C0509E5> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/AEFilterSDRConform.bundle/Contents/MacOS/AEFilterSDRConform
0x155414000 - 0x155416ff7 +com.adobe.AEFilterAlphaAdjust.framework (11.1.0 - 11.1.0.0) <73CBE202-0CE1-345C-92B6-B0DA95D7EDC2> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/AEFilterAlphaAdjust.bundle/Contents/MacOS/AEFilterAlphaAdjust
0x15541d000 - 0x155423ff7 +com.adobe.AEFilterClipName.framework (11.1.0 - 11.1.0.0) <94ADAEFB-F3D1-3B57-89B7-FCE9BA7A8AC6> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/AEFilterClipName.bundle/Contents/MacOS/AEFilterClipName
0x155430000 - 0x155435ff7 +com.adobe.AEFilterVideoLimiter.framework (11.1.0 - 11.1.0.0) <F059CBF0-5B8E-3EAF-99AB-74F227C5DF9D> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/AEFilterVideoLimiter.bundle/Contents/MacOS/AEFilterVideoLimiter
0x155cfe000 - 0x155d18ff7 +com.adobe.ImporterJPEG.framework (11.1.0 - 11.1.0.0) <C4C6D7D3-203F-3C34-A21B-B443ED2AED09> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/ImporterJPEG.bundle/Contents/MacOS/ImporterJPEG
0x15656b000 - 0x156571fff +com.adobe.AEFilterCrop.framework (11.1.0 - 11.1.0.0) <D8283A3D-CD42-3A4D-A811-EB3F22141DF4> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/AEFilterCrop.bundle/Contents/MacOS/AEFilterCrop
0x15657b000 - 0x156584fff +com.mainconcept.mc.config.mp2v (10.3 - 10.3.16.2760) <C2781FE8-8DD4-3172-84A0-8BE0351CA997> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_config_mp2v.framework/mc_config_mp2v
0x156637000 - 0x15664dff7 +com.adobe.ImporterFastMPEG.framework (11.1.0 - 11.1.0.0) <FDE7EECC-AF29-36AA-AEAA-6421E16B298C> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/ImporterFastMPEG.bundle/Contents/MacOS/ImporterFastMPEG
0x156c8c000 - 0x156cb9fff +com.adobe.EASequenceRenderer.framework (11.1.0 - 11.1.0.0) <9143174A-BA11-3916-AB4F-3D29A3871B6A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/EASequenceRenderer.bundle/Contents/MacOS/EASequenceRenderer
0x157d68000 - 0x157f38fe7 +com.adobe.PremierePro.OpenEXR (1.0 - 1.0) <5923A225-A8ED-05D1-CA50-B4A7EFA35DF0> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/OpenEXR Premiere.bundle/Contents/MacOS/OpenEXR Premiere
0x158101000 - 0x158110ff7 +com.adobe.PremiereFiltersMetaPlugin.framework (11.1.0 - 11.1.0.0) <8523A4B4-191C-3F68-A045-85717E20BA41> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/PremiereFiltersMetaPlugin
0x158129000 - 0x158138ff7 +com.adobe.TransitionsMetaPlugin.framework (11.1.0 - 11.1.0.0) <74152BDE-F165-3389-B303-8406F46BDA12> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsMetaPlugin
0x158152000 - 0x158154ff7 +com.adobe.TransmitDesktopAudio.framework (11.1.0 - 11.1.0.0) <2D8D3621-3198-30DD-BEE1-264D6988FE62> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/TransmitDesktopAudio.bundle/Contents/MacOS/TransmitDesktopAudio
0x15815e000 - 0x15816ffff +com.adobe.TransmitDV.framework (11.1.0 - 11.1.0.0) <DFA9FC7D-4511-3245-B7E5-D1C91A8DEE53> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/TransmitDV.bundle/Contents/MacOS/TransmitDV
0x15818a000 - 0x1581b4ff7 com.apple.AVCVideoServices (1.0 - 42) <831901D9-100A-38FC-8FB9-AAA43862500F> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
0x1581f1000 - 0x158646fff +quvis.wraptor (1.0 - 1) <540DAE90-F54B-3780-861A-D694BFB06310> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/wraptor.bundle/Contents/MacOS/wraptor
0x158af7000 - 0x158afcfff +com.adobe.TransmitFullScreen.framework (11.1.0 - 11.1.0.0) <18471905-AC91-33F4-B36C-FC6E3322F309> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/TransmitFullScreen.bundle/Contents/MacOS/TransmitFullScreen
0x158b0a000 - 0x158ce5ff7 +com.adobe.TransmitScopes.framework (11.1.0 - 11.1.0.0) <621BC847-8129-3322-B58B-E5A042130D0B> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/TransmitScopes.bundle/Contents/MacOS/TransmitScopes
0x15a4f2000 - 0x15a54fff7 +com.adobe.PlayerMediaCore.framework (11.1.0 - 11.1.0.0) <DAE6F2EA-A6F1-3336-A3AC-3E7255648E4B> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
0x15a5ae000 - 0x15a5dbfff +com.adobe.RendererCPU.framework (11.1.0 - 11.1.0.0) <DC34E8F9-69DE-352E-98F7-B5B711759A27> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/RendererCPU.framework/Versions/A/RendererCPU
0x15a615000 - 0x15a61dfff +com.adobe.ExporterCoreAudio.framework (11.1.0 - 11.1.0.0) <90A5DEAD-9E07-380D-9DCE-66C03289F929> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCoreAudio
0x15a62b000 - 0x15a634fff +com.adobe.AudioConverter.framework (11.1.0 - 11.1.0.0) <DEC8B2F6-65E8-3014-81AB-7FCEE8C4A8CE> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
0x15a646000 - 0x15a776ffb com.apple.audio.units.Components (1.13 - 1.13) <69FC51F9-E779-3940-AA27-8F97A9849D51> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x15a829000 - 0x15ab22ff7 com.apple.audio.codecs.Components (6.0 - 6.0) <BF8186C2-6A22-33D0-9DD0-2E1FD25D175D> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x15abd7000 - 0x15ac2fff7 +com.adobe.ExporterQuickTimeHost.framework (11.1.0 - 11.1.0.0) <083C96D5-7BAD-3A3C-809C-6DAA3DB98E3F> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQuickTimeHost
0x15ac7f000 - 0x15ac99fff +com.adobe.QTWriter.framework (11.1.0 - 11.1.0.0) <2497B2F3-47E2-31E3-83C6-60B59706B553> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/QTWriter.framework/Versions/A/QTWriter
0x15acc4000 - 0x15acf4fff +com.adobe.QTParser.framework (11.1.0 - 11.1.0.0) <4BA1C49B-C7C0-35FB-BA25-3E162B8A1165> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
0x15ad1a000 - 0x15b0e4fe7 +com.adobe.ImporterQuickTime.framework (11.1.0 - 11.1.0.0) <30AF64C2-3BA2-3A97-80C2-DC14792B3B21> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/ImporterQuickTime.bundle/Contents/MacOS/ImporterQuickTime
0x15b31d000 - 0x15b346fff +com.adobe.PlatformAudioCodecs.framework (11.1.0 - 11.1.0.0) <C3FFA4B7-0ABD-3715-B511-479A99C77180> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/PlatformAudioCodecs.framework/Versions/A/PlatformAudioCodecs
0x15b370000 - 0x15b45efff +com.mainconcept.mc.demux.mp2 (10.3 - 10.3.16.2760) <4FB5A4BE-28E6-3ACE-92BC-438107791D65> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_demux_mp2.framework/Versions/10/mc_demux_mp2
0x15bb00000 - 0x15c22dffb +com.aja.RecordAJADpx (13.0.0.9 - 13.0.0.9) <30483563-FDD8-3CC6-9F14-E69EED361C02> /Library/Application Support/Adobe/*/RecordAJADpx.bundle/RecordAJADpx
0x15c8f2000 - 0x15c93bfff +com.mainconcept.mc_dec_dv100 (8.5 - 8.5.0.14265) <CBD18884-E94E-1238-27B2-8AB0E4531DD1> /Library/Frameworks/mc_dec_dv100.framework/Versions/8.5/mc_dec_dv100
0x15c998000 - 0x15c9dfff1 +com.mainconcept.mc_enc_dv100 (8.5 - 8.5.0.14265) <541CA5F5-D4C5-F91A-1CC8-C8FC49FAF2C5> /Library/Frameworks/mc_enc_dv100.framework/Versions/8.5/mc_enc_dv100
0x15ca32000 - 0x15cf81fef +libDNxHR.dylib (0) <C115436D-D23B-3852-A325-910223FC4209> /Library/Application Support/AJA/libDNxHR.dylib
0x15d39e000 - 0x15dacbffb +com.aja.RecordAJAMov (13.0.0.9 - 13.0.0.9) <074049C9-1695-331E-BEF5-C33B6FD05A06> /Library/Application Support/Adobe/*/RecordAJAMov.bundle/RecordAJAMov
0x15e161000 - 0x15e88effb +com.aja.RecordAJAMxf (13.0.0.9 - 13.0.0.9) <5C69C68B-B490-388D-9DD2-73A62AB6546C> /Library/Application Support/Adobe/*/RecordAJAMxf.bundle/RecordAJAMxf
0x15eac7000 - 0x15ead6fff +com.mainconcept.mc.enc.mpa (10.3 - 10.3.16.2760) <C252F151-C028-36B6-8105-752FDC2FF7E9> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/10/mc_enc_mpa
0x15ef61000 - 0x15f638ffb +com.aja.TransmitAJA (13.0.0.9 - 13.0.0.9) <E93B1275-B482-38F0-8CEA-3B55C5BE78C7> /Library/Application Support/Adobe/*/TransmitAJA.bundle/TransmitAJA
0x15f904000 - 0x15f938fff +com.adobe.ExporterMPEGPreview.framework (11.1.0 - 11.1.0.0) <39847331-D6AE-3DE8-A0D1-4F2F8FA39A7F> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Contents/MacOS/ExporterMPEGPreview
0x15f95c000 - 0x15fb47fef +com.mainconcept.mc.enc.mp2v (10.3 - 10.3.16.2760) <03DE4309-A614-3479-89CF-422793A32180> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/10/mc_enc_mp2v
0x15fb97000 - 0x15fc9cff7 +com.mainconcept.mc.mux.mp2 (10.3 - 10.3.16.2760) <28CF26EC-C1AA-3487-9FBD-EEDBEADD267D> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/10/mc_mux_mp2
0x15fcb2000 - 0x15fcebff7 +com.mainconcept.mc.enc.aac (10.3 - 10.3.16.2760) <62A9C22E-74F3-32EF-B8E2-4F68B60CC3AC> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_enc_aac.framework/Versions/10/mc_enc_aac
0x15fcf1000 - 0x15fd8bff7 +com.adobe.IPPMPEGDecoder.framework (11.1.0 - 11.1.0.0) <18318F11-95B2-3BFA-8C0C-5CB1C0A600AD> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
0x15ffe0000 - 0x15ffe2fff +com.adobe.Color_Key.framework (11.1.0 - 11.1.0.0) <4F428532-398F-33A0-A64B-C55CB2E4B1C8> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/Color_Key.bundle/Contents/MacOS/Color_Key
0x160c2d000 - 0x160ca7ff7 com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
0x160e00000 - 0x160f4bfef +IMSLib.dylib (10.0.0.19 - 10.0.0.19) <32EDDC00-4237-3F41-8B49-8B8010FAA72B> /Library/Application Support/Adobe/*/IMSLib.dylib
0x161600000 - 0x16166dfff +com.adobe.ICUData (4.0 - 3.61) <604A18BB-29F6-34EC-98D4-3CC65EA9298C> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x161671000 - 0x1616a3ff7 +com.adobe.ARE (AdobeARE 1.5.02.37848 - 1.5.02.37848) <D414F78A-3CFE-3615-BE21-59B32D3B7031> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
