5 Replies Latest reply on Jul 27, 2017 9:08 AM by aFatFish
    Indesign A5 Booklet Printing Issue - The booklet doesn't fit the current paper size.
    aFatFish
      Hi everyone,
      Using InDesign CC.
      I'm trying to print a booklet on to A4 paper. I'd like each page to be A5 size (A4 folded in half, landscape). Pages facing each other and double sided (my printer can do duplex printing).
      However, when i go to print booklet, the preview is all wrong - please see second screen grab below. If i export to PDF then try printing I get one page per entire A4 paper, not a booklet at all! How do i correct this? I've tried searching to solve my own issue, and either the solutions are back from CS2 era or simply don't work for me! :-(
      Thanks!
      Tommy
      Detailed Explanation:
      Document set up: Intent set to "print". Number of pages: 20. "Facing Pages" checkbox is ticked. Page size: A5. Orientation set to landscape. 0mm bleed and slug.
      When I go file --> print booklet, i get the following error:
      These are my print settings ("Print Settings" button in above image):
      What on earth is going on? How can Indesign be this stupidly hard to use?
      Here's my Summary log info (from bottom option in the left hand menu from the above photo):
      Print Preset: [Custom]
      Printer: EPSON76B788 (ET-4550 Series)
      PPD: N/A
      PPD File: N/A
      Print Booklet
          Booklet Type: 2-up Saddle Stitch
          Auto Adjust Margins: On
          Top Margin: 0 mm
          Bottom Margin: 0 mm
          Left Margin: 0 mm
          Right Margin: 0 mm
          Space Between Pages: N/A
          Creep: 0 mm
          Bleed Between Pages: N/A
          Signature Size: N/A
          Print Blank Printer Spreads: On
      General
          Copies: 1
          Collate: Off
          Reverse Order: Off
          Pages: All
          Sequence: All Pages
          Spreads: Off
          Print Master Pages: Off
          Print Layers: Visible & Printable Layers
          Print Non-printing Objects: Off
          Print Blank Pages: Off
          Print Visible Guides and Baseline Grids: Off
      Setup
          Paper Size: A4 210 x 297 mm
          Paper Width: 210 mm
          Paper Height: 297 mm
          Page Orientation: Landscape
          Paper Offset: 0 mm
          Paper Gap: 0 mm
          Transverse: Off
          Scaling: 100%
          Constrain Proportions: On
          Page Position: Upper Left
          Thumbnails: Off
          Tiling: Off
      Marks and Bleed
          Crop Marks: Off
          Bleed Marks: Off
          Registration Marks: Off
          Colour Bars: Off
          Page Information: Off
          Printer Mark Type: Default
          Crop Mark Weight: 0.25 pt
          Mark Offset from Page: 2.117 mm
          Use Document Bleed Settings: On
          Bleed Top: 0 mm
          Bleed Bottom: 0 mm
          Bleed Inside: 0 mm
          Bleed Outside: 0 mm
          Include Slug Area: Off
      Output
          Colour: Composite RGB
          Text As Black: Off
          Trapping: Off
          Flip: None
          Negative: Off
          Screening: Default
          Simulate Overprint: Off
          Frequency: 70
          Angle: 45
      Graphics
          Send Data: Optimised Subsampling
          Download: Subset
          Download PPD Fonts: On
          PostScript®: Level 2
          Data Format: Binary
      Colour Management
          Document Profile: sRGB IEC61966-2.1
          Colour Handling: Let InDesign Determine Colours
          Printer Profile: Document RGB - sRGB IEC61966-2.1
          Preserve RGB Numbers: Off
          Proof Profile: Document CMYK
          Simulate Paper Colour: On
      Advanced
          Print &as Bitmap: Off
          Bitmap Resolution: 300
          OPI Image Replacement: Off
          EPS: Off
          PDF: Off
          Bitmap Images: Off
          Transparency Flattener Preset: [Medium Resolution]
          Ignore Spread Overrides: Off
        • 1. Re: Indesign A5 Booklet Printing Issue - The booklet doesn't fit the current paper size.
          Bill Silbert Adobe Community Professional
          A job like this would not need to be printed using the booklet feature. It can be printed using InDesign's regular Print dialog box.
          See screen shot below:
          In the general tab make sure that spreads is chosen (first picture above). In the setup tab (second picture) choose the A4 paper size and orient it landscape. Also choose center alignment. The Duplex settings will depend on your Printer but should be able to be accessed through the Printer button on the bottom of the dialog box. Once into your Printers dialog there should be a Printers Features option which should in turn provide the Duplex option. When you’ve chosen all of the options then you should be able to send it to print.
          Please note that with Duplex printing you will have to make sure that you’ve set the job up in printer spreads including having the front and back cover on a spread together in order for all of the pages to come out correctly.
          All of this being said I must warn you that jobs are not usually printed out to size like this. Printers are not able to print right to the edge and so unless everything has a comfortable margin from the edges content may be lost. The usual process is to print a job on paper larger than the trim size using crop marks and bleed and then having the job cut to size.
          • 2. Re: Indesign A5 Booklet Printing Issue - The booklet doesn't fit the current paper size.
            When you impose a booklet you obviously have to print spreads. Your A5 landscape 2-page spread would be 420mm (16.6") and that spread will not fit on A4 paper, which is 297mm (11.7"). You would need at least tabloid size paper to impose 2-up printer spreads.
            Screen Shot 2017-07-27 at 11.30.54 AM.pngScreen Shot 2017-07-27 at 11.31.59 AM.png
            Or you would have to design the booklet as portrait, which will fit on A4:
            • 3. Re: Indesign A5 Booklet Printing Issue - The booklet doesn't fit the current paper size.
              Even if FatFish arranges the pages as printer spreads, the spreads will not fit on an A4 sheet. Print Booklet feature is there so you don't have to set up a document as printer spreads, which would create all sorts of design problems.
              • 4. Re: Indesign A5 Booklet Printing Issue - The booklet doesn't fit the current paper size.
                OOps. I had it in my head that he was printing the A5s portrait on the sheet.
                • 5. Re: Indesign A5 Booklet Printing Issue - The booklet doesn't fit the current paper size.
                  aFatFish Level 1
                  urrrgghhhhh of course. Not indesign being stupid; it's me. Thank you!
