• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Changing Glossary Hotspot Look and Feel?
New Here ,
Jul 01, 2008 Jul 01, 2008
Hello,
I want to use the Glossary Hotspot functionality in my RoboHelp WebHelp project. However, I do not like display method that RoboHelp uses for its Hotspots (Basically, I love the concept of Hotspots, but I don't like RoboHelp's execution of them). By default, in the generated output, the glossary term is italicized and the definition shows up (also italicized) inline with the text of the help page itself. Ugh.
Can I set up my project to show the definition using a pop-up window (or mouseover window) and not inline? Also, can I change the default italicized text to something else (messing with the .css file for the project perhaps)?
Thanks!
Views
593
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jul 01, 2008 Jul 01, 2008
Hi ayanna
Changing the look is simple. You edit your style sheet. Click Format > Styles and look in the Character styles section.
Chaging the operation will be difficult. There is no alternative. If you would like to see one added in a future release, please consider submitting a wish form asking for it. You may do that using the link below:
Click here to view the WishForm/Bug Reporting Form
Cheers... Rick
Votes
Translate
Translate
LEGEND ,
Hi ayanna
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Jul 03, 2008 Jul 03, 2008
Thanks Rick. I figured everything was in the style sheet. I will definitely be submitting a "wish" for the operations part of the feature. For those of us doing a lot of customization to our help (and want the luxury of glossary hotspots) this is a bad limitation.
Votes
Translate
Translate
Report
Report
Engaged ,
Jul 02, 2008 Jul 02, 2008
Assuming you do not have in-line expanding text that you WANT, you can search-and-replace to change the in-line expanding text to a drop down text in the generated files.
Change (replace) the following:
<a class=glossterm
...with...
<a class=dropspot
...and...
x-popup-type=expanding
...with...
x-popup-type=pulldown
Regards,
GEWB
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
<a class=glossterm
...with...
<a class=dropspot
...and...
...with...
Regards,
GEWB
Thanks for this bit of info...
Seems like the code changed a bit for RoboHelp 7? The generated WebHelp output looks like this in the HTML source:
<a class="glossterm" href="javascript:TextPopup(this)" id="HotSpot11681">Glossary Term</a> <span class="glosstext" style="display:'none';" id="POPUP11681">Glossary Definition</span>
The class="glossterm" is there and can be changed in the HTML, but there is no x-popup-type=expanding anywhere in the generated HTML. However, it is in the referenced ehlpdhtm.js file. When I looked at .js file, I found the code where this is all defined (won't post it on the forum because I'm not sure if that's ok).
Basically, it looks like I will have to write my own code (and have RoboHelp not reference it's own javascript when generating a hotspot) if I want to customize this to operate how I want it to operate.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