0x1616bb000 - 0x1616c2fff +com.adobe.Basic_3D.framework (11.1.0 - 11.1.0.0) <F1023CA0-3156-3E33-8224-9640B616C693> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/Basic_3D.bundle/Contents/MacOS/Basic_3D
0x1616c8000 - 0x1616d8fff +libMXF_SDK_GenericContainer_MPEG_MP4.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MP4.dylib.1.4.22
0x1616f2000 - 0x1616f6ff7 +com.adobe.Twirl.framework (11.1.0 - 11.1.0.0) <FD9505FF-E68E-3F69-9416-15995204BC08> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/Twirl.bundle/Contents/MacOS/Twirl
0x161b3a000 - 0x161be4ff7 +com.adobe.ExporterXDCAMHD.framework (11.1.0 - 11.1.0.0) <F2B4E27E-4D48-3296-AEE9-6640A3BF7398> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/ExporterXDCAMHD.bundle/Contents/MacOS/ExporterXDCAMHD
0x161c87000 - 0x161c9aff2 +libMXF_SDK_GenericContainer_MPEG_XAVC.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_XAVC.dylib.1.4.22
0x161d23000 - 0x161d36fff +libMXF_SDK_GenericContainer_VC3.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_VC3.dylib.1.4.22
0x1624f6000 - 0x162886fef +com.adobe.AEFilterLumetri.framework (11.1.0 - 11.1.0.0) <37563F19-4CD8-351B-8B62-B05F3B4588C8> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/AEFilterLumetri.bundle/Contents/MacOS/AEFilterLumetri
0x162b43000 - 0x162b75ff7 +com.adobe.pip (7.4.1.63.45453) <D4D5717C-769F-3DC1-862F-17F5ED9D9482> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x162f81000 - 0x162fbdff0 +libMXF_SDK_GenericContainer_MPEG_AVC.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_AVC.dylib.1.4.22
0x16346a000 - 0x16348bfff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.37744 - 3.8.0.37744) <3FAB06F9-F9E9-378B-B3AC-96BA820313E1> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x16379e000 - 0x1637d8ffb +libMXF_SDK_MXFIO_AS11.dylib.1.4.22 (1.4.22) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_MXFIO_AS11.dylib.1.4.22
0x163a00000 - 0x163a32ffb +libMXF_SDK_XMLBuilder.dylib.1.4.22 (1.4.22) <9DE9CD76-E9E8-96DB-B688-791EAEF92854> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_XMLBuilder.dylib.1.4.22
0x16edc1000 - 0x16eddcfff com.apple.security.csparser (3.0 - 57337.60.2) <EE79884A-DBF8-340D-96D2-F92FE4E66C67> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x17b720000 - 0x17b7c2ff7 +com.adobe.ICUConverter (4.0 - 3.61) <4D6A813A-56D5-3CE1-8743-2BA65500FD20> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
0x1809c8000 - 0x1811bef77 +com.adobe.AEFilterMask.framework (11.1.0 - 11.1.0.0) <074E7457-F5FA-3C29-AD0E-C04808915A91> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/AEFilterMask.bundle/Contents/MacOS/AEFilterMask
0x1812d0000 - 0x181390ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.38312) <3115468A-6DA5-3FC4-90D2-8E0190C45CAD> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x1813d6000 - 0x1814c7ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <431F0368-6F63-3B0D-A215-D6866EEACA9A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
0x181512000 - 0x181878ff3 +com.adobe.MPS (AdobeMPS 5.8.1.37738 - 5.8.1.37738) <E8A7236E-77EE-36B6-A6DA-FD59BDE448CA> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x1818eb000 - 0x18203aff3 +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.37738) <D7F246E8-240F-3298-92BB-642E03664660> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
0x18258b000 - 0x1826bffff +com.adobe.AIDE (1.5.0 - 1.5.0.37764) <2EF02D99-49E9-3912-9459-0205DB83FD37> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
0x182ca7000 - 0x182cb2fff +com.adobe.Corner_Pin.framework (11.1.0 - 11.1.0.0) <E1F6A9C8-6C02-3099-800A-D96FAD949018> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/Corner_Pin.bundle/Contents/MacOS/Corner_Pin
0x1854e4000 - 0x186a65fc7 +com.adobe.Stabilizer.framework (11.1.0 - 11.1.0.0) <F6E735E6-AEF3-3BDA-9420-3E734FDCEC2E> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/Stabilizer.bundle/Contents/MacOS/Stabilizer
0x18a4c7000 - 0x18a4c7ff7 +com.adobe.dvahapticcore.framework (9.1.0 - 9.1.0.0) <0A26F94F-8D32-32CE-B5C0-970C6FD8D32D> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/dvahapticcore.framework/dvahapticcore
0x18a4cc000 - 0x18a4d1fff libgermantok.dylib (17) <B230A9A9-EC4C-306C-8C65-7143285DA142> /usr/lib/libgermantok.dylib
0x18a617000 - 0x18a620ff7 +com.adobe.AEFilterTimecode.framework (11.1.0 - 11.1.0.0) <D4988CE5-49EE-3E43-94E4-443E8F627F8E> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/AEFilterTimecode.bundle/Contents/MacOS/AEFilterTimecode
0x190290000 - 0x1905fcfef +com.mainconcept.mc.bc.enc.avc (10.3 - 10.3.16.2760) <F66FE8EA-61C8-3D25-987E-9E63B0052F82> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_bc_enc_avc.framework/Versions/10/mc_bc_enc_avc
0x19072d000 - 0x190941fff +libMXF_SDK.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK.dylib.4.5.16
0x190ae1000 - 0x19118dfff +libMXF_SDK_XMLUtils.dylib.4.5.16 (4.5.16) /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_XMLUtils.dylib.4.5.16
0x19d48b000 - 0x19d6b1ff7 +com.mainconcept.mc.demux.mp4 (10.3 - 10.3.16.2760) <D700793B-615B-3C71-A91B-136CA7B7181C> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_demux_mp4.framework/mc_demux_mp4
0x19fad0000 - 0x19fb0cfff +com.mainconcept.mc.dec.aac (10.3 - 10.3.16.2760) <05852DAB-BE5D-38D1-B265-5872BCE6322D> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Frameworks/mc_dec_aac.framework/mc_dec_aac
0x1b6a80000 - 0x1b6bbcff7 +com.adobe.ExporterMXF.framework (11.1.0 - 11.1.0.0) <6605D570-ABFD-3849-9F8B-D910F04DCCD2> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/ExporterMXF.bundle/Contents/MacOS/ExporterMXF
0x1baaf5000 - 0x1bac21fff +com.adobe.ExporterP2.framework (11.1.0 - 11.1.0.0) <C94B9E05-7E2A-3A6D-B943-017C648BA1FC> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/ExporterP2.bundle/Contents/MacOS/ExporterP2
0x1d4516000 - 0x1d451efff +com.adobe.ImporterWave.framework (11.1.0 - 11.1.0.0) <D4E879A8-2007-38BD-939D-D637A3FCEF6A> /Applications/Adobe Premiere Pro CC 2017/Adobe Premiere Pro CC 2017.app/Contents/Plug-Ins/Common/ImporterWave.bundle/Contents/MacOS/ImporterWave
0x7fff61116000 - 0x7fff6114da47 dyld (360.22) <DC81CC9D-651A-3A45-8809-928282052BD3> /usr/lib/dyld
0x7fff87c68000 - 0x7fff87c84ff7 libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
0x7fff87c85000 - 0x7fff87c95fff libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
0x7fff87c99000 - 0x7fff88effff3 com.apple.CoreGraphics (1.600.0 - 960.3) <A2DA51BA-7A97-33B9-97A1-979F6401989C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff88f00000 - 0x7fff88f53ff7 libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
0x7fff88f54000 - 0x7fff88fb2fff com.apple.CoreServices.OSServices (728.13 - 728.13) <27C12B92-7845-38DD-B82D-DC5B678352D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff89119000 - 0x7fff8913dff7 libJPEG.dylib (1459) <30F85216-E836-37B3-874E-62F1D040B098> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff89221000 - 0x7fff89223fff libCVMSPluginSupport.dylib (12.1) <D81B3D8D-B83F-3918-BD4B-6C794A30AF9F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff8922a000 - 0x7fff8922bfff com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff8954d000 - 0x7fff89716ff7 com.apple.ImageIO.framework (3.3.0 - 1459) <72B4D556-2600-3CA0-89F1-6BA24A4274B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff89717000 - 0x7fff8971dfff com.apple.IOAccelerator (205.11 - 205.11) <C51BF724-F8E8-3B9F-806E-A00C65056445> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff8971e000 - 0x7fff89726fff com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff89727000 - 0x7fff89727fff com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff89740000 - 0x7fff8998cff7 com.apple.AddressBook.framework (9.0 - 1679.10) <24F823D3-C3FC-3AF9-B8B3-C166539DBD11> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff8998d000 - 0x7fff899c7fff com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff899d3000 - 0x7fff899e4ff7 libsystem_trace.dylib (201.10.3) <1DD0C1FD-74E2-3949-9C2C-B81D19C2CA5E> /usr/lib/system/libsystem_trace.dylib
0x7fff899e5000 - 0x7fff89a43fff com.apple.SystemConfiguration (1.14 - 1.14) <D801FAD7-5A2D-3E5E-9F44-B6C9B8BEA747> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff89a97000 - 0x7fff89ad5ff7 libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff89aff000 - 0x7fff89b73ff7 com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff89b74000 - 0x7fff89b74fff com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff89b92000 - 0x7fff89b92fff com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff89bd6000 - 0x7fff89ce4ff3 com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff89ce8000 - 0x7fff89d15fff libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
0x7fff89d7d000 - 0x7fff89d80fff com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff89d81000 - 0x7fff8ae6aff3 com.apple.WebCore (11601 - 11601.7.5) <9153DA7E-1625-382A-8257-8D4293F06F7F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff8ae6b000 - 0x7fff8ae6bfff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8b084000 - 0x7fff8b09fff7 libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
0x7fff8b0a0000 - 0x7fff8b0c4fff com.apple.MultitouchSupport.framework (304.12 - 304.12) <65CB7653-EACD-3ADB-ABB6-2E0671708301> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8b253000 - 0x7fff8b2e0fef libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
