• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Is there a RoboHelp 2017 image format that allows you to edit text that you have added to an image?
Participant ,
Jul 28, 2017 Jul 28, 2017
Hi, I need to add text to an image in RoboHelp 2017, and subsequently edit the image, to change the language of the added text. I don't think this is possible in RoboHelp 2017, which appears to only allow the following image formats: .gif, .png, .jpg, .jpeg, .jpe and .bmp, which cannot be edited in this way. Please could someone confirm whether I can do this in RoboHelp 2017 please?
Views
385
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jul 28, 2017 Jul 28, 2017
The answer to your question is No so I'll anticipate that your next question is how can it be done.
I believe it can be done in Flare if you purchase an extra cost add on so if we are into extra cost, there is a solution that will work with some nice benefits. Try SnagIt which I think most authors regard as the best screen capture tool around. Currently about US$50.
What you would do is capture the screen and add the text in SnagIt's own format, then do a Save As in your preferred format for RoboH
Votes
Translate
Translate
Community Expert ,
What you would do is capture the screen and add the text in SnagIt's own format, then do a Save As in your preferred format for RoboHelp. When you need to translate, go back to the SnagIt format and edit the text and do another Save As. You might prefer to save copies of each SnagIt file in each language to minimise translating later.
Would that work for you?
See www.grainge.org for RoboHelp and Authoring information
@petergrainge
Votes
Translate
Translate
Report
Report
Participant ,
Thanks very much for confirming this. I have access to an old copy of Paint Shop Pro, which allows me to save the image as a .psd file (Photoshop). I can then edit the file, as required, and then save it as a .png file, which can be used in RoboHelp. I think that will be an acceptable workaround.
Mark
Votes
Translate
Translate
Report
Report
Community Expert ,
Basically, anything that allows you to save in an editable format.
SnagIt's advantage is simply that is great for other features such as creating a jagged edge to show the shot is not the whole screen, dulling areas so that something in particular stands out etc etc.
If Paint Shop Pro works, it's no cost and on with the show.
@petergrainge
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
SnagIt would be helpful, and it's not too expensive. I'll certainly put in a request for it.
Thanks again.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
