10 Replies Latest reply on Jul 27, 2017 10:58 AM by davids23429739
    How to pass a variable (not hardcoded value) to a data-sly-use statement.
    davids23429739
      Hello Guys,
      I've got an issue in which I'm unable to pass a variable to a data-sly-use.
      This is a small snippet of the code I have.
      <div data-sly-use.info="questions-and-answers.js"  data-sly-use.questions="${'LatestQuestions' @ maxLinks=info.maxLinks}" class="nc-questions-and-answers">
        <h2 class="nc-questions-and-answers__heading">
         ${info.title}
         </h2>
      </div>
      Basically the first data-sly-use (questions-and-answers.js) returns an object with several properties in which one of those (maxLinks) needs to be send to the second data-sly-use. The problem is that when I tried to get the variable in the java handler I'm always getting null.
      String maxLinks = get("maxLinks", String.class);
      The variables maxLinks is always null.
      If instead of sending `info.maxLinks` I use a hardcoded value like a string or number, I do get the correct value in the Java handler but because the maxLinks property is dynamic then I need to send it like that.
      Does anyone know how to proceed here?
      Thank you.