0x7fff8b315000 - 0x7fff8b3ceff7 libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8b3cf000 - 0x7fff8b669ff3 com.apple.security (7.0 - 57337.60.2) <E2E553E7-28C4-3296-B3B6-BB1B3CA73943> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff8b66c000 - 0x7fff8b68bff7 com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff8b68f000 - 0x7fff8b68fff7 libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
0x7fff8b6ed000 - 0x7fff8b7a5ff7 com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff8c0de000 - 0x7fff8c123ff3 libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff8c124000 - 0x7fff8c12ffff com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff8c130000 - 0x7fff8c242fef libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff8c243000 - 0x7fff8c39eff3 com.apple.WebKitLegacy (11601 - 11601.7.7) <17A2118E-168F-312C-B083-81DC0BFA3C83> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff8c39f000 - 0x7fff8c3a8fff com.apple.IOAccelMemoryInfo (1.0 - 1) <5938394C-EAF4-37C7-A335-62D9A5DEC196> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff8d2b2000 - 0x7fff8d392ff7 unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
0x7fff8d39a000 - 0x7fff8d39efff libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
0x7fff8d3a6000 - 0x7fff8d43bfff com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff8d43c000 - 0x7fff8d7a7657 libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
0x7fff8d7ed000 - 0x7fff8d7f3fff com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff8d7f4000 - 0x7fff8d9fffff libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
0x7fff8da00000 - 0x7fff8da0cfff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff8da2e000 - 0x7fff8da74ff7 libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
0x7fff8da75000 - 0x7fff8da87fff libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
0x7fff8da88000 - 0x7fff8db10fff com.apple.CoreSymbolication (3.1 - 58048.1) <4730422E-4178-34F9-8550-BB92F2A4F44B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff8db11000 - 0x7fff8db12fff libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
0x7fff8dc45000 - 0x7fff8df83ff7 com.apple.WebKit (11601 - 11601.7.7) <29B8BA84-D78E-393B-BB36-4B9605372A5F> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff8e188000 - 0x7fff8e215dd7 com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff8e216000 - 0x7fff8e2acfff com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8e2ad000 - 0x7fff8e35dfff com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff8e3cf000 - 0x7fff8e3d7fff libGFXShared.dylib (12.1) <5A0C2493-200C-30BE-97D5-8E8C0B8E604D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff8e3d8000 - 0x7fff8e3ddff3 libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
0x7fff8e3df000 - 0x7fff8e3eafff libkxld.dylib (3248.60.10) <991CDFE9-AB87-321B-A4B2-5EFE64DDCF74> /usr/lib/system/libkxld.dylib
0x7fff8e5c7000 - 0x7fff8e5d1fff com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8e5d2000 - 0x7fff8e5d5fff libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff8e5fc000 - 0x7fff8e60afff com.apple.opengl (12.1.0 - 12.1.0) <0718DB60-BA4F-3CF7-A117-10A2515D931F> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8e60b000 - 0x7fff8e65aff7 com.apple.opencl (2.7.0 - 2.7.0) <39581F1A-04FE-3CCA-9118-E9BB9053F7A1> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff8e65b000 - 0x7fff8e65bfff com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff8e65c000 - 0x7fff8e6fcfff com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff8e9fb000 - 0x7fff8e9fbfff libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fff8e9fc000 - 0x7fff8ea0afff com.apple.IntlPreferences (2.0 - 192) <0108A3F2-6A11-30B1-965D-A167CC8131EC> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff8ea25000 - 0x7fff8ea7afff com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff8eb3b000 - 0x7fff8eb42ff7 libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
0x7fff8eb43000 - 0x7fff8eb8eff7 com.apple.CoreMediaIO (703.0 - 4791) <D8BC511D-0C1E-3686-9829-C874FDBE94CB> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff8eb8f000 - 0x7fff8ebbdff7 libsandbox.1.dylib (460.60.2) <DAB5D6F4-CDA9-3AEB-83FF-88F003D5B5E5> /usr/lib/libsandbox.1.dylib
0x7fff8eda0000 - 0x7fff8f2deff7 com.apple.MediaToolbox (1.0 - 1731.15.206) <119FFD0E-947D-3103-9221-458439F5764D> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff8f377000 - 0x7fff8f390fff com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff8f41e000 - 0x7fff8f4f7fff com.apple.CoreMedia (1.0 - 1731.15.206) <DE407384-39D5-3727-A78D-D22849D816C7> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff8f50b000 - 0x7fff8f530ff7 libPng.dylib (1459) <F98F6D50-BC82-3ED7-885F-FEE708E401CC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8f531000 - 0x7fff8f558fff com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff8f559000 - 0x7fff8f564ff7 libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
0x7fff8f56d000 - 0x7fff8f5fcfff com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff8f5fd000 - 0x7fff8fc9cff7 com.apple.JavaScriptCore (11601 - 11601.7.2) <4A888404-501D-38DE-921D-BA9AEEAC8243> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff8fc9d000 - 0x7fff8fca0fff libsystem_sandbox.dylib (460.60.2) <2A68B39C-B786-3A05-87A2-56E688469FB8> /usr/lib/system/libsystem_sandbox.dylib
0x7fff8fd7a000 - 0x7fff8fd8bff7 libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
0x7fff8fda3000 - 0x7fff8fdb8ff3 libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff8ff7b000 - 0x7fff900c0fff com.apple.QTKit (7.7.3 - 2943.12) <79EA2D04-09EC-3266-A5F7-A4AACA97FE1E> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff901ba000 - 0x7fff901c2fef libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
0x7fff9032a000 - 0x7fff90353fff libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
0x7fff90354000 - 0x7fff9035cfff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff9035d000 - 0x7fff903a9ff7 com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff904d8000 - 0x7fff90578fff com.apple.Metadata (10.7.0 - 972.34) <A58195C5-5D5C-32D5-8BBB-F4D32201E5AA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff90579000 - 0x7fff90594fff com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff90595000 - 0x7fff90596fff libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
0x7fff905c6000 - 0x7fff90634ff7 com.apple.ApplicationServices.ATS (377 - 394.4) <9779E916-0788-3CAC-B1EC-F68BCB12A2B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff90635000 - 0x7fff90a63fff com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff90a64000 - 0x7fff90a69fff com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff90a6a000 - 0x7fff90a76fff com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff90ae1000 - 0x7fff90ae6fff com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff90ae7000 - 0x7fff90af2fff libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
0x7fff90af3000 - 0x7fff90b9efff com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff90b9f000 - 0x7fff90bf1fff com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff90bf2000 - 0x7fff90c16fff com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff90cc3000 - 0x7fff9109bfef com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff9109c000 - 0x7fff910fcfff com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff910fd000 - 0x7fff9110cfe7 com.apple.AppleFSCompression (81.20.2 - 1.0) <2FE122A9-5265-320A-9600-FFC5CE4DE197> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff91145000 - 0x7fff91170ff7 com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff912c7000 - 0x7fff912c9fff com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff912ca000 - 0x7fff912e3fff com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff912e4000 - 0x7fff91f0dff7 com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff91f40000 - 0x7fff91f42fff com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff91f43000 - 0x7fff91f46ff7 com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff91f49000 - 0x7fff9223efff com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff9224f000 - 0x7fff92266fff com.apple.ScriptingBridge (1.3.3 - 68) <13D01EBC-D01E-3054-8C3C-3989BCF6370A> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fff92267000 - 0x7fff92290ff7 libxslt.1.dylib (14.4) <72CD1CA4-1FBD-3672-ADCE-A89AB741689A> /usr/lib/libxslt.1.dylib
0x7fff92291000 - 0x7fff922aeff7 com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <41378C0B-B56A-3A73-9BD0-E06FA1F87B8C> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff922b5000 - 0x7fff922bafff com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff92308000 - 0x7fff9230aff7 libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
0x7fff9230b000 - 0x7fff9236efff libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x7fff9236f000 - 0x7fff92382fff com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fff92383000 - 0x7fff923e9ff7 libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
0x7fff923ea000 - 0x7fff923eafff com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff923eb000 - 0x7fff9241cfff com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff92afc000 - 0x7fff92d8cff7 com.apple.RawCamera.bundle (6.19 - 844) <F14992BD-D9D8-36EE-8A51-989A220E1846> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff92d8d000 - 0x7fff92db6fff com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff92db7000 - 0x7fff92dcdfff com.apple.CoreMediaAuthoring (2.2 - 953) <5103EF2E-BB0A-302B-B8BB-CED301BC746B> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff931ab000 - 0x7fff931c0fff com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff931c1000 - 0x7fff931f2ff7 libtidy.A.dylib (15.17) <6859415D-7A43-384E-ABDD-AA6B2AA9FDCD> /usr/lib/libtidy.A.dylib
