I just don't understand this basic expression and why it's causing this result. I wanted to make a circle rotate properly along a path, like a ball rolling. I started to play around and when I pick whip my rotation to the separated position dimension of X and start adjusting the X position, it works, but why? All that is in the expression is "transform.xPosition" so I am not understanding where in that tiny expression that if the position moves the object should rotate equally. I feel like to do that would entail a much more extensive expression. Any help explaining this is greatly appreciated!
OK... to answer my own question : )
The key thing to note is that a pick-whipped expression basically just copies the values from one property to another - and those values are unitless. They are interpreted in terms of the units of the property to which they are applied. So in your case X pixels of movement is interpreted as X degrees of rotation.
You need to work out what proportion of a circle's circumference is the distance moved, which is:
distance / (Pi x diameter) . Having got the proportio
...Copy link to clipboard
You got lucky ; )
I bet your ball was just over 100px in diameter? Ideally about 115?
Your expression says: make my rotation equal my x position movement.
ball moves 360 pixels to the right = ball rotates 360 degrees clockwise.
For the ball to rotate without slipping or skidding it's circumference would need to equal the distance it moved.
Diameter = circumerefence / Pi = 360 / 3.14 = 114.6 pixels.
Your homework, should you choose to accept it...
make an expression that rolls without slipping or skidding for a ball of any size : )
distance / (Pi x diameter) . Having got the proportion, you can x 360 to calculate the degrees.
In expression speak:
dia = 300;
transform.position[0] / (Math.PI * dia) * 360
Notes:
1. Change the number 300 to whatever your circle diameter is.
2. No need to separate the dimensions. The '[0]' at the end of transform.position says 'use the first ('X') value'.
Here is the site to learn all about expressions from the master:
Ha! You are correct, I got lucky... about 120px on the circle, now this is making sense!
And I will do my homework!
Thanks Mike!
