14 Replies Latest reply on Aug 1, 2017 2:48 AM by SuperMerlin
    How to separate Fidget Spinner Export JPG files Scripting
    saranr37921948 Level 1
      How to do export files JPG
      any script or any other method
      18 output JPG files
      this is for the Test file PSD file link Fidget Spinner Test Files - Google Drive
      kindly advise
      output files:
        • 1. Re: How to separate Fidget Spinner Export JPG files Scripting
          anybody understand my requirement
          • 2. Re: How to separate Fidget Spinner Export JPG files Scripting
            anybody give solution this
            i stuck
            how to do this
            Photoshop variable or any script
            • 4. Re: How to separate Fidget Spinner Export JPG files Scripting
              very best comedy Sir
              I want solution
              I am learn scripting
              • 5. Re: How to separate Fidget Spinner Export JPG files Scripting
                I want solution
                I was not trying to be a comic.  You posted a layered PSD file that has three layers one each has a an image of a single spinner. One Red, one Green, one blue,  You posted you want 18 spinners jpg and poster 19 row two column list containing 18 file names and an associated color red, green, or blue. You ask if any one understood your requirements.  You want jpeg from ]from Photoshop.  What Photoshop steps are you trying to script. Show us what you have so far so we get some Idea of the process you are trying to automate. You gave us no information as to how you want the generate these files. You ask ho to separate the spinners. Your PSD has them on separate layers. They seem to be separated already??? One of your appends also seemed to indicate you may be using Photoshop data driven graphics for you stated Photoshop variable  which goes along with a PSD and a Row and Column CSV file. However, your PSD does not look like a Data Driver Graphics template. I think the only one who understand what you want may be yourself.
                • 6. Re: How to separate Fidget Spinner Export JPG files Scripting
                  Stephen_A_Marsh Adobe Community Professional
                  JJMack, my “understanding” is:
                  Create a script to cycle through a red, green, blue layered file. The script should perform a lookup from a .CSV file matching the “Fidget Spinner Color” column value to the appropriate layer name to switch on visibility and save out a new file with the name found in the “File Naming” column for that colour.
                  If this was only 18 files, this could have easily be done manually in less than 5 minutes, so I’m guessing that this is either an ongoing requirement or the list is actually a lot longer than 18 files.
                  • 7. Re: How to separate Fidget Spinner Export JPG files Scripting
                    That could be what they want. It is just hard for me to believe they want five copies of a red spinner image, five copies of a blue spinner and eight copies of a green spinner  with coded file names like they show.
                    • 8. Re: How to separate Fidget Spinner Export JPG files Scripting
                      i don't know how to explain in english
                      kindly see the screenshot I want this kind of output
                      • 9. Re: How to separate Fidget Spinner Export JPG files Scripting
                        thank you sir my requirement you understand
                        this is my requirement
                        I have 1000 files:)
                        • 10. Re: How to separate Fidget Spinner Export JPG files Scripting
                          You do not need Photoshop to do file copying. All you would be doing with that script is copying your three images.  It would be very easy with a text editor to make a DOS BAT file using your CVS file to copy the three images jpeg files you started with.  You do not need complicate things  stack the images into a layered document then script the process.  It a simple file copy you are doing..
                          • 11. Re: How to separate Fidget Spinner Export JPG files Scripting
                            SuperMerlin Level 5
                            #target photoshop;
                            app.bringToFront();
                            if(documents.length) main();
                            function main(){
                            var Name = app.activeDocument.name.replace(/\.[^\.]+$/, '');
                            var csv = File.openDialog("Please select CSV file.","CSV File:*.csv");
                            if(csv == null) return;
                            outputFolder = Folder.selectDialog("Please select the output folder");
                            if(outputFolder == null) return;
                            csv.open('r');
                            var data = csv.read();
                            csv.close();
                            data=data.split("\n");
                            var data2=[];
                            for(var a in data){
                                if(a==0) continue;
                                var line = data[a].split(",");
                                if(line.length ==2)
                                data2.push([[line[0].toString().replace(/^\s+|\s$/g,"").replace(/File Name$/,Name)],[line[1].toString().replace(/^\s+|\s$/g,"")]]);
                            data=[];
                            setLayersVisOFF();
                            for(var x in data2){
                                if(selectLayerByName(data2[x][1].toString())){
                                app.activeDocument.activeLayer.visible = true;
                                var saveFile = new File(outputFolder +"/" + data2[x][0].toString() + ".jpg");
                                SaveForWeb(saveFile,80);
                                app.activeDocument.activeLayer.visible = false;
                            function setLayersVisOFF(){
                               var ref = new ActionReference();
                               ref.putEnumerated( charIDToTypeID('Dcmn'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                               var count = executeActionGet(ref).getInteger(charIDToTypeID('NmbL')) +1;
                            try{
                                activeDocument.backgroundLayer;
                            var i = 0; }catch(e){ var i = 1; };
                               for(i;i<count;i++){
                                    ref.putIndex( charIDToTypeID( 'Lyr ' ), i );
                                    var desc = executeActionGet(ref);
                                    var layerName = desc.getString(charIDToTypeID( 'Nm  ' ))
                                    if(layerName.match(/^<\/Layer group/) ) continue;
                                    var layerType = typeIDToStringID(desc.getEnumerationValue( stringIDToTypeID( 'layerSection' )));
                                    var isLayerSet =( layerType == 'layerSectionContent') ? false:true;
                                    if(desc.getBoolean(stringIDToTypeID('visible')) && isLayerSet != true){
                                        var list = new ActionList();
                                        list.putReference( ref );
                                        desc.putList( charIDToTypeID('null'), list );
                                        executeAction( charIDToTypeID('Hd  '), desc, DialogModes.NO );
                            function selectLayerByName(lyrName){
                            var desc = new ActionDescriptor();
                            ref.putName( charIDToTypeID( "Lyr " ), lyrName);
                            desc.putReference( charIDToTypeID( "null" ), ref );
                            desc.putBoolean( charIDToTypeID( "MkVs" ), false );
                            try{
                            return executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO );
                            }catch(e){return null;}
                            function SaveForWeb(saveFile,jpegQuality) {
                            var sfwOptions = new ExportOptionsSaveForWeb();
                               sfwOptions.format = SaveDocumentType.JPEG;
                               sfwOptions.includeProfile = false;
                               sfwOptions.interlaced = 0;
                               sfwOptions.optimized = true;
                               sfwOptions.quality = jpegQuality;
                            activeDocument.exportDocument(saveFile, ExportType.SAVEFORWEB, sfwOptions);
                            2 people found this helpful
                            • 13. Re: How to separate Fidget Spinner Export JPG files Scripting
                              the script not taking the file name the original file
                              the script now taking the CVS filenaming
                              I want taking the CVS to File Naming + original PSD file name
                              Example naming
                              output came this kind of not taking the file name
                              kindly edit the script
                              thank you for your help
                              • 14. Re: How to separate Fidget Spinner Export JPG files Scripting
                                SuperMerlin Level 5
                                #target photoshop;
                                app.bringToFront();
                                function main(){
                                csv.open('r');
                                csv.close();
                                var data2=[];
                                for(var a in data){
                                    if(a==0) continue;
                                    if(line.length ==2)
                                    if(line[0].toString().replace(/^\s+|\s$/g,"").match(/File Name$/)){
                                    }else{
                                       data2.push([[(line[0].toString().replace(/^\s+|\s$/g,"") +"_" +Name)],[line[1].toString().replace(/^\s+|\s$/g,"")]]);
                                data=[];
                                setLayersVisOFF();
                                try{
                                   for(i;i<count;i++){
                                try{