0x7fff9348f000 - 0x7fff934c2ff7 com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff934c3000 - 0x7fff9351eff7 libTIFF.dylib (1459) <CA5015CC-A770-3A62-BABD-B5A88AD390E6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff9351f000 - 0x7fff93a41fff com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff93a42000 - 0x7fff93a5eff7 libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
0x7fff941f4000 - 0x7fff941fffff com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff94200000 - 0x7fff942d6ffb com.apple.DiskImagesFramework (10.11.4 - 417.4) <B9525D22-6F0D-39C5-BA9B-9DF195FE1968> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff942ed000 - 0x7fff942fdfff libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff942fe000 - 0x7fff94327ff7 libxpc.dylib (765.50.8) <54D1328E-054E-3DAA-89E2-375722F9D18F> /usr/lib/system/libxpc.dylib
0x7fff94328000 - 0x7fff94338ff3 com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff94339000 - 0x7fff94362ffb libRIP.A.dylib (960.3) <702967FB-D16C-38C7-A3CC-0EC336740A69> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff94364000 - 0x7fff94368fff libGIF.dylib (1459) <58F85C45-96D2-3713-A8C0-B2579B419A80> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff943b9000 - 0x7fff943bbff7 libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
0x7fff9445a000 - 0x7fff94628ff3 com.apple.QuartzCore (1.11 - 410.14) <076BDE58-8AED-3D47-84FD-548CF8E8EDB9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff94629000 - 0x7fff94631ffb libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
0x7fff94645000 - 0x7fff94653fff com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fff94654000 - 0x7fff9473afef unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x7fff9473b000 - 0x7fff9475dfff com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff9475e000 - 0x7fff9488bff3 com.apple.CoreText (352.0 - 494.12) <ADBE8355-D4F5-3316-A6C4-D641D615CEC4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff948a2000 - 0x7fff94a20fff com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff94a21000 - 0x7fff94a53ff7 libTrueTypeScaler.dylib (158.6) <469A7620-3B6F-3E06-80A7-8D89E5DD9C81> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff94a54000 - 0x7fff94a56ff7 com.apple.securityhi (9.0 - 55006) <1E7BE52B-97EA-371A-AECA-1EE2AD246D8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff94a5e000 - 0x7fff94ba8ff7 com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff94ba9000 - 0x7fff94baafff libffi.dylib (18.1) <5BA9612C-747E-33CE-9DB1-3C01ECF3041D> /usr/lib/libffi.dylib
0x7fff94bb0000 - 0x7fff94bf1ff7 libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff94c47000 - 0x7fff94c98ff7 libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
0x7fff94c99000 - 0x7fff94cb0fff libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
0x7fff94cb7000 - 0x7fff94d70ff7 com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff94df6000 - 0x7fff94e6bfff com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff94ed6000 - 0x7fff94f45fff com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff94f51000 - 0x7fff950ddff7 libGLProgrammability.dylib (12.1) <BCFFBF6B-9717-3456-B6F9-6AE46644B076> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff950de000 - 0x7fff950e3ff7 libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
0x7fff950e7000 - 0x7fff9518efff com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff95200000 - 0x7fff9521aff3 liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
0x7fff9521b000 - 0x7fff9521dffb libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
0x7fff9521e000 - 0x7fff9524eff3 com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff9524f000 - 0x7fff954e5fff libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
0x7fff955ee000 - 0x7fff9563cff7 libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
0x7fff9575f000 - 0x7fff9578affb libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
0x7fff957d6000 - 0x7fff95827fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff95828000 - 0x7fff9582fff7 com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff95833000 - 0x7fff95cceffb com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff95ccf000 - 0x7fff95dbaff7 com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff95fed000 - 0x7fff9602aff3 com.apple.bom (14.0 - 193.7) <9B8AE30B-24A3-37AB-B04E-4CE67AED4775> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff9602b000 - 0x7fff9602bfff libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
0x7fff9602c000 - 0x7fff9605bffb com.apple.datadetectors (5.0 - 308) <1949868C-BDCD-3772-BDBD-D7E9F2CC1451> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
0x7fff9608a000 - 0x7fff960b9fff com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff9610b000 - 0x7fff96132fff com.apple.shortcut (2.16 - 93) <2BA6DF3E-04C7-39C8-B311-3413E9FC9022> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff96133000 - 0x7fff9613bfff libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
0x7fff96946000 - 0x7fff96962ff3 libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
0x7fff96963000 - 0x7fff969f2ff7 libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
0x7fff969f3000 - 0x7fff969f6fff com.apple.IOSurface (108.2.3 - 108.2.3) <52E51D16-42E9-3DDB-A16C-48225EF262C4> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff969f7000 - 0x7fff96a26ff7 com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff96a27000 - 0x7fff96a40fe7 libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
0x7fff96b80000 - 0x7fff96b8bfff libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff96be4000 - 0x7fff96d90ff7 com.apple.avfoundation (2.0 - 1046.9.12) <2D241BC4-A619-3382-BABD-C4E4490BD638> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff96d91000 - 0x7fff96dc0ffb libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
0x7fff96e92000 - 0x7fff96e9eff7 com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff96f03000 - 0x7fff96f7aff7 com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fff96f7b000 - 0x7fff96f99ff7 libsystem_kernel.dylib (3248.60.10) <C1A6A0B9-1869-36AB-B4A2-D862EB09A4BE> /usr/lib/system/libsystem_kernel.dylib
0x7fff96f9a000 - 0x7fff96f9cff7 libRadiance.dylib (1459) <1FE4F408-D135-3CA5-A06B-B0FCE974997C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff96f9d000 - 0x7fff96feffff com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff97124000 - 0x7fff97127fff libspindump.dylib (197.1) <48F4C673-9F0C-38BE-B550-88241E812518> /usr/lib/libspindump.dylib
0x7fff97165000 - 0x7fff97165fff com.apple.CoreServices (728.13 - 728.13) <E3DFECD2-ECEA-3242-972D-95B9646B57B8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff97183000 - 0x7fff971d3ff7 com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff97206000 - 0x7fff9724bff7 com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff9724c000 - 0x7fff97459fff libicucore.A.dylib (551.51.4) <3899B146-3840-3D4A-8C4A-FE391D5D25C7> /usr/lib/libicucore.A.dylib
0x7fff9745a000 - 0x7fff9747cff7 com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff9747d000 - 0x7fff974ecfff com.apple.datadetectorscore (7.0 - 460) <E8616F01-90AC-3863-B18C-426E6DD1ACDE> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff97550000 - 0x7fff97567ff7 libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
0x7fff9756e000 - 0x7fff97654ff7 libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff9765f000 - 0x7fff9765fff7 libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
0x7fff97660000 - 0x7fff97697ff7 com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff976cc000 - 0x7fff976cdff3 com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff97721000 - 0x7fff9774fff7 com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff97750000 - 0x7fff97758fff libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
0x7fff97a3f000 - 0x7fff97a41fff libCGXType.A.dylib (960.3) <70FA6D91-53BC-3DA6-92F3-7FEB33C73948> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff97ab1000 - 0x7fff97ac2fff libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
0x7fff97b3a000 - 0x7fff97b3bfff libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff97b3c000 - 0x7fff97b3dfff liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
0x7fff97b41000 - 0x7fff97b8dffb com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff97b8e000 - 0x7fff97b96fff com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff97b97000 - 0x7fff97ba2ff7 libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
0x7fff97c0e000 - 0x7fff97d00ff7 libJP2.dylib (1459) <90B4DD14-4D0B-3373-B1B6-DC8F53D78565> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff97d01000 - 0x7fff97d05fff libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
0x7fff98131000 - 0x7fff98131ff7 liblaunch.dylib (765.50.8) <834ED605-5114-3641-AA4D-ECF31B801C50> /usr/lib/system/liblaunch.dylib
0x7fff98724000 - 0x7fff9872ffff com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff98730000 - 0x7fff98732fff libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
