I'm not sure if this is possible...but I am looking for a way (possibly a script?) to export each layer of a InDesign file to its own PDF.
I have a 5 page indesign file and each page has 3 layers, so the exported pdf would have 15 pages. Does anyone know of a way to do this?
[Moved by moderator from InDesign to InDesign Scripting]
Not knowing script, I would personally make five PDFs and combine them using Acrobat Pro. It would take less than five minutes (maybe three).
But a scripter might be able to automate it for you. I can move this to the scripting forum.
If you could move this to the scripting forum that would be good, as sometimes I could have up to 20 layers on 30 pages (600 pdfs)
Many thanks
InDesign cannot combine PDFs or generate more PDF pages than there are in the original document. When exporting one layer at a time you would end up with at least as many separate files as there are layers.
As yours seems a rather strange document (I'm not doubting that you have good reasons to work this way! But as you found out, InDesign doesn't really have a workflow for this): would it be possible to have this hypothetical script add new pages for each layer, copying only what's on it, and then hide that layer? That is, is the contents of every single layer on its own an entire page?
What you mentioned is exactly what i need... the contents of every single layer on its own an entire page in a pdf.
I'd love to know if this is possible??
It is doable, yes. Fairly simple. Just hide all layers, then loop through all layers making a different one visible each time, and each time export the document as PDFs file, one for each page.
Definitely scriptable... If you'd like a quote, feel free to get in touch: admin [at] id-extras.com
Ariel
Ariel is right!
I've just called it: "0184_EachLayer-PageToPDF_MichelAllio.jsx"
[not for free!]
… Interesting, Script version 2: only the pages per layer with something on the layer will be exported as pdf!
With the Script version 1, all the layers of all the pages have been treated => 20 pdf files!
With the Script version 2, just 10 pdf files!
I wrote a Python script a while ago which might be helpful:
#!/usr/bin/python
# -*- coding: utf-8 -*-
from __future__ import print_function, division, absolute_import
from builtins import super
import win32com.client
import sys
import os
from shutil import copyfile
def patchWin32com():
# https://stackoverflow.com/q/9383307/321973
import winerror
from win32com.client.dynamic import ERRORS_BAD_CONTEXT
global ERRORS_BAD_CONTEXT
if not winerror.E_NOTIMPL in ERRORS_BAD_CONTEXT:
ERRORS_BAD_CONTEXT.append(winerror.E_NOTIMPL)
patchWin32com()
PDSaveIncremental = 0x00
PDSaveFull = 0x01
PDSaveCopy = 0x02
PDSaveLinearized = 0x04
PDSaveWithPSHeader = 0x08
PDSaveBinaryOK = 0x10
PDSaveCollectGarbage = 0x20
PDSaveForceIncremental = 0x40
PDSaveKeepModDate = 0x80
SAVEFLAG = PDSaveFull | PDSaveLinearized | PDSaveCollectGarbage
def splitPDFvariants(pdffile):
"""split PDF into logo/print versions
at the moment, only hides the layers from settings!"""
pdffile = os.path.abspath(pdffile)
acropdf = win32com.client.Dispatch('AcroExch.PDDoc')
for name, logo in (('digital', True), ('print', False)):
pdfcopy = pdffile.rstrip('.pdf') + '-' + name + '.pdf'
copyfile(pdffile, pdfcopy)
assert acropdf.Open(pdfcopy)
jso = acropdf.GetJSObject()
ocgs = jso.GetOCGs()
for ocg in ocgs:
if ocg.name == 'Logo': # lock Logo to relevant state
ocg.initState = logo
ocg.state = logo
ocg.locked = True
jso.SetOCGOrder([]) # remove layers from menu
assert acropdf.Save(SAVEFLAG, pdfcopy)
assert acropdf.Close()
if __name__ == '__main__':
splitPDFvariants(sys.argv[1])
It opens the input argument PDF (created via InDesign, using the "create layers" PDF export option) with Acrobat (Pro) and creates a "digital" and "print" version with the layer "Logo" on and off respectively. With some adaption you can loop through the layers and create individual PDFs for each, and with some more lines you can also merge those PDFs.
Cheers,
Tobias
Thanks Tobias.
Sorry I know next to nothing about scripting, what should I do with your Python script to make it a usable script in Indesign?
Dawn Stiles wrote
Thanks Tobias.
Sorry for the brevity, the script runs independently of InDesign. You just run it via command line and pass the PDF file path and name as argument, e.g.
python exporter.py c:\users\me\Documents\somewhere\thing.pdf
You can run this on a machine without InDesign, but instead you need Acrobat Pro. This also works for other PDFs not generated by InDesign. But as mentioned, the scripts needs a few modifications to actually extract all layers, for which I'm currently lacking the time.
Cheers,
Tobias
You may have it as a plugin :