0x7fff98733000 - 0x7fff9885afff com.apple.LaunchServices (728.13 - 728.13) <DF9A69C3-06AD-3062-A40A-50ED12CA18CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff9886c000 - 0x7fff988a0ff7 com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff988a5000 - 0x7fff988a7fff com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff988a8000 - 0x7fff988aaff7 com.apple.SafariServices.framework (11601 - 11601.7.7) <4BCAFAC2-CB87-31A1-A27B-B4794B2F8535> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff988ab000 - 0x7fff988b4ff7 libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
0x7fff988c0000 - 0x7fff988c1ffb libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
0x7fff988c5000 - 0x7fff9897ffff com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff98980000 - 0x7fff98988fff com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff98989000 - 0x7fff9898cffb libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
0x7fff98a2f000 - 0x7fff98a96fff com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff98a97000 - 0x7fff98b93ff7 libFontParser.dylib (158.6) <267A9AE4-4138-3112-8D73-BDFDC96568FF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff98d1d000 - 0x7fff98da6ff7 com.apple.PerformanceAnalysis (1.0 - 1) <1BC106BB-3C7F-37C9-8496-43F584A6F304> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff98da7000 - 0x7fff98dd1ff7 GLRendererFloat (12.1) <BE957AC5-82C2-3620-A625-56C9BE7B853F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff98dd2000 - 0x7fff98dd2fff com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff9903e000 - 0x7fff99042fff com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff99043000 - 0x7fff99062ff7 com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff990d1000 - 0x7fff99358fff com.apple.CFNetwork (760.6.3 - 760.6.3) <8CB9CB2E-D0FB-31D4-A1AE-2A5FE028AD6B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff99359000 - 0x7fff9938ffff libssl.0.9.8.dylib (59.60.1) <C047F10D-A929-36C8-83DE-E8BB7183A158> /usr/lib/libssl.0.9.8.dylib
0x7fff99392000 - 0x7fff993a1ffb com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff99429000 - 0x7fff99431fff libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
0x7fff9943a000 - 0x7fff994aeff3 com.apple.securityfoundation (6.0 - 55126) <DAA4FDD0-7F84-30AA-BE6F-96BB9F871F07> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff994af000 - 0x7fff994b8ff7 com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff994b9000 - 0x7fff9980dfff com.apple.Foundation (6.9 - 1259) <71A9D3A0-0B1F-3E3A-86F3-1486365A6EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff9980e000 - 0x7fff99813ff7 com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
0x7fff99820000 - 0x7fff99872fff com.apple.AppleVAFramework (5.0.32 - 5.0.32) <271ED7A9-73E5-3595-A8D6-28594C9F3C9D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff998af000 - 0x7fff99b55ff7 com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff99b56000 - 0x7fff99b61fff libGPUSupportMercury.dylib (12.1) <9D35C668-4F21-31C8-890C-CC1F45905194> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff99b62000 - 0x7fff99b79ff7 libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
0x7fff99b7f000 - 0x7fff99b95ff7 libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff99b96000 - 0x7fff99b98ff7 com.apple.xpc.ServiceManagement (1.0 - 1) <D96D7A6D-EDEB-35EE-B5D9-E33A3BF011B5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff99b99000 - 0x7fff99baefff com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fff99baf000 - 0x7fff99e1cfff com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff99fc2000 - 0x7fff99ffcff7 com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff9a015000 - 0x7fff9a015fff libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
0x7fff9a051000 - 0x7fff9a053fff com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff9a109000 - 0x7fff9a10efff com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff9a10f000 - 0x7fff9a2baffb GLEngine (12.1) <299D9296-2984-3967-9049-A842B99E5D43> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff9a2bb000 - 0x7fff9a731fff com.apple.CoreFoundation (6.9 - 1258.1) <943A1383-DA6A-3DC0-ABCD-D9AEB3D0D34D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff9a732000 - 0x7fff9a73bff7 com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff9ac42000 - 0x7fff9ac4efff com.apple.HelpData (2.1.4 - 90) <10608EEC-B613-309C-96E6-5A40AB951FA4> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff9ad93000 - 0x7fff9ada6fff com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff9ada7000 - 0x7fff9aec4fff libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
0x7fff9af7b000 - 0x7fff9af7cffb libSystem.B.dylib (1226.10.1) <ECAA07BE-A114-3461-AA13-C57838775FC2> /usr/lib/libSystem.B.dylib
0x7fff9afe3000 - 0x7fff9b031fff libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
0x7fff9b032000 - 0x7fff9b038ff7 com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff9b0b2000 - 0x7fff9b0c6fff com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff9b0c7000 - 0x7fff9b26dff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff9b557000 - 0x7fff9b83cffb com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff9b83d000 - 0x7fff9b84bfff libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
0x7fff9b84c000 - 0x7fff9bd0afcf com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff9bd0b000 - 0x7fff9bdfaff7 libxml2.2.dylib (29.10) <B3B03292-7E1A-34AB-888C-3D49D63D60C6> /usr/lib/libxml2.2.dylib
0x7fff9c1b7000 - 0x7fff9c1baff7 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff9c1bb000 - 0x7fff9c1d7fff com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff9c1d8000 - 0x7fff9c3f9ff7 com.apple.CoreImage (11.4.0 - 366.4.19) <F5B7B115-E43A-3C61-A6AD-EFCDE7FC43A1> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff9c574000 - 0x7fff9c8efffb com.apple.VideoToolbox (1.0 - 1731.15.206) <19DD020F-128A-32B0-96A4-A51F111B549F> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff9dabf000 - 0x7fff9dbb1ff7 libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
0x7fff9dbb5000 - 0x7fff9dbbdfef libcldcpuengine.dylib (2.7.3) <385BE8CE-16D8-3FCB-8558-8EB744D3DFE6> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff9dbbe000 - 0x7fff9dc35feb libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
0x7fff9dc3d000 - 0x7fff9dc89fff com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff9dc8a000 - 0x7fff9dcccff7 com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff9dccd000 - 0x7fff9dcd2ff7 libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
0x7fff9dcd3000 - 0x7fff9dd77fff com.apple.Bluetooth (4.4.6 - 4.4.6f1) <F8E54D34-DAAB-319F-8AE7-F3C55CA0CC68> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff9de11000 - 0x7fff9de49ff7 com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff9de4a000 - 0x7fff9de58ff7 libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
0x7fff9de59000 - 0x7fff9de62fff com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fff9defa000 - 0x7fff9df24ff7 libc++abi.dylib (307.2) <922EFB36-0E9E-315B-8270-E81AC43472C0> /usr/lib/libc++abi.dylib
0x7fff9df25000 - 0x7fff9df28ff7 libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff9df29000 - 0x7fff9e0e9ffb libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff9e0ea000 - 0x7fff9e0edffb libdyld.dylib (360.22) <1F9FCF2C-5E94-3F2D-B4A5-1238587AA5C6> /usr/lib/system/libdyld.dylib
0x7fff9e0ee000 - 0x7fff9e159ff7 com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff9e183000 - 0x7fff9e19dfff com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff9e1c0000 - 0x7fff9e1c9ff3 libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
0x7fff9e1ca000 - 0x7fff9e5ccfff libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 15
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 2680
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=916.9M resident=0K(0%) swapped_out_or_unallocated=916.9M(100%)
Writable regions: Total=6.3G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=6.3G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
ATS (font support) 32.0M 8
ATS (font support) (reserved) 8K 3 reserved VM address space (unallocated)
Accelerate.framework 256K 3
Activity Tracing 2048K 2
CG backing stores 16.2M 5
CG image 128K 13
CG shared images 464K 12
CoreAnimation 168K 30
CoreUI image data 1376K 16
CoreUI image file 192K 4
Dispatch continuations 48.0M 2
Foundation 20K 3
Image IO 64K 2
Kernel Alloc Once 8K 3
MALLOC 1.1G 1360
MALLOC guard page 32K 7
Memory Tag 242 12K 2
Memory Tag 249 156K 3
OpenCL 1.1G 101
OpenGL GLSL 128K 3
Process Corpse Info 2048K 2
STACK GUARD 56.2M 51
Stack 32.5M 54
VM_ALLOCATE 3.9G 2498
VM_ALLOCATE (reserved) 1024K 2 reserved VM address space (unallocated)
__DATA 86.6M 750
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 343.7M 330
__TEXT 573.2M 609
__UNICODE 552K 2
mapped file 97.6M 40
shared memory 26.6M 18
TOTAL 7.4G 5909
TOTAL, minus reserved VM space 7.4G 5909
Process: Adobe CEF Helper [334]
Path: /Library/Application Support/Adobe/*/Adobe CEF Helper.app/Contents/MacOS/Adobe CEF Helper
Identifier: Adobe CEF Helper
Version: 4.2.0.211 (4.2.0.211)
Code Type: X86-64 (Native)
Parent Process: Creative Cloud [279]
Responsible: Adobe CEF Helper [334]
User ID: 503
Date/Time: 2017-07-31 18:14:40.586 -0700
OS Version: Mac OS X 10.11.6 (15G31)
Report Version: 11
Anonymous UUID: 39A11AF7-BAFF-7F8C-59E0-E68C066C08AB
Time Awake Since Boot: 9 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
Assertion failed: (gfx_plugin_data.fbindex == gfx_plugin_data.fbindex[i - 1] + 1), function validate_plugin_data, file /Library/Caches/com.apple.xbs/Sources/OpenGL/OpenGL-12.1/GFXShared/gfx_plugin.c, line 1417.
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff9734cf06 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff98c6c4ec pthread_kill + 90
2 libsystem_c.dylib 0x00007fff8b66c6df abort + 129
3 libsystem_c.dylib 0x00007fff8b633dd8 __assert_rtn + 321
4 libGFXShared.dylib 0x00007fff8e78ae86 gfxLoadPluginData + 1077
5 com.apple.opengl 0x00007fff8e9b916b 0x7fff8e9b7000 + 8555
6 com.apple.opengl 0x00007fff8e9b90c4 glcPluginCount + 23
7 com.apple.opengl 0x00007fff8e9c057e 0x7fff8e9b7000 + 38270
8 com.apple.opengl 0x00007fff8e9bf8a9 CGLChoosePixelFormat + 85
9 org.chromium.ContentShell.framework 0x000000010b3fbf7c 0x10959a000 + 31858556
10 org.chromium.ContentShell.framework 0x000000010b3fb5f1 0x10959a000 + 31856113
11 org.chromium.ContentShell.framework 0x000000010b3fb42c 0x10959a000 + 31855660
12 org.chromium.ContentShell.framework 0x000000010a03cc65 0x10959a000 + 11152485
13 org.chromium.ContentShell.framework 0x000000010a03c118 0x10959a000 + 11149592
14 org.chromium.ContentShell.framework 0x000000010a9c0ac6 0x10959a000 + 21129926
15 org.chromium.ContentShell.framework 0x000000010a9c00de 0x10959a000 + 21127390
16 org.chromium.ContentShell.framework 0x000000010a9ea085 0x10959a000 + 21299333
17 org.chromium.ContentShell.framework 0x000000010959cbb0 cef_execute_process + 192
18 com.adobe.acc.HEXHelper 0x000000010954cfc0 0x10951a000 + 208832
19 com.adobe.acc.HEXHelper 0x000000010951c93a 0x10951a000 + 10554
20 com.adobe.acc.HEXHelper 0x000000010951bca4 start + 52
Thread 1:
0 libsystem_kernel.dylib 0x00007fff9734d5e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff98c69578 _pthread_wqthread + 1283
2 libsystem_pthread.dylib 0x00007fff98c67341 start_wqthread + 13
Thread 2:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff9734defa kevent_qos + 10
1 libdispatch.dylib 0x00007fff8a0ab165 _dispatch_mgr_invoke + 216
2 libdispatch.dylib 0x00007fff8a0aadcd _dispatch_mgr_thread + 52
Thread 3:
Thread 4:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x00007fff566e4208 rdx: 0x0000000000000000
rdi: 0x0000000000000307 rsi: 0x0000000000000006 rbp: 0x00007fff566e4230 rsp: 0x00007fff566e4208
r8: 0x0000000000000000 r9: 0x0000000000000589 r10: 0x0000000008000000 r11: 0x0000000000000206
r12: 0x00007fff8e792895 r13: 0x0000000116236000 r14: 0x00007fff7aed3000 r15: 0x00007fff8e7927f8
rip: 0x00007fff9734cf06 rfl: 0x0000000000000206 cr2: 0x00007fff785e7008
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x10951a000 - 0x109586fff +com.adobe.acc.HEXHelper (4.2.0.211 - 4.2.0.211) <F612D3EE-ECFD-3654-AF66-0188702A30B6> /Library/Application Support/Adobe/*/Adobe CEF Helper.app/Contents/MacOS/Adobe CEF Helper
0x10959a000 - 0x10f4c0fa7 +org.chromium.ContentShell.framework (3.2987.1596.0 - 1596.0) <06D47B5B-C100-3AE8-A0CF-59BDEBD3FCA6> /Library/Application Support/Adobe/*/Chromium Embedded Framework.framework/Chromium Embedded Framework
0x10fc0e000 - 0x10fc45fff com.apple.audio.midi.CoreMIDI (1.10 - 88) <51E79766-51D8-3A95-A7FD-18E7E11528F3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x10fc6f000 - 0x10fc82ff7 com.apple.GameController (1.0 - 1) <5B98EABB-D27C-3381-9487-21B1C91BF9E8> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
0x10fc99000 - 0x10fcb2fff libexpat.1.dylib (12.60.1) <6BF318AC-F90F-3F16-99C2-6ADDE404E280> /usr/lib/libexpat.1.dylib
0x7fff6be49000 - 0x7fff6be80a47 dyld (360.22) <DC81CC9D-651A-3A45-8809-928282052BD3> /usr/lib/dyld
0x7fff88023000 - 0x7fff8803fff7 libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
0x7fff88040000 - 0x7fff88050fff libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
0x7fff88054000 - 0x7fff892baff3 com.apple.CoreGraphics (1.600.0 - 960.3) <A2DA51BA-7A97-33B9-97A1-979F6401989C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff892bb000 - 0x7fff8930eff7 libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
0x7fff8930f000 - 0x7fff8936dfff com.apple.CoreServices.OSServices (728.13 - 728.13) <27C12B92-7845-38DD-B82D-DC5B678352D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff894d4000 - 0x7fff894f8ff7 libJPEG.dylib (1459) <30F85216-E836-37B3-874E-62F1D040B098> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff895dc000 - 0x7fff895defff libCVMSPluginSupport.dylib (12.1) <D81B3D8D-B83F-3918-BD4B-6C794A30AF9F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff895e5000 - 0x7fff895e6fff com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff89908000 - 0x7fff89ad1ff7 com.apple.ImageIO.framework (3.3.0 - 1459) <72B4D556-2600-3CA0-89F1-6BA24A4274B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff89ad2000 - 0x7fff89ad8fff com.apple.IOAccelerator (205.11 - 205.11) <C51BF724-F8E8-3B9F-806E-A00C65056445> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff89ad9000 - 0x7fff89ae1fff com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff89ae2000 - 0x7fff89ae2fff com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff89afb000 - 0x7fff89d47ff7 com.apple.AddressBook.framework (9.0 - 1679.10) <24F823D3-C3FC-3AF9-B8B3-C166539DBD11> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff89d48000 - 0x7fff89d82fff com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff89d8e000 - 0x7fff89d9fff7 libsystem_trace.dylib (201.10.3) <1DD0C1FD-74E2-3949-9C2C-B81D19C2CA5E> /usr/lib/system/libsystem_trace.dylib
0x7fff89da0000 - 0x7fff89dfefff com.apple.SystemConfiguration (1.14 - 1.14) <D801FAD7-5A2D-3E5E-9F44-B6C9B8BEA747> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff89e52000 - 0x7fff89e90ff7 libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff89eba000 - 0x7fff89f2eff7 com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff89f2f000 - 0x7fff89f2ffff com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff89f4d000 - 0x7fff89f4dfff com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff89f91000 - 0x7fff8a09fff3 com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff8a0a3000 - 0x7fff8a0d0fff libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
0x7fff8a138000 - 0x7fff8a13bfff com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff8b226000 - 0x7fff8b226fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8b43f000 - 0x7fff8b45aff7 libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
0x7fff8b45b000 - 0x7fff8b47ffff com.apple.MultitouchSupport.framework (304.12 - 304.12) <65CB7653-EACD-3ADB-ABB6-2E0671708301> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8b60e000 - 0x7fff8b69bfef libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
0x7fff8b6d0000 - 0x7fff8b789ff7 libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8b78a000 - 0x7fff8ba24ff3 com.apple.security (7.0 - 57337.60.2) <E2E553E7-28C4-3296-B3B6-BB1B3CA73943> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff8ba27000 - 0x7fff8ba46ff7 com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff8ba4a000 - 0x7fff8ba4aff7 libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
0x7fff8c499000 - 0x7fff8c4deff3 libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff8c4df000 - 0x7fff8c4eafff com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff8c4eb000 - 0x7fff8c5fdfef libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff8d755000 - 0x7fff8d759fff libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
0x7fff8d761000 - 0x7fff8d7f6fff com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff8d7f7000 - 0x7fff8db62657 libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
0x7fff8dba8000 - 0x7fff8dbaefff com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff8dbaf000 - 0x7fff8ddbafff libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
0x7fff8ddbb000 - 0x7fff8ddc7fff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff8dde9000 - 0x7fff8de2fff7 libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
0x7fff8de30000 - 0x7fff8de42fff libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
0x7fff8de43000 - 0x7fff8decbfff com.apple.CoreSymbolication (3.1 - 58048.1) <4730422E-4178-34F9-8550-BB92F2A4F44B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff8decc000 - 0x7fff8decdfff libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
0x7fff8e543000 - 0x7fff8e5d0dd7 com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff8e5d1000 - 0x7fff8e667fff com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8e668000 - 0x7fff8e718fff com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff8e78a000 - 0x7fff8e792fff libGFXShared.dylib (12.1) <5A0C2493-200C-30BE-97D5-8E8C0B8E604D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff8e793000 - 0x7fff8e798ff3 libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
0x7fff8e79a000 - 0x7fff8e7a5fff libkxld.dylib (3248.60.10) <991CDFE9-AB87-321B-A4B2-5EFE64DDCF74> /usr/lib/system/libkxld.dylib
0x7fff8e982000 - 0x7fff8e98cfff com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8e98d000 - 0x7fff8e990fff libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff8e9b7000 - 0x7fff8e9c5fff com.apple.opengl (12.1.0 - 12.1.0) <0718DB60-BA4F-3CF7-A117-10A2515D931F> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8e9c6000 - 0x7fff8ea15ff7 com.apple.opencl (2.7.0 - 2.7.0) <39581F1A-04FE-3CCA-9118-E9BB9053F7A1> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff8ea16000 - 0x7fff8ea16fff com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff8ea17000 - 0x7fff8eab7fff com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff8edb6000 - 0x7fff8edb6fff libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fff8edb7000 - 0x7fff8edc5fff com.apple.IntlPreferences (2.0 - 192) <0108A3F2-6A11-30B1-965D-A167CC8131EC> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff8ede0000 - 0x7fff8ee35fff com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff8eef6000 - 0x7fff8eefdff7 libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
0x7fff8eefe000 - 0x7fff8ef49ff7 com.apple.CoreMediaIO (703.0 - 4791) <D8BC511D-0C1E-3686-9829-C874FDBE94CB> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff8ef4a000 - 0x7fff8ef78ff7 libsandbox.1.dylib (460.60.2) <DAB5D6F4-CDA9-3AEB-83FF-88F003D5B5E5> /usr/lib/libsandbox.1.dylib
0x7fff8f15b000 - 0x7fff8f699ff7 com.apple.MediaToolbox (1.0 - 1731.15.206) <119FFD0E-947D-3103-9221-458439F5764D> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff8f732000 - 0x7fff8f74bfff com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff8f7d9000 - 0x7fff8f8b2fff com.apple.CoreMedia (1.0 - 1731.15.206) <DE407384-39D5-3727-A78D-D22849D816C7> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff8f8c6000 - 0x7fff8f8ebff7 libPng.dylib (1459) <F98F6D50-BC82-3ED7-885F-FEE708E401CC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8f8ec000 - 0x7fff8f913fff com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff8f914000 - 0x7fff8f91fff7 libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
0x7fff8f928000 - 0x7fff8f9b7fff com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff8f9b8000 - 0x7fff90057ff7 com.apple.JavaScriptCore (11601 - 11601.7.2) <4A888404-501D-38DE-921D-BA9AEEAC8243> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff90058000 - 0x7fff9005bfff libsystem_sandbox.dylib (460.60.2) <2A68B39C-B786-3A05-87A2-56E688469FB8> /usr/lib/system/libsystem_sandbox.dylib
0x7fff90135000 - 0x7fff90146ff7 libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
0x7fff90336000 - 0x7fff9047bfff com.apple.QTKit (7.7.3 - 2943.12) <79EA2D04-09EC-3266-A5F7-A4AACA97FE1E> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff90575000 - 0x7fff9057dfef libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
0x7fff906e5000 - 0x7fff9070efff libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
0x7fff9070f000 - 0x7fff90717fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff90893000 - 0x7fff90933fff com.apple.Metadata (10.7.0 - 972.34) <A58195C5-5D5C-32D5-8BBB-F4D32201E5AA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff90934000 - 0x7fff9094ffff com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff90950000 - 0x7fff90951fff libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
0x7fff90981000 - 0x7fff909efff7 com.apple.ApplicationServices.ATS (377 - 394.4) <9779E916-0788-3CAC-B1EC-F68BCB12A2B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff909f0000 - 0x7fff90e1efff com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff90e1f000 - 0x7fff90e24fff com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff90e25000 - 0x7fff90e31fff com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff90e9c000 - 0x7fff90ea1fff com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff90eae000 - 0x7fff90f59fff com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff90fad000 - 0x7fff90fd1fff com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff9107e000 - 0x7fff91456fef com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff91457000 - 0x7fff914b7fff com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff91500000 - 0x7fff9152bff7 com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff91682000 - 0x7fff91684fff com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff91685000 - 0x7fff9169efff com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff9169f000 - 0x7fff922c8ff7 com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff922fe000 - 0x7fff92301ff7 com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff92304000 - 0x7fff925f9fff com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff92622000 - 0x7fff9264bff7 libxslt.1.dylib (14.4) <72CD1CA4-1FBD-3672-ADCE-A89AB741689A> /usr/lib/libxslt.1.dylib
0x7fff9264c000 - 0x7fff92669ff7 com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <41378C0B-B56A-3A73-9BD0-E06FA1F87B8C> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff92670000 - 0x7fff92675fff com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff926c3000 - 0x7fff926c5ff7 libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
0x7fff926c6000 - 0x7fff92729fff libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x7fff9272a000 - 0x7fff9273dfff com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fff9273e000 - 0x7fff927a4ff7 libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
0x7fff927a5000 - 0x7fff927a5fff com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff927a6000 - 0x7fff927d7fff com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff93172000 - 0x7fff93188fff com.apple.CoreMediaAuthoring (2.2 - 953) <5103EF2E-BB0A-302B-B8BB-CED301BC746B> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff93566000 - 0x7fff9357bfff com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff9387e000 - 0x7fff938d9ff7 libTIFF.dylib (1459) <CA5015CC-A770-3A62-BABD-B5A88AD390E6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff938da000 - 0x7fff93dfcfff com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff93dfd000 - 0x7fff93e19ff7 libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
0x7fff945af000 - 0x7fff945bafff com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff946a8000 - 0x7fff946b8fff libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff946b9000 - 0x7fff946e2ff7 libxpc.dylib (765.50.8) <54D1328E-054E-3DAA-89E2-375722F9D18F> /usr/lib/system/libxpc.dylib
0x7fff946f4000 - 0x7fff9471dffb libRIP.A.dylib (960.3) <702967FB-D16C-38C7-A3CC-0EC336740A69> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff9471f000 - 0x7fff94723fff libGIF.dylib (1459) <58F85C45-96D2-3713-A8C0-B2579B419A80> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff94774000 - 0x7fff94776ff7 libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
0x7fff94815000 - 0x7fff949e3ff3 com.apple.QuartzCore (1.11 - 410.14) <076BDE58-8AED-3D47-84FD-548CF8E8EDB9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff949e4000 - 0x7fff949ecffb libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
0x7fff94a00000 - 0x7fff94a0efff com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fff94af6000 - 0x7fff94b18fff com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff94b19000 - 0x7fff94c46ff3 com.apple.CoreText (352.0 - 494.12) <ADBE8355-D4F5-3316-A6C4-D641D615CEC4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff94c5d000 - 0x7fff94ddbfff com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff94e0f000 - 0x7fff94e11ff7 com.apple.securityhi (9.0 - 55006) <1E7BE52B-97EA-371A-AECA-1EE2AD246D8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff94e19000 - 0x7fff94f63ff7 com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff94f6b000 - 0x7fff94facff7 libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff95002000 - 0x7fff95053ff7 libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
0x7fff95054000 - 0x7fff9506bfff libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
0x7fff951b1000 - 0x7fff95226fff com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff95291000 - 0x7fff95300fff com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff95499000 - 0x7fff9549eff7 libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
0x7fff954a2000 - 0x7fff95549fff com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff955bb000 - 0x7fff955d5ff3 liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
0x7fff955d9000 - 0x7fff95609ff3 com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff9560a000 - 0x7fff958a0fff libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
0x7fff959a9000 - 0x7fff959f7ff7 libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
0x7fff95b1a000 - 0x7fff95b45ffb libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
0x7fff95b91000 - 0x7fff95be2fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff95be3000 - 0x7fff95beaff7 com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff9608a000 - 0x7fff96175ff7 com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff963e6000 - 0x7fff963e6fff libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
0x7fff96445000 - 0x7fff96474fff com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff964ee000 - 0x7fff964f6fff libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
0x7fff96d01000 - 0x7fff96d1dff3 libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
0x7fff96dae000 - 0x7fff96db1fff com.apple.IOSurface (108.2.3 - 108.2.3) <52E51D16-42E9-3DDB-A16C-48225EF262C4> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff96db2000 - 0x7fff96de1ff7 com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff96de2000 - 0x7fff96dfbfe7 libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
0x7fff96f3b000 - 0x7fff96f46fff libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff96f9f000 - 0x7fff9714bff7 com.apple.avfoundation (2.0 - 1046.9.12) <2D241BC4-A619-3382-BABD-C4E4490BD638> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff9714c000 - 0x7fff9717bffb libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
0x7fff9724d000 - 0x7fff97259ff7 com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff97336000 - 0x7fff97354ff7 libsystem_kernel.dylib (3248.60.10) <C1A6A0B9-1869-36AB-B4A2-D862EB09A4BE> /usr/lib/system/libsystem_kernel.dylib
0x7fff97355000 - 0x7fff97357ff7 libRadiance.dylib (1459) <1FE4F408-D135-3CA5-A06B-B0FCE974997C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff97358000 - 0x7fff973aafff com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff974df000 - 0x7fff974e2fff libspindump.dylib (197.1) <48F4C673-9F0C-38BE-B550-88241E812518> /usr/lib/libspindump.dylib
0x7fff97520000 - 0x7fff97520fff com.apple.CoreServices (728.13 - 728.13) <E3DFECD2-ECEA-3242-972D-95B9646B57B8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff9753e000 - 0x7fff9758eff7 com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff975c1000 - 0x7fff97606ff7 com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff97607000 - 0x7fff97814fff libicucore.A.dylib (551.51.4) <3899B146-3840-3D4A-8C4A-FE391D5D25C7> /usr/lib/libicucore.A.dylib
0x7fff97815000 - 0x7fff97837ff7 com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff97838000 - 0x7fff978a7fff com.apple.datadetectorscore (7.0 - 460) <E8616F01-90AC-3863-B18C-426E6DD1ACDE> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff9790b000 - 0x7fff97922ff7 libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
0x7fff97929000 - 0x7fff97a0fff7 libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff97a1a000 - 0x7fff97a1aff7 libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
0x7fff97a1b000 - 0x7fff97a52ff7 com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff97a87000 - 0x7fff97a88ff3 com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff97b0b000 - 0x7fff97b13fff libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
0x7fff97e6c000 - 0x7fff97e7dfff libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
0x7fff97ef5000 - 0x7fff97ef6fff libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff97ef7000 - 0x7fff97ef8fff liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
0x7fff97efc000 - 0x7fff97f48ffb com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff97f49000 - 0x7fff97f51fff com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff97f52000 - 0x7fff97f5dff7 libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
0x7fff97fc9000 - 0x7fff980bbff7 libJP2.dylib (1459) <90B4DD14-4D0B-3373-B1B6-DC8F53D78565> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff980bc000 - 0x7fff980c0fff libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
0x7fff984ec000 - 0x7fff984ecff7 liblaunch.dylib (765.50.8) <834ED605-5114-3641-AA4D-ECF31B801C50> /usr/lib/system/liblaunch.dylib
0x7fff98adf000 - 0x7fff98aeafff com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff98aeb000 - 0x7fff98aedfff libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
0x7fff98aee000 - 0x7fff98c15fff com.apple.LaunchServices (728.13 - 728.13) <DF9A69C3-06AD-3062-A40A-50ED12CA18CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff98c27000 - 0x7fff98c5bff7 com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff98c60000 - 0x7fff98c62fff com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff98c63000 - 0x7fff98c65ff7 com.apple.SafariServices.framework (11601 - 11601.7.7) <4BCAFAC2-CB87-31A1-A27B-B4794B2F8535> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff98c66000 - 0x7fff98c6fff7 libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
0x7fff98c7b000 - 0x7fff98c7cffb libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
0x7fff98d3b000 - 0x7fff98d43fff com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff98d44000 - 0x7fff98d47ffb libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
0x7fff98dea000 - 0x7fff98e51fff com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff98e52000 - 0x7fff98f4eff7 libFontParser.dylib (158.6) <267A9AE4-4138-3112-8D73-BDFDC96568FF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff990d8000 - 0x7fff99161ff7 com.apple.PerformanceAnalysis (1.0 - 1) <1BC106BB-3C7F-37C9-8496-43F584A6F304> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff9918d000 - 0x7fff9918dfff com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff993f9000 - 0x7fff993fdfff com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff993fe000 - 0x7fff9941dff7 com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff9948c000 - 0x7fff99713fff com.apple.CFNetwork (760.6.3 - 760.6.3) <8CB9CB2E-D0FB-31D4-A1AE-2A5FE028AD6B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff9974d000 - 0x7fff9975cffb com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff997e4000 - 0x7fff997ecfff libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
0x7fff997f5000 - 0x7fff99869ff3 com.apple.securityfoundation (6.0 - 55126) <DAA4FDD0-7F84-30AA-BE6F-96BB9F871F07> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff9986a000 - 0x7fff99873ff7 com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff99874000 - 0x7fff99bc8fff com.apple.Foundation (6.9 - 1259) <71A9D3A0-0B1F-3E3A-86F3-1486365A6EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff99bdb000 - 0x7fff99c2dfff com.apple.AppleVAFramework (5.0.32 - 5.0.32) <271ED7A9-73E5-3595-A8D6-28594C9F3C9D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff99c6a000 - 0x7fff99f10ff7 com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff99f1d000 - 0x7fff99f34ff7 libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
0x7fff99f3a000 - 0x7fff99f50ff7 libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff99f51000 - 0x7fff99f53ff7 com.apple.xpc.ServiceManagement (1.0 - 1) <D96D7A6D-EDEB-35EE-B5D9-E33A3BF011B5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff99f54000 - 0x7fff99f69fff com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fff99f6a000 - 0x7fff9a1d7fff com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff9a37d000 - 0x7fff9a3b7ff7 com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff9a3d0000 - 0x7fff9a3d0fff libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
0x7fff9a4c4000 - 0x7fff9a4c9fff com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff9a676000 - 0x7fff9aaecfff com.apple.CoreFoundation (6.9 - 1258.1) <943A1383-DA6A-3DC0-ABCD-D9AEB3D0D34D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff9aaed000 - 0x7fff9aaf6ff7 com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff9b14e000 - 0x7fff9b161fff com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff9b162000 - 0x7fff9b27ffff libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
0x7fff9b336000 - 0x7fff9b337ffb libSystem.B.dylib (1226.10.1) <ECAA07BE-A114-3461-AA13-C57838775FC2> /usr/lib/libSystem.B.dylib
0x7fff9b3ed000 - 0x7fff9b3f3ff7 com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff9b482000 - 0x7fff9b628ff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff9b912000 - 0x7fff9bbf7ffb com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff9bbf8000 - 0x7fff9bc06fff libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
0x7fff9bc07000 - 0x7fff9c0c5fcf com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff9c0c6000 - 0x7fff9c1b5ff7 libxml2.2.dylib (29.10) <B3B03292-7E1A-34AB-888C-3D49D63D60C6> /usr/lib/libxml2.2.dylib
0x7fff9c572000 - 0x7fff9c575ff7 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff9c576000 - 0x7fff9c592fff com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff9c593000 - 0x7fff9c7b4ff7 com.apple.CoreImage (11.4.0 - 366.4.19) <F5B7B115-E43A-3C61-A6AD-EFCDE7FC43A1> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff9c92f000 - 0x7fff9ccaaffb com.apple.VideoToolbox (1.0 - 1731.15.206) <19DD020F-128A-32B0-96A4-A51F111B549F> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff9de7a000 - 0x7fff9df6cff7 libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
0x7fff9df79000 - 0x7fff9dff0feb libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
0x7fff9dff8000 - 0x7fff9e044fff com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff9e045000 - 0x7fff9e087ff7 com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff9e088000 - 0x7fff9e08dff7 libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
0x7fff9e08e000 - 0x7fff9e132fff com.apple.Bluetooth (4.4.6 - 4.4.6f1) <F8E54D34-DAAB-319F-8AE7-F3C55CA0CC68> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff9e1cc000 - 0x7fff9e204ff7 com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff9e205000 - 0x7fff9e213ff7 libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
0x7fff9e2b5000 - 0x7fff9e2dfff7 libc++abi.dylib (307.2) <922EFB36-0E9E-315B-8270-E81AC43472C0> /usr/lib/libc++abi.dylib
0x7fff9e2e0000 - 0x7fff9e2e3ff7 libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff9e2e4000 - 0x7fff9e4a4ffb libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff9e4a5000 - 0x7fff9e4a8ffb libdyld.dylib (360.22) <1F9FCF2C-5E94-3F2D-B4A5-1238587AA5C6> /usr/lib/system/libdyld.dylib
0x7fff9e4a9000 - 0x7fff9e514ff7 com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff9e53e000 - 0x7fff9e558fff com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff9e57b000 - 0x7fff9e584ff3 libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
0x7fff9e585000 - 0x7fff9e987fff libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 91
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=350.2M resident=0K(0%) swapped_out_or_unallocated=350.2M(100%)
Writable regions: Total=137.1M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=137.1M(100%)
VIRTUAL REGION
CG shared images 144K 5
MALLOC 74.4M 16
STACK GUARD 56.0M 6
Stack 9824K 6
VM_ALLOCATE 40K 6
__DATA 28.8M 236
__IMAGE 528K 2
__LINKEDIT 93.1M 8
__TEXT 257.1M 243
__UNICODE 552K 2
mapped file 50.9M 3
shared memory 28K 5
TOTAL 623.2M 537
To me, this looks like issues with the GPU
